Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Opteron 144 @ 3.310ghz *UPDATE 2!* *1m 25 sec* AIR COOLED!
    May 2004
    Finland
    Oppy144@3.330ghz update 3 *water run*
    Hello
    System
    Ocz 430w power
    DFI NF4 Ultra-d
    Opteron 144 0614 KAB1E EPCW
    Khx 3500 2x256mb
    40gb maxtor
    7600gt
    Cooled by Zalman 9500 led + Zalman tzg silver
    Ambient air temp is +9C' outside
    Vcore 1.525v+110%
    Vmem 3.8v
    Mems 200/150 divider
    First i have to say superpi times are very slow, and i dont have no idea why!
    MEM SETTINGS
    UPDATE 2 !!
    Superpi 1m
    Superpi 8m
    I did remove my pc to out and ambient temperature was +9C' same settings!
    UPDATE3! water bench!
    ok im having some problems, mystic boot problems bsod sometimes and no matter if i raise vcore up to 1.8
    water were +6c' and idle&load dropped 4 c* also times were slowening :
    so here they are
    SP1M (vcore around 1.8v)
    SP8M (vcore around 1.73v)
    and my mems are not holding back
    So in the end i have 4 possible problems: Power maybe its running out of juice
    OS it's probably messed up, Mobo maxed out ?! and last maybe water wasnt cool enought...
    we will see it later
    A64 2800@ 9x279 # Abit kv8pro 3rd EYE (vtt and vmem modded) # 2x256 mb TwinMos memory( with old winbond ch-5 max:240@3.5v) # 2x256mb KHX 3000 memory (with old winbond bh-5 max:270@3.7v)
    9600 Pro LE with vgpu mod
    Good Job!
    Jun 2006
    go 25s
    Apr 2006
    Cairo
    26 seconds on air with no tweaking at all that is a good time
    May be it is the language lol
    ________
    volcano review
    Jul 2005
    Netherlands
    Maybe he thinks with al the conroe power 26seconds is slow xD
    Asus P5B-deluxe | E4300@3200mhz | 2x1024MB 400Mhz 4-4-4-12| Asus X1950Pro |
    Apr 2006
    Cairo
    Quote Originally Posted by Razor_Sniper
    He is a member since may 2004 so he should know that AMD max was 21 seconds @ 4ghz
    ________
    Chang'an Ford Engine
    May 2004
    Finland
    Quote Originally Posted by kemo6600
    thanx
    UPDATE 2 edited
    Good Job!
    Jun 2004
    And my watercooled Opteron 146 CABYE won't top 2.75 ghz stable 24/7 at 1.55 volts...
    Nice work.
    MSI K8N Neo2 Platinum Edition, AMD Opteron 146 CABYE 0536GPMW - 2.815 ghz @ 1.65 Vcore (32C idle, 42 Load), 2 x 512 MB TwinMOS SP, BFG Geforce 6800 GT
    Completly custom external watercooling enclosure
    Sony Vaio FS760/W laptop - 1.86 ghz Pentium M, 1GB DDR2, 6400 Go with 128 MB
    Oct 2005
    That is crazy impressive, great work man!
    May 2004
    Finland
    thanx , tomorrow some chilled water...
    Good Job!
    Jun 2006
    México
    Ok, youve got a good stepping right there.
    So, just Air cooling right? Very impressive. I can do that with my Opoteron 146 CABYE 0540 but using Water cooling (as long as processor doesnt go above 35ºC and using 1.5v or 1.525 v)
    Congratulations.
    Xtreme Enthusiast Celcius's Avatar
    Dec 2004
    Texas
    Nice, keep pushing it!
    Xtreme Mentor
    Feb 2004
    The Netherlands
    I'm convinced that a better aircooler could get you some extra megahurtz !! amazing chip dude
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
    May 2005
    Oslo, Norway
    Nice clock dude, but hey, you playing Age Of Empires 2? Haha, nice SPI version btw, do you have a link to it? I want it.
    Apr 2004
    Helsinki / Finland
    My old golden Opt 146 CABYE 0540FPBW did nice SuperPI times with TT BigTyphoon
    SP1M 24.953s
    SP8M 4m32s
    SP32M 22m06s
    Too sad I hade only 2x256mb BH-5
    KeZzZu, use some Finnish cold air, here is now only 7'C
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
    Jun 2006
    any closer...and you are there.
    May 2004
    Finland
    i did put my pc to outside and oc results are better
    Good Job!
    May 2005
    Paris (France)
    Kezzzu: i think you can improve your spi time with some tweaks.
    however, week 0614 for opty are the best ever for air/water.
    here is my last 0614DPCW with normal air (~40°C idle)
  18. #18
    May 2004
    Finland
    yes i know that i can tweak little bit tighter mems
    but i have some issues with cpu-z 1.36 , it will keep cpu under 100% load all the time , so icant open another cpu-z to show mem speed
    Good Job!
  19. #19
    May 2004
    Finland
    heh it has been while for OC so maybe at whis weekend ill play with water depends on outside temperature becose my chiller is broken atm
    Good Job!
  20. #20
    Oct 2006
    Argentina
    nice Chip there you have. I think that the KAB1E and KABYE are he bests overclockers ( FX Step )
  21. #21
    939
    May 2006
    Safe Switzerland
    i love all 0614chips... my best no opti, but 0614
  22. #22
    May 2004
    Finland
    UPDATE
    ok same setup but bumbed voltages and got 7 mhz more for cpu but i didnt take screenie and still on air temp were around + 6c'
    So im against wall with air so i did do little research and found that my mem has still plenty of room in OC enjoy hopig that my mobo isnt limiting, quessing that zalman cant keep temps enought low to get better run. Next time with water
    Good Job!
  23. #23
    May 2005
    WoW, maybe I shouldn't have sold my opty 144 for 60 bucks shipped... lol
    A+ Black Pearl
    GIGABYTE GA-EX58-UD5
    Intel i7 920 @ 4.1ghz | Apogee GTZ | Swiftech MCR320 | Liang D5 Vario |
    6gb Corsair XMS 1600
    Visiontek HD 4870
    3x 640gb AAKS Raid-0 Short-stroked 300gb
    Corsair TX750
    Olevia 42" 242TFHD 1080p
  24. #24
    Xtreme X.I.P.
    Nov 2002
    Shipai
    ahhhh man... those pics are in awfull quality, my eyes hurt :P
    and most dont seem to load actually... maybe rehost them?
  25. #25
    Jun 2006
    Russia
    Nice clock for air
