Results 1 to 25 of 103
Thread: Fritz Chess Benchmark+AxonBench
Threaded View
    Sep 2006
    Fritz Chess Benchmark - http://www.jens.tauchclub-krems.at/d...0Benchmark.zip
    XS Top Runs (by Relative Speed):
    (Updated 5/7/09)
    #1 Rol-Co -------- 43.16 ---------- QX9775@4730Mhz
    #2 Movieman ------ 36.82 ----------- E5450@3858MHz
    #3 rge ------- 35.08 -------- i7 940 @ 4600Mhz
    #4 ReverendMaynard -------- 33.45 -------- i7 920 @ 4410mhz
    #5 T_Flight ------- 31.86 ---------- i7 965 @ 4200Mhz
    #6 rogueagent6 ------- 31.42 ----- i7 920@4200Mhz
    #7 liftedcj7on44s ------- 29.72 ------ i7 920 @4018Mhz
    #8 NapalmV5 -------- 29.32 ------------ Q9650 @ 5GHz
    #9 Zucker2k ----- 26.62 --------- Q9650@4554Mhz
    #10 570091D ------ 23.90 -------- QX9650@4199Mhz
    #11 trickson ----- 23.73 ------- Q9650@4005Mhz
    #12 KELL5 ----- 23.51 ---------- Q6600@4095Mhz
    #13 loonym ------- 23.40 ---------- X3360@3993Mhz
    #14 nilo123 ------ 22.86 ---------- Q9650@4049Mhz
    #15 speedfreak86 ------ 22.70 -------- Q6600@4049Mhz
    #16 Severance ------ 22.57 ---------- Q6600@4005Mhz
    #17 chessman --------- 22.50 -------- Qx6700@3806Mhz
    #18 uber-gm ----------- 22.47 ---------- Q9550 @ 3.9GHz
    #19 dengyong --------- 21.64 ------- Q6600@3800Mhz
    #20 eva2000 ------- 21.01 ------- Q6600@3554Mhz
    #21 Toysoldier ------ 20.28 --------- Q6600@3600 MHz
    #22 mAJORD ----------- 20.01 ---------- Phenom II X4 955@3920 Mhz
    #23 Chosen. ------- 19.63 ------ QX6700@3450Mhz
    #24 OgaiB -------- 13.35 ---------- Phenom II 720BE @ 3632MHZ
    #25 firebane -----12.96 -------- E8600 @ 4.6ghz
    #26 <<HANNIBAL>> -- 11.73 --------- E6600@ 3906Mhz
    #27 kiwi ----- 11.07 --------- E6400@3714MHZ
    #28 6e33yMa ---- 11.00 -------- E6400@3776MHz
    #29 Apokalipse ----- 8.25 --------- X2 6000+@3450MHZ
    Please attach a screenshot if you'd like to be added to the list.
    You can also compare your system with a larger database of results over here:
    Fritz 9 Chess Benchmarks
    Edit: Removed Axonbench. Updated List.
