When i set my nbv to 1.65 the pci-e width drops to 1x, anyone found a fix for this, 1.55 works fine, 1.65 is the one with the problem.......anyone fix this?
hmm strange, do you see it in cpuz or where... I will try 1,65 now and see ( and have also P5B DLX) and same bios version as you
Asus Rampage II Gene - i7 920 D0 Lapped - Lapped Noctua NH12U-F
Sapphire HD4870 X2 - 6GB Corsair Dominator GT@T1 - Windows 7 x64
2 x WD Velociraptor 150GB Raid 0 - 500GB Samsung T166
Antec ThreeHundred - Samsung A656 40"- TX650W
Ok after playing with the settings, i found that if i set my NB volt to 1.65 i need to raise my SB volt to 1.7, anything lower results in pci-e link width to drop to 1X..........problem solved............so if anyone is raising the NBv to 1.65 you may also need to raise the SBv to 1.7......wonder is this is with all P5B's if any one tries this please post, thanks!
Thanks. I was having this problem too.
P5B Deluxe/WiFi-AP
Core 2 Duo E6300 @ 2.8GHz
GeForce 8800GTS
CLICK THIS:http://www.projectoffset.com/astormiscoming/ Each unique view moves the bar up. Last time it filled, a new picture was revealed.
The 1X link width prob appears to my P5B also when i set NB @ 1.65v but raising SB's vcore even @ 1.8v doesn't help.
Edit: The solution, that worked for me, is raising pci-e freq to 102mhz. SB's vcore doesn't matter. U can try this out.
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
Still doesn't work. I think I got it and forgot, because it said it was at x16 afetr leaving it on for a few days, but then I hit reset to see the settings, and it wouldn't startup.
P5B Deluxe/WiFi-AP
GeForce 8800GTS
i had a weird problem. i got 1X pcie width with even 1,45 and 1,55V. then after clearing the cmos it works fine on 16X at 1,65V. also im suffering from occasional reboots/shut downs while gaming. and im using 0711 bios so the restart shouldnt shut down the computer. but mine does shut it down so the problem shouldnt be unstable OC.
Intel C2D E8400 @ 4000MHz ~1,192V
Thermaltake Big Typhoon 120
MSI P35 NEO2-FIR (bios v1.8)
ADATA 2*2GB DDR2 800+ EE
ASUS Geforce 8800GT 512MB + Accelero S1
Seasonic S12-600
Thanks to you (GAR) I just noticed I'm also having this problem! No wonder my game was so choppy today! I'll post back on what fixes it for me. My NBv is set a 1.55v btw.
Edit: Damn it! I tried raising the SBv to 1.7 and nothing. I lowered my PCI-E freq from 105 to 102 and nothing.
Edit2: Also tried raising the PCE-E freq to 108 and the SBv to 1.8 but nothing. Any suggestions (other than lowering the NBv)?
Edit3: Well it looks like all mine needed was a cold boot. After shutting down my PC last night and turning it on this morning my link width is back at 16x. All my settings are just as before. SBv is at 1.6v, PCI-E freq @ 105 and NBv at 1.55v.
Intel i7 3770K @4.7GHz (1.224v) | Gigabyte Z77X-UD5H | 8GB Samsung DDR3-1866 | EVGA GTX 780 Classified
Corsair HX850 | X-Fi Titanium HD | ATCS 840 Black
Apogee XT | DDC-2 w/ XSPC Top | XSPC RX360
I never had 1x pcie width problem with any bios. I'm running my E6600 at 3.6ghz 24/7 and i have 1.65V on NB, 2.3V on ram and 1.55V on CPU. All other voltages on auto
edit: i have pcie frequency always set to auto
C2D E8400 | abit IP35-E | G.Skill HZ 4x1GB | Gainward GeForce 8800 GT | WD 250+500GB | Enermax Liberty 500W
CPU, GPU & NB water cooled
[SIGPIC][/SIGPIC]
That has to be your overclock. Bring it down some and start gaming to see if it is still their.Originally Posted by heikis
Asus P6X58D Premium/ i7 920@3.8Ghz (3.8ghz 24/7)/3X2 Gigs Corsair Dominator 1600Mhz 8-8-8-24/Intel X25M-80gb SSD/Asus 5650/ OCZ Powerstream PSU/Thermalright Ultra Extreme 120/Samsung 40" LED TV/monitor/Windows 7 64bit
This problem manifests itself as an internal BIOS bug. It has nothing to do with certain combinations of settings, rather that when you do change something it can sometimes corrects the setting that causes the problems. The only solution is to change things and reboot until you are working again. Often you can then revert right back to all the same settings after making the fix and have things "magically" work again.
