09-29-2006, 10:35 PM
#1
vMCH pencil mod for intel D975Xbx Bad Axe
at your own risk...
just my 2c, but when i pencil mod, i take the initial reading, pencil, take a reading and when i am happy, vacuum the graphite dust, take another reading, and if it is all good, slap a small piece of tape over the area.
I lowered the resistance by 10 ohms from 330+/- to 319, and when 1.725v is set in bios, i get 1.82v actual w/ dmm. Now stable at 450.
__________________
- E8500 @ 4.25 -1.41v/P5K-E vdroop mod
2x2gb OCZ Plat 1000@1000
7800GT/WD640AAKS
RocketRAID 2322/4 x WD7500KS RAID5
Sunbeam Core-Contact
10-04-2006, 08:40 AM
#2
Memory Addict
awesome... anyone else try this ?
do you have a top down photo of the area to pencil ?
where's the vMCH read point for DMM measuring ?
thanks
10-04-2006, 11:55 AM
#3
here is omegas? pic.
__________________
7800GT/WD640AAKS
10-05-2006, 10:25 PM
#4
Is that blue box called a "trimmer"? I'm still rather new to electronics, but am trying to learn more about parts as a EE major. Unfortunately in classes, they don't expose us to real-life circuit elements enough.
__________________
MSI K8N Neo2 Platinum Edition, AMD Opteron 146 CABYE 0536GPMW - 2.815 ghz @ 1.65 Vcore (32C idle, 42 Load), 2 x 512 MB TwinMOS SP, BFG Geforce 6800 GT
Completly custom external watercooling enclosure
Sony Vaio FS760/W laptop - 1.86 ghz Pentium M, 1GB DDR2, 6400 Go with 128 MB
10-16-2006, 07:51 AM
#5
hey just curious, but when I measure with a dmm, at the spot indicated if set to auto in bios, I'm only getting 1.3v, and when set to 1.725, it only gets 1.6, is that spot acurrate or is my board def? the spot circled is where I'm measureing from
10-19-2006, 11:01 AM
#6
reaching perihelion
That's the appropriate spot
Looks like why Bad Axes are so FSB limited; my r.302 gave ~1.55Vmch for 1.72V set into the bios... BTW mine took Spi1M @ 450FSB for ~ 1.55V as observed with 2 different DMMs.
I've got the same issue with Vddr (for instance it was ~ 2.08V DMM for 2.2V bios)
__________________
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
10-20-2006, 08:19 AM
#7
Memory Addict
Okay did this vMCH pencil mod on one of my D975XBX Bad Axe rev304 ICS based boards
Default - only measured 1.725v bios setting
bios setting -> bios value -> dmm value -> IDU value
1.725v -> 1.671v -> 1.689v -> N/A
pencil vMCH modded
1.725v -> 1.736v -> 1.744v -> 1.745v
1.650v -> 1.671v -> 1.670v -> 1.680v
1.600v -> 1.620v -> 1.628v -> 1.628v
1.525v -> 1.555v -> 1.615v -> 1.563v <- weird ???
default -> 1.555v -> 1.615v -> 1.563v <- weird ????
Before pencil vMCH mod max fsb on this board was 421-423fsb (1067fsb strap) and 426-429fsb (1333fsb strap) using Thermaltake Extreme Spirit II chipset cooler.
Have yet to test new max fsb for this board.
10-24-2006, 01:53 AM
#8
reaching perihelion
It seems me a pretty good work buddy
That's good to have a little higher voltage than what the bios reads because of the droop while the system is loading. In a sense, the bios setting is an average value.
__________________
Best Regards,
Xavier
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
