Now, what are you waiting for the true powerful DDRII?...
SO let me tell you this...
This is gonna be the first one to strike truly DDRII 800, 3-3-3-8
2x 1gb DDRII,Micron D9 GMH IC,
This is high bin of high bin MT D9GMH
**Please note: For the sticker showing 3-4-3-8 is because the sticker is not finished while I done for this Stability test;
For the full retail version, it should be correct spec.
retail package:
Testbed:
CPU: E6600 ES B1 S5 1.5v
Mobo: Asus P5WDG2 WS Pro, bios 0004
OS windows 2003 Original
Power: PC P&C 1kw
HD WD Raptor 10k rpm 150g x1
show the vidmm from the meter all set vdimm @ 2.25~2.28v
In the middle of benching:
DDR800 starting
I: DDR 800, 3-3-3-8, dual prime Large FFT after 3 more hours
6 plus hours:
7more hours for completely 2 runs
DDR 800 3-3-3-8 done, now reboot and set proper divider for ddr1000 4-4-3 and go sleep
DDR1000, 4-4-3
testing:
I: DDR 1000 4-4-3-4, dual prime Large FFT running after 6 hours
7 hours
ok...how about some extra super pi 32m ?
505mhz not enough?let 's add more
DDR 1000 4-4-3-4 all done
so what do you feel ?
(All contents are provided and authorized by OPB - 9/11/06)
