Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: 1900XT 256mb is smoking
    Slovenian OC Master
    Nov 2004
    Slovenia
    OC-Lab.si!!
    Feb 2006
    Russia
    Nice clocks & Great Result! Congrats!
    What gpu cooling?? What about coldbug??
    Jun 2004
    Quote Originally Posted by zbogorgon
    thats pretty good clks for single stage...
    what ram is used on 256mb version XT...
    I am Xtreme
    Apr 2005
    Upstate, NY
    Holy CRAP. AWESOME clocks man, holy cht. Keep pushin!
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Slovenian OC Master
    Nov 2004
    Slovenia
    actually I was able to do a run with 1030 on ram, but failed on doing pic, cause after run I run that buggy ati tool (i closed it by mistake after setting the clocks) which screwed the screen, but i saved the project, did 17414.
    pic of system
    OC-Lab.si!!
    Apr 2006
    Cairo
    Nice clocks
    what is your max without vmod
    ________
    Ferrari F399 specifications
    Slovenian OC Master
    Nov 2004
    Slovenia
    there is no vmod and no coldbug up to -36, it's only SS , voltage adjustment with ati tool only.
    OC-Lab.si!!
    Apr 2006
    San Gabriel, CA
    Quote Originally Posted by Dynasty
    on my sapphire X1900XT 256, they are samsung B12s. i have no idea how high they can go.
    nice clocks, man!
    i5 2500k @ 4.6GHz - Corsair A70 | Biostar TP67B+ | G.Skill RipJaws DDR3-1600 2x2GB | MSI HD7950 TF3 | X-Fi Titanium | WD 750GB Black | CM 690 II - Corsair TX850 | 2xDell 2407WFP A04/A03 | Win 7 Pro x64
    http://www.heatware.com/eval.php?id=48222
    Xtreme Legend
    Dec 2004
    Sweden
    Incredible
    Smaller framebuffer should help the OC. Are you running max vddci? If you do not have black artifacting there is room for more voltage to the mem also.
    Jul 2005
    ATX
    crazy clocks!!!
    May 2005
    Camping your spawn :)
    Verry impressive..
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
    I am Xtreme
    Aug 2003
    Kick ass mems Core looks strong to. Great score!
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Apr 2006
    Cairo
    That means that 256mb x1900xt is a good deal and average user can overclock the memory up to 1800 MHz effective at least with no problems
    ________
    330
    Slovenian OC Master
    Nov 2004
    Slovenia
    Quote Originally Posted by Kinc
    Incredible
    thx, vddci was all the way up, there were a few articafts during benching,
    Quote Originally Posted by kemo6600
    it has potential, but on water cooling i benched at 780/780, so rams were pretty bad, but i suspect Ati Tool for that.
    OC-Lab.si!!
    Jan 2006
    Sweden
    I'm using a x1900xt 256mb too, with watercooling. Not getting great clocks at all and I have problem getting ATi tool to work properly. :<
    Jan 2006
    Crete-Greece
    Crazy Stuff!
    24/724/7
    Sep 2006
    how come nobody uses the stock CCC to OC it? I got a 256mb Saphire X1900XT as well, and I just OC it a little with the ACI overdrive thing...running 660/750:
    is there something I'm missing?? is CCC not good enough?
    Intel e8400 @ 4.21Ghz 24/7 (467fsb@1.29Vcore)
    Asus P5Q-E mobo, 1406 BIOS
    4x1GB Crucial Ballistix PC6400 DDR2-800 @ 5-5-5-18 1:1
    Sapphire Radeon X1900XT @ 690/792 3D
    2 x 320Gb WD SATA for apps/data
    1 x 320Gb WD SATA for backup
    Scythe Infinity Heatsink
    700W Thermaltake Toughpower PSU
    Dell 2405FPW 24" LCD
  18. #18
    Sep 2006
    I guess the question is this:
    If you are not planning to do a lot of 2D intensive stuff, just your basic internet browsing, etc, and you just play 3D games (Quake4, doom3, oblivion, etc), then what does one gain from OCing this card using ATItool vs the ATI CCC overdrive tab?
    If I use the ATI overdrive in CCC, doesn't that set the 3D ranges as well as the ATI tool, when doing 3D games?
  19. #19
    May 2006
    Philippines ^_^
    excellent man.. nice video card ..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  20. #20
    Jan 2006
    Sweden
    What voltage did you use when you got that high, I've got some problems getting the mem speed up, running 781mhz right now, want to hit 800.
  21. #21
    Jan 2006
    Sweden
    *double post*
  22. #22
    Apr 2006
    San Gabriel, CA
    i set my memory voltage to 2.088 via ATi Tool. running at 715/801. on the 512 models, the memory ran around that voltage in 3D mode, so i guessed it should be safe.
  23. #23
    May 2006
    Sweden
    really nice, what brand is that board?
  24. #24
    Xtreme Guru
    Jul 2004
    Very nice ov3rclock!
  25. #25
    Slovenian OC Master
    Nov 2004
    Slovenia
    new results, just missed single card WR for 05, my 2nd run this session, after that i had problems with graphic card so even no LOD was applied , will try soon for more.
    OC-Lab.si!!
