Very nice.
Boot or clockgen'd up?
What memory?
Maybe a 1333 strap on this board..
stuff goes here.. etc etc.. i win.. lalala.. pwn etc
How are you booting at 6x450 when you don't have an X6800?
I have an E6700 ES and the multiplier ratio is greyed out in the BIOS?
Nice, now vmod it @2,3volts, cool it with dry ice, and get to 600 FSB with 975x Nice board you got man!
Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
New P5W DH bios enables lower multi's. Even without that you could lower them with Crystal CPUID.Originally Posted by Durzel
Also, this is not a P5W DH.
That is the board in your sig at least, so I assume you are referring to it.
Where to get ??? Can it be used on the P5WDG2-WS PRO also ???Originally Posted by xpsentity
Yeah but EIST change the multiplier just before Windowns start, so with E6600 and BIOS multiplier 8x400 is in boot before Windows 9x400Originally Posted by xpsentity
- Team Skootterit
- SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
Sorry ignore my sig, it's out of date. I'm running the P5W64-WS Pro now with 0116 BIOS (one it was shipped with) and the multiplier ratio is greyed out in the BIOS like it is on the P5W-DH (at least before the latest beta P5W-DH BIOS).Originally Posted by xpsentity
I already know how to change the multiplier with CrystalCPUID - but it seems if you can get the board (ANY of the boards) to boot with 400+ BIOS then it seems to be using a different strap (1333 instead of 1066). I desperately need to know how the OP managed to change the multiplier to *BOOT* at 6x450.....
Looks like he is using Bios 0209 in the pic.
very promising
congrats
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
Kids
P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
Well spotted! If 0209 unlocks the multi I'm going to be very happy. I can't WAIT to get to work tomorrow that's all I can say! Almost tempted to drive the 5 miles in now to flash it lol, even though its midnight here!Originally Posted by xpsentity
@ Durzel:
Download 0209 bios here.
Yup I posted a link to it earlier.. thanks though Sadly for me I'm at home and my P5W64 is at work on a bench so I can test it allOriginally Posted by xpsentity
DRATS!...wish the P5WDG WS pro had that option!
BIOSTAR TPOWER I45 UNOFFICIAL THREAD
BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
ABIT IP35 PRO HEATPIPE MOD
ABIT IP35 PRO BIOS FLASHING PROCEDURE
IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
How high FSB can you get with the x9 multi ?Originally Posted by webwilli
Q9650 @ 4Ghz - 1.216v
E8600 @ 4500Ghz - 1.34v - Q822A435
Q6600 @ 4014Ghz & E2160 @ 3.6Ghz
Silverstone Zeus 850w, Maximum formula,
Custom Water Cooling, 4GB OCZ 9200 Flex II,
Xfire 4850's 800/1150, 3D Mark 06 , Vantage,
Frontlineforce
Looking at ordering one of these very soon.
P5W64 WS PRO 69M0AG
E6600 B2 - BTT HSF
2x 1GBHZ G.Skill DDR2 serials 0606
2x 1GBHZ G.Skill DDR2 serials 0629
XFX 8800GTX 760mb PCIE
TT Shark Case 2x120mm fans
Enermax Liberty 620watt
Creative X-Fi
2x ASUS DVDWR SATA
WD 320GB SATAII
Seagate 120gb SATAII
WD 200GB SATAII
Seagate 200GB SATAII
@webwilli, m8 i have the 64 pro aswell, dont have the cahnce to try out th\e new bios till tomorrow, can you check if you still have the overvoltage problem?
E6600 L629B
Asus Striker Extreme testing. I hope DFI can make my dreams come true!
CELL SHOCK PC6400
Tuniq tower 120
MSI 7900GTO
OCZ 600W
I wonder if vCore is tied to high FSBs?
Flashed this BIOS, indeed the multiplier is available (I've got 6x - 20x on my E6700 ES), plus a few extra memory options none of which I understand lol... couldn't get it to boot at 6x450 though, just wouldn't switch on - and the next time I powered it on it moaned about "Overclocking failed".
I'd left vCore on AUTO since 6x450 is only 2.7Ghz, but I guess you need to up the vCore as soon as you start beefing the FSB up, regardless of what speed your CPU is running at?
Extra memory settings in the 0209 BIOS (Chipset section) are:
tRAS
RMS
tRFC
tRD
Here's what I've found so far...
I needed to up vCore to 1.4250v in BIOS (1.48v actual in PC Probe) to get PC to POST properly, regardless of multiplier. Overvolting problem is still there. It seems even though I'm underclocking my CPU at 6x405 (2430Mhz), the motherboard behaves - at least at POST - as if its still on default (for me 10x).
Once in Windows I was able to Clockgen the FSB up to 450Mhz. Tried 475Mhz but it locked up. I guess I would need more vCore.
I'm not prepared to stick 1.6v through my CPU at air cooling so I'll resume testing once I've got my Vapo. I suspect the board will hit 500FSB with ease, though if my suspicions are correct I might not be able to boot it at 500FSB because it would be trying to boot at 10x500 (5Ghz) on an E6700.
My board is a retail board bought from a shop, which is totally stock at the moment (haven't even removed the wrapping on the NB cover or changed the TIM)
I could be wrong though....
NIIIICEEE!!! I hope they do the same with p5w bios...
As for the strap, AFAIK, ASUS 975 boards doesnt have 1333 strap, just 1066.
450 no prtoblem with this board. Nice FSB there Durzel
@Webwilli...500 is awesome, good job
