I always wonderd why the Mushkin PC6400 Cas 443 stuff was so low key here, I had a hunch that it was some great ram... and boy was I right![]()
heres some previews of what I did with them yesterday.
I just got these yesterday, so all this is very preliminary, so I dont fully know the quirks of this ram yet, but heres alittle I can say so far.
I've tested every latency combination that I normally use, at the 2 volt setting so far, to find the max with each cas. so far, cas 5-5-4-12 at 2.0 volts seems like a sweet spot for 550, or 1100 mhz, and cas 5-4-4-10 is good for about 560, or 1020 mhz.
thats pretty cool for a low voltage overclock.
but the real fun, for me, is the high voltage overclocking, so how about getting to that.![]()
this ram uses the Micron D9GMH.
it's extremely responsive to extra voltages, and boots just fine, error free, right into windows for me at 2.88 volts... the highest voltage I currently have available to me.
Hardware Used.
650 watt Mushkin PSU + 250 Thermaltake VGA PSU.
Asus P5B Deluxe, WiFI version. Bios 0614.
PowerColor X1950XTX.
E6300 that tops out just below 3.9 ghz on air.
2 x 150 gig raptors/raid zero + 400 gig slave.
Creative Xfi.
CD/DVD Burners...
and the Mushkin PC6400.
Voltages adjustable to 2.88 volts Via Hipro DDR2 Maximizer.![]()
(great toy if you dont want to volt mod something)
Tests.
Initial tests, 10 rounds of Memtest 86 test #5 before trying in Windows.
then Super Pi Mod 1.5.
thats it so far.
(remember I just got this yesterday)
I run test 5, cause I find if I can pass that a dozen times or so, then I can probably pass 32M and 3Dmark as well... so it saves me time testing with that first.
for the 475 cas 3-3-3 shot, that was done with booting into windows at cas 3-3-3 at 450, at 2.8 volts, then clockgening to 475.
however, with how easy it was to pass 32M at 475, I think 485 might be possible as well. 490+ doesn't seem possible yet... but then again, I have alot of tweaking to do, so who knows![]()
heres the max I got.
2.88 volts.
(So damn close to 500... just need more voltage...)
this shot here is a personal favorite, cause I like ram that can run ras to cas 3 at 1 ghz.... unfortunatly, I forgot what voltage I used for this shot... will do more testing later anyways, so I will find out then.
this next shot, is just a moderate overclock, showing the max I got at 2.25 volts. nothing too interesting I suppose, but I wanted to try and be alittle thorough on the range I am showing, high voltage and low voltage OC's.
this shot I like alot too, cause it was done at 2.3 volts, and is extremely stable and easy to reach. 1066 mhz, cas 4-4-4-4 or PC8500 speed.
I definatly like that.
this is a 100% boot up shot, not clockgen or memset shot.