Bottom line, Asus should be aware of this. I expect will we eventually see a fix in furture BIOS releases.
Amen to that...Originally Posted by freecableguy
Project ZEUS II
Watercooling setup:
I hope you're right, but just in case you're not... ASUS REP READ THIS THREAD!Originally Posted by freecableguy
In case one of them is just skimming through the thread.![]()
i get the same reboots even at stockOriginally Posted by NO1B4ME
also ive noticed that my fortron bluestorm 500W gets damn hot in one particular area- near the hole, where the cords come out. i suspect my PSU has gone![]()
Seasonic S12-600
That explains why it was so damn inconsistent.
P5B Deluxe/WiFi-AP
GeForce 8800GTS
If you are running 400X9 as per your sig, you can probably set NB and SB voltages to Auto. 1.65v is way too high for 400FSB.Originally Posted by GAR
Mine is fixed by doing a cold restart, thats unplugging pc and powering back up, works for me 100% of the time.
Hi!
I *just* came across this problem today and gave up trying to figure out why it kept dropping to 1x when i never had any probs with my P5B-E few wks ago, btw im only running E6300 @ 465FSB with P5B-D bios 711. Will post some screens for you guys when i get to work tomorrowI cant get anywhere near 500FSB
actually, my ram wont do cas4 without 1.65v.Originally Posted by sierra_bound
is there any way to put the card linked by pci-e 16x with another bios, a some kind of a hard mod???
Here is how I fixed my PCi-e x1 problem. I was trying to decide if I wanted to run my memory at 1:1 or 4:5. When I had it at 1:1 my PCi-e was x1. When I changed it to 4:5 the PCi-e was x16. I flipped back and forth a few times and the results were the same. I tried changing the NB vCore and it was not the problem.
P5B Deluxe (Bios 1101)
e6600....389 FSB running at 3.51Ghz
Sapphire X1950Pro 512MB
2X1Gb G.Skill F2-6400PHU2-2GBHZ (4:5) running at 973Mhz (4-4-4-10)
vMemory: 2.30
CPU vCore: 1.4625
FSB vCore: Auto
NB vCore: 1.55
Sb Vcore: 1.50
ICH vCore: Auto
PS: I tried for 400 FSB with a vMemory of 2.40 and the bios page froze. I thought I was done. It would not post on repeated tries. I had 4x1Gb of memory, so I tried one set at a time and sure enough one of my sets were defective and would not post. So I guess 2.40 volts is not good for this memory. I am glad I had two sets of memory or else I would not have been able to figure this out. I RMA'd the memory and I am going to keep it as backup from now on.
major thread revival. lol. ram can't take 2.4 for long or 2.3 in most cases. you should try to run at lower volts if possible.
like freecableguy said this is a bug plain and simple and as the posts reflect it was known about last year when the boards launched and they still havn't fixed it. since their resources are focused on p35 and x-38 chipsets i doubt if it ever will be fixed properly.
and back to the ram ..you do realise that those sticks need 2.2 volts and your board only gives them 1.8 by default.(like after a failed o.c.) when the voltage jumps back to set-up defaults (the crash-free bios) the ram is only fed 1.8v and with four dimms it's no wonder it wouldn't boot. memtest those sticks before you rma them at proper settings.
QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.![]()
DFI LP LT X-38 T2R
2X HD4850's water cooled , volt modded
Thermaltake 1KW Psu
4x Seagate 250GB in RAID 0
8GB crucial ballistix ram
this work for me:
setup your overclock and save
power off
remove graphics card
power on without it
switch off before load windows
install again
16x
