these instructions came from a IBM tech support read me file http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62909 (Found after reading http://www.neowin.net/forum/index.php?showtopic=457699 What BIOS setting would be the same on a the ASUS P5W DH? Will be setting up my SATA drives RAID Ready, will not be using RAID
If you do not have a diskette drive, you can install Intel Matrix
Storage Manager Driver by the following alternative procedure:
Note: If you select AHCI for Serial ATA (SATA) in the BIOS Setup
Utility before installing Intel Matrix Storage Manager Driver,
your computer will not respond; it will only display a blue screen.
1. Start the BIOS Setup Utility menu.
2. Select "Config".
3. Select "Serial ATA (SATA)".
4. Select "Compatibility".
5. Install Windows XP and Service Pack 2.
6. Download Intel Matrix Storage Manager Driver from the Web site and
extract the driver to C:\DRIVERS\WIN\SATA.
7. Run Intel Matrix Storage Manager Driver. To do this, go to
C:\DRIVERS\WIN\SATA\PREPARE, and double-click install.cmd.
8. Turn the computer off and then on again.
9. Start the BIOS Setup Utility menu.
10. Select "Config".
11. Select "Serial ATA (SATA)".
12. Select "AHCI".
13. Start Windows XP. The Welcome to the Found New Hardware Wizard
appears.
14. Click "No, not this time", and then click "Next".
15. Select Install from a list or specific location (Advanced), and then
click Next.
16. Select "Search for the best driver in these locations". Then select
"Include this location in the search:", specify the path,
C:\DRIVERS\WIN\SATA, and click "Next". The Completing the Found New
Hardware Wizard appears.
17. Click "Finish".
18. When the System Settings Change window appears, click "Yes". The
computer restarts.
