I will show you some pictures of my the project I´m working on right now.
I have worked on it for about 2weeks and i think it´s time to publish the pictures on an english site too.
The case I´m modifying is a Cooler Master Centurion 534 wich I have polished on the aluminium at the front, as you can se on the pictures. This will be a watercooled system.
Special thanks to:
Sven at www.sbs.o.se
And
Gary Stofer at www.sidewindercomputers.com
Some pictures on the case
Second updace: The cpu hase arrived and some more polishing
Third update: The 5,25" covers are finnished
Fourth update: Fan controller and the front panel is done
Fifth update: The watercooling system and som other stuff
Sixthe update: Modified the pump, radiator and the case
Seventh update: Fans and cd/dvd stealth
Eight update: Painting the case and fans. Sleeving and some memory
Ninth update: The first radiator
Tenth update: Second radiator, and pump
Twelfth update: Making the reservoir
Thirteenth update: finnished the reservoir
Fourteen update: Almost finnished
