My customer Raju contacted me with something special in mind so this unit I gathered only the best components I could find and got my good friend Dimas to make the case.
Specs:
Compressor: Danfoss NL11F
Condensor: Rifle tubing high performance from Placebo
Refrigerant: R402a
Cappilary: 2.7m 0.031"
Evap: @itor with acrylic kit
Controller: Gfroster XE 1.6
Temps:
Idle: -60c
150w constant: -45c
200w constant: -40c
@itor evap:
DimasTech case with window. It is 590mm deep instead of the usual 490mm to fit under Lain Li PC70 case.
Plexiglass panel with 2 x LCD's. Will measure Condensor in/out temp. The panel will sit behind the Window panel
Power box, contains 15v ac transformer for Gfroster, 5v DC for LCD's and Gfroster power module:
Some shots of unit:
LED's in enclosure![]()
Hold it off a few month until Gray gets mine sorted will you please.
