Using the P5WDG2-WS Pro with a QX6600.
FSB is stuck at 310FSB, no higher is stable.
Can't raise the multi higher than 9x. Flashed on a beta bios which opens it up to 20x, but it doesn't post at anything above 9.
Any ideas?
Temps maybe? not enough volts? might have to face that its just a crud OC cpu
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
wth is a QX 6600 ? you mean an E6600 ?
and what week and stepping ?
what voltage ?
what psu do you have
what ram
what everything
come on guy ya gotta help us out if you want us to help you.
so lets start with the most obvious here.
you have a 6600 there is NO upwards multi that is ONLY for the X6800
where how and when did you think you got anything more than 9x ?
"These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
Welcome to the Roughnecks"
"Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
Heat Ebay Feedback
Kentsfield ES - QX 6600
AMD Opteron 148 CABYE 0543 FPBW || DFI LanParty nF4 SLI-DR AD0
2x 512MB OCZ PC3500 Limited Edition Winbond BH-5 || 2x 512MB Corsair PC3200LL V1.1 Winbond BH-5 || 1x 256MB Mushkin PC3500 LV2 Winbond BH-5
SAPPHIRE X800GTO2 @ 16P 600/570, Voltmodded, GPU=1,7V/VDD/VDDQ=2,3V
Zippy PSL-6720P(G1) GAMING ,POWER - I love it!
here is a QX6700 thread
http://www.xtremesystems.org/forums/...d.php?t=106324
the QX6700 means
4x Core 2 Quad Xtreme version E6700
and so on ...
its Q6600 i think, not an extreme edition
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
All Kentsfields are Extreme Edition processors. Another member had a 6600 Kentsfield. He was using a P5W DH.
http://www.xtremesystems.org/forums/...d.php?t=109445
in response to the original post/question:
you will find that different boards/BOISs respond quite differently to each individual kentsfield. don't forget - you're dealing with an Engineering Sample. i have seen some quad cores that will go to 400 FSB (only one actually) and many more than struggle anywhere from 300-360FSB. you'll more than likely need to test that CPU in many, many different environments before you find one that satisfies you (what do you think the MB manufactures are doing with theirs?)
-FCG
Only one?Originally Posted by freecableguy
http://www.xtremesystems.org/forums/...&postcount=130
I think current Kentsfield record is 450FSB.
9x310=2790MHz. That is what you can run at the moment?
Atleast 10x266 should be possible without raising vCore. But just to be sure, put the vcore a few 'steps' over stock voltage.
I am not sure, but was there not a 'lock' somewhere in BIOS that keeps the standard allowed multiples? I will check that later.
Is it BIOS 0004 or 0005 that you are using at the moment?
sierra: Nice result! I can not get my B0 over 220 yet.
well you heard it from one of the few guys around here who knows what the kent's are like. and as usualy with FCG i'd trust his word.
Heat Ebay Feedback
My main concern is that it doesn't post at higher multipliers. If it does 2.8GHz normally, it should do at least 266*10. Temps are high 40's. Tried 0004 and 0005 - both the same problem.
I've tried heaps of settings and it won't post above 9. How is everyone else posting above 9?
Is there any way to change the multi in windows?
I'm about to try with vcore @ 1.4375V
Still no post at 10![]()
try a different motherboard![]()
so this is false:Originally Posted by sierra_bound
http://www.xbitlabs.com/news/cpu/dis...919051744.html
no Q6600??
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
So the 6600 isn't an Xtreme edition?
This one could raise the multi:
http://img235.imageshack.us/img235/4966/untitledzf1.jpg
Mine has the same revision as his and appears the same in cpuz except that mine says it's an ES...hmm
Also note that only die 0 will change multi over stock 6-20 for both cores, die 1 will stay at 6-9 range (for 6600s) and 6-10 range (for 6700s) for both cores, this is only relivant to ES I beleive.
:: QX6600 ES @ 3,0Ghz 1.4V |Mine Idle: 56c Load: 74c (SP2004 CoreTemp)
:: Asus P5W-DH | 2GB Gskill 6400HZ DDR1000 2.3V 4,4,4,8
:: 74GB Raptor : 320GB 7200.10 | Antec P180 | XFX 7950 GX2 600/1500
That mobo can go higher "normally" on a Conroe. Kentsfield is going to behave differently for sure, but you may need to consider the ram your using, and that the P5WDG may not like it.
The heat goes up fast on Kentsfields oc'd, so I'm guessing you've used the multi to go up to test how far the cpu is capable of first yes?
The Q6600 ES "should" be open multi yes. But bios can limit this - have you updated the bios?
All thoughts to consider![]()
Well right now I can't change any dies.Originally Posted by qui
Board does 458MHz with my memory on my E6300.Originally Posted by Anemone
I can't raise the multi at all. If it does 9*300, one would think it'd do 266*10.Originally Posted by Anemone
Well I've tried all the beta bioses that actually give the multi option.Originally Posted by Anemone
All the quads will be xtreme edition, they'll certainly be priced as such imo
Something definitely odd about your ES...![]()
then tell me , these articles:Originally Posted by 775911
http://www.dailytech.com/article.aspx?newsid=4217
http://www.hkepc.com/bbs/itnews.php?tid=671374
are false??A mainstream quad-core Kentsfield will launch early next year, dubbed the Core 2 Quadro Q6600, and will debut with a 2.4GHz core frequency. A price tag for the Q6600 has not been set yet, but the processor will retail for less than the QX6700 but more than the Core 2 Duo E6700. The E6700 has a street price of approximately $530 USD, but price cuts will bring the cost of the CPU down before the Q1'07 launch of mainstream Kentsfield.
as for why 6600 has unlocked upward multi. 2 scenario:
1. all kentsfield have upward unlock multi.
2. maybe b/c thats an ES??
i hope its the 1st one ... and i hope there is a Q6600
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
Try this bios..http://www.xtremesystems.org/forums/...&postcount=144
