Super Pi 8M.
all settings done from bios.
I just chose one speed that I could use multiple fast mhz, and cas settings from. 7 x 367 worked out pretty good for me.
Hardware...
Asus P5B Deluxe. Bios 0711.
Mushkin PC 6400 2 gig kit, cas 4-4-3-10 set.
E6300 CPU.
from the looks of this, MHz is more important then cas alone, and 1:1 isn't better then other higher ratios...unless you can run 1:1 at over 1 ghz of course.
733 mhz at 1:1, cas 3-3-2-8 = 4M-10 Sec.
920 mhz at 4:5, cas 4-3-3-8 = 4M-3 Sec.
1100 mhz at 2:3, cas 5-4-4-8 = 3M-52 Sec.
this is just a simple test, and not meant to be conclusive.
As I mentioned to someone else in another thread, if you have RAM capable of high clocks, take advantage of it.
The people who weren't obsessed with FSB speed saw this early on.
