Results 1 to 14 of 14
Thread: No enough Space to copy PCI Option ROM [05:02:01] error???
    Feb 2004
    Question No enough Space to copy PCI Option ROM [05:02:01] error???
    I don't know what I did wrong. I had a defective x1900xtx so I sent it to ATI and they replaced it for me. Meanwhile, I had the ATI x800gto in the system for now. Well, I put back the x1900xtx in the system and when going through the boot sequence, I recieve this error:
    Press F1 to Resume
    Here's a picture of it:
    The system comprises of the following:
    PCIX Adaptec 2 channel card ( 1 channel is being used ) and this controller is my 1st boot device since it has my OS.
    I have a backup WD 300G drive on the SATA connection as well as my DVDRW ( Plextor )
    The Dell monitor I have has a number of USB and memory slots on it as well so I think the boot sequence also refers to those ( not sure ).
    Remember, I didn't have this problem before until I put the card back it.
    Any clues.?
    When I press F1, it boots into Windows without a problem.
    The un-extreme XIP
    Jul 2004
    try flashing, or reflashing, to the latest bios
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Feb 2004
    Quote Originally Posted by cirthix
    Forgot to mention, but I did that as well.
    Feb 2004
    sorry for this but I'm hoping someone can help with this.
    Nov 2005
    Mansfield TX
    Do you have plug n pay os = yes set in bios? Sounds like you've run out of IRQ's. Leave the usb's on your dell unplugged if you have pugin pay os set to yes.
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
    XS_GAMERS
    Jul 2006
    New Jersey
    The MB bootrom cannot hold all of the option ROMS it's trying to. Try disabling secondary HDD controller bootrom.
    Core 2 Duo E6400 3.4ghz SL9S9 1.4v
    GIGABYTE GA-P35C-DS3R
    Mushkin eXtreme Performance 6400 4-3-3-8 D9
    HD2900XT 512MB on 17" Samsung 730B viv Monster DVI
    2xWD740ADFD RAID0--1xWD320KS 16mb SATAII
    Plextor PX 716SA--Plextor PX740
    X-Fi
    Silverstone OP650
    In a HSPC Tech sStation
    Feb 2004
    [Do you have plug n pay os = yes set in bios?
    It was set to No so I changed to Yes - same problem
    In the initial screen I disabled what I could as far as the drive controllers are concerned but the only drive I have is a single WD 400G drive and a Plextor 716 SATA connected. The Raid drives are on a seperate PCIX Adaptec SCSI controller.
    Even tried to disable the USB controllers, printer ports etc.
    I have ACPI off, not sure if I should put it ON in this case - If I set it on, I assume the os will have to reinstalled?
    Funny thing is I didn't have this problem with the other card. All I did was put back my x1900xtx...strange. As mentioned, when I'm fully booted up after pressing F1 and going into xp, everything works fine. No errors in Device manager...nudda.
    I'M STUMPED!
    I asked Asus with no luck at all and they actually mentioned that it could be the card since when i do install the x800GTO ( which uses the same drive, there's no issue ). Called ATI and they never heard of the problem and are stumped as well. ATI just sent me this card 3 days ago as a replacement for another one I had.
    Feb 2004
    Well anyway, this will be my final post on this but since the x800gto doesn't cause this problem, I'm just going to assume that the card ATI sent me was defective and will request another card
    Feb 2004
    I even tried relocating to the other PCIX slot. Tried another x1900xtx and even my latest video purchase - the x1950xtx has the same error ocurring. I know it has to do with IRQ conflicts with the video card but no one can figure this out.
    I called Asus - no luck
    I called Adaptec but they charge $199 per call!
    This is what I have installed:
    NO HARDDRIVES other than those on the scsi control card
    1 SATA PLEXOR CD player
    1 SONY LS120 IDE DRIVE
    anyone?
    Sep 2004
    West Covina. CA
    clear the cmos...............
    Feb 2004
    Quote Originally Posted by Falkentyne
    Did that and even put back the original bios for both the motherboard and adaptec 39320A-R adapter.
    I give up. The only thing left is the motherboard.
    Feb 2004
    I called Adaptec customer service and after trying many different types of scenarios, there is NO SOLUTION. Apparenty there are issues with the dual channel adaptec controllers ( not the single channel ) and certain pci-x video cards. Apparently, Intel did address the issue but do not have a solution other than downgrading to a single channel adaptor or downgrading through experimentation different video cards.
    WHAT DOES WORK:
    Adaptec 39320A-R with ATI x800GTO
    Adaptec 29320A-R with any video card
    WHAT DOES NOT WORK
    Adaptec 39320A-R with x1900xtx or x1950xtx
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Adaptec 29160 and 2940 will also display the same message with X1900 video card installed.
    I was searching google and this hit came up to the top.
    I guess I will switch out to another video card.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jun 2002
    Las Vegas
    The bios on the 29160 does allows you a few ROM disable options, this did correct the boot problem with the exception the 29160 does not have boot device on it, its running a scanner on mine.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
