Results 1 to 25 of 82
Thread: Thermalright HR-03 - x1k Owners Rejoice!
Threaded View
    Skulltrail Junkie
    Jan 2005
    Milwaukee, WI
    found this while browsing at sidewinder computers today:
    http://www.sidewindercomputers.com/thhr.html
    Thermalright HR-03
    Product Description & Info
    Definitely a world first and a first for Thermalright, the HR-03 VGA cooler can be run passively or accommodate a 92 mm fan. The HR-03 can be mounted in two ways also, which is a key factor for SLI users. The compatibilities of this VGA cooler have been enhanced to support all the latest cards as well. See the HR-03 for yourself below, we installed it on a BFG 7900 GT-OC, paired with one of our Akasa 92mm Amber series fans.
    * Designed to work fan-less or with a 92mm fan at low RPM for low-noise operation and higher performance
    * Proprietary through holes on fins for efficient ventilation and proficient cooling
    * 4 innovative designed heat pipes (2 U-shaped and 2 N-shaped heat pipes) for thorough heat distribution across multiple fins
    * Two ways of mounting the cooler on video card for best space and configuration management
    * Light weight and easy no-tool installation
    * Vast compatibility with system cases (ATX & BTX)
    * SLI/Crossfire friendly for those serious gaming enthusiasts
    * Cosmetically contoured design for that vanity look
    Technical Specifications
    Dimension
    L133 x W156 x H38 mm (heatsink only)
    Weight:
    350g (heatsink only)
    Compatibilities
    ATI:
    X1300TD, X1600TD, X1600XT, X1800XL, X1800XT, X1900XT, X1900XTX,X1950,X1900GT
    NVIDIA:
    6800, 6800TD, 6800XT ,6800GT ,7800GT,7800GTX ,7600GS ,7600GT ,7900GT ,7900GTX ,7900GS,7950GT
    HR-03 $46.95
    Judging by the 4-heapipe design and 92mm fan compatibility - this looks to be the first TRUE, GOOD air cooling solution (other than the noisy azz stock HSF) for owners of ATI X1800 and X1900 series cards
    If I didn't have water cooling, I'd be jumping on this right now!
    • Lian Li PC-75B • Corsair Professional Series 850w •
    • 2x Intel Xeon E5420 @ 3.0GHz (400x7.5) • Intel D5400XS Skulltrail •
    • 8GB (4x2GB) A-Data DDR2-800 FB-DIMM ECC (1:1 @ 400MHz) •
    • MSI Radeon HD4870 1GB • Creative X-Fi Titanium HD •
    • 2x WD VelociRaptor 150GB (RAID 0) + 2x WD Caviar Black 500GB •
    • 2x EK Supreme HF CPU • EK S-MAX NB • EK VGA Supreme GPU • Blastflow Tidal SB •
    • Thermochill PA120.3 • Swiftech MCRes-Micro • Laing D5 w/ Bitspower Top •
    Heatware • http://www.heatware.com/eval.php?id=34593
