Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: Bios 1401 for P5WDH / Bios 0614 for P5B Deluxe WIFI/AP
    Nov 2005
    Germany
    ASUS P5B Deluxe WIFI/AP: 0614
    1 Support DDR2 SO DIMM
    2 Support DDR2 double side X16
    3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
    4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
    5 Support Conroe / Kentsfield ratio overclocking higher than default
    6 Fix CPU Fan Profile mode not correct after system shutdown
    P5W DH: 1401
    1 Fixed EIST select item is disappeared if used Conroe1066 QPHV 2.93G CPU set ratio to 6X issue.
    2 Fixed Kentsfield L2 cache show error issue.
    3 Fixed no detect JMicron HDD in Windows XP install screen.
    4 Fixed cna't enter crashfree screen when interrupt EZ Flash 2 update bios issue
    5 Fixed JMicron JMB36X controller shows with yellow bang in device manager issue
    6 Update new JMicron option from 1.06.52 to 1.06.56a version.
    7 Fixed CPU Vcore show "Auto" issue.
    8 Add CPU "Speedstep" & C1E & "Vcore" note string.
    9 Support FSB overclocking to 550MHz.
    http://www.computerbase.de/forum/sho...d.php?t=224790
    Nov 2005
    Mansfield TX
    Downloaded & intalling. You try it yet?
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
    Nov 2005
    Germany
    yes, i flash from 0609 to 0614
    Attached Images Attached Images
    Git-R-Done
    May 2006
    Toronto, Canada
    My EZ flash doesn't work :/
    Mar 2003
    Don't see any changes... Options the same, OC the same, vcore, vdroop, and temps the same.
    Asus P8P67-M Pro - Bios 413
    i7-2600K LO41C106
    Cooler Master V8 - Antec 180 Mini
    G.SKILL Ripjaws X Series 8GB (2 x 4GB)
    Sissy OC - 4.6 @ 1.3175 24/7 | 18' Idle - 55' Load
    Windows 7 MS Is Getting Better...
    Personal Site!
    Xtreme Cruncher
    Jul 2005
    London - UK
    Hold on a second. If you can set 6x does that mean they added multi support??
    I doubt it but anyone flashed yet. I can't be bothered to be first anymore..
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    Feb 2006
    I'll be flashing when I get home... I'll let you know.
    Leaping Ahead....
    CPU: Intel Core 2 Quad Q6600 @ 3.4 Ghz at 1.35 VCore set in BIOS
    HSF: LAPPED Thermalright Ultra 120 Extreme + 120mm Yate Loon D12SL
    RAM: 4 x 1GB Crucial Ballistix PC6400 963 Mhz @ 4-4-4-12 2.15V
    Mobo: Asus P5K-Deluxe P35
    HD's: 2 x 74GB Raptors in RAID 0 and 2 x 160GB WD Sata II's in RAID 1
    GPU: EVGA 8800GT 512MB Superclocked 720/1860/1980
    Sound: Sound Blaster X-Fi XtremeMusic
    PSU: Corsair HX-620
    Case: CM 690 Loaded with fans but quiet as a mouse.
    Monitor: 22" Samsung 226BW - 2ms of Gaming Joy!
    Apr 2004
    Helsinki / Finland
    1401 is [1101], something new
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
    Mar 2003
    Quote Originally Posted by lawrywild
    Where have you been, there's been multiplier support since 607, maybe even 605....
    Opps! Sorry lawry, was talking 965 not your P5W DH Deluxe...
    i7-2600K LO41C106
    Personal Site!
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by pcdoc1
    Yes, that would be p5b-deluxe not the p5wdh clever dic
    Mar 2003
    Damn, didn't even have time to "Edit"
    Regards-
    i7-2600K LO41C106
    Personal Site!
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    NOPE!! Dammit ASUS!!!
    "You'll find happiness once you accept the inevitable or at least you won't be too pissed off" -- Me
    [SIGPIC][/SIGPIC]
    Xtreme Cruncher
    Jun 2006
    San Jose
    geez why do they keep messing with the Jmicron crap. Who gives a about that! I want some 2.5vmch 2v vcore, all ram tweaking options available, unlock multiplier downward, better ram divider, and for god sake fix that horrible boot lag.
    For all your cooling needs: ShopPTS.com
    System:
    Rampage Formula // E8400 @ 4.0 (1.28v)
    4x 1GB Ballistix Tracer @ 600 (5-5-5-15)
    4x 74GB Raptors 16MB Raid-0 // Samsung F1 1TB
    eVGA 8800GTS 512MB @ 800/1111/2000
    Corsair HX620 // LG246WP
    Cooling:
    D-TEK FuZion // PA120.3 // 3x Yate Loon SH
    MCW60GT // EK Multi-150 // DDC-2 + Petra's Top
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by syne_24
    lol yeh, that's pretty much everything that needs doing summed up..
    Xtreme Cruncher
    Jul 2005
    London - UK
    Regards-
    lol no problem, I'm just joking about
    Aug 2006
    I vouch for that.
    Jan 2005
    Sweden
    I started up the flash utility and halfway throught my computer just died. It booted up okey but with the same bios version as before, but now the bios flash utility cant read my bios rom and I get an error
    This is when trying to flash the 614 bios on the P5B DLX WIFI.
    Gigabyte GA-990FXA-UD3 rev 1,0| AMD FX-8120@?| Corsair H100| 2x4 GB Patriot Viper Xtreme Division 2 PC15000 9-11-9-27| 2*Powercolor Radeon HD6970 2048MB @ Crossfire| 3*NEC MultiSync EA231WMi 23" Monitorer @ Eyefinity| OCZ Vertex 3 60 GB| 2*Intel 80GB X25-M G2 @ RAID0| Cooler Master Silent Pro M1000W| Cooler Master ATCS 840|
  18. #18
    Xtreme Cruncher
    Jul 2005
    London - UK
    Use afudos
  19. #19
    Git-R-Done
    May 2006
    Toronto, Canada
    I want just 1.85vmch! Stupid old board that I bought a week ago!
    Sorry for the noob question, how do I use AFUDOS? I downloaded, and in the cmd prompt couldn't get it to do anything...
  20. #20
    I am Xtreme
    Dec 2002
    Quote Originally Posted by Shpoon
    TBH i would tell you if i knew, but i have to look it up every time i use it - lol.
  21. #21
    Mar 2006
    That's positive, shame my board won't go any higher than 410 1:1 stable.
  22. #22
    Xtreme Cruncher
    Jul 2005
    London - UK
    Read the manual then?
    Code:
    afudos /i***.rom /pbnc /n
  23. #23
    Jan 2005
    Sweden
    Use afudos
    Thanks for the tip, afudos worked great.
  24. #24
    Mar 2005
    Spain
    Mine doesnt lag some revision's ago, it was some kind of magic, it randomly lagged, now it doesnt lag... Im afraid of flashing, maybe it would lag again
    Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
  25. #25
    Jul 2006
    Northern IL.
    YES to that.......and also fix the fuxored AiBooster the hasn't reported correctly since bios 0801!!!
    Core 2 Quad Q6600 G0 L723A930
    3.6GHz 24/7
    ASUS P5K Deluxe Mobo
    Thermalright Ultima-90
    Sapphire HD 2900 XT
    2x1G Mushkin XP2 DDR2 800MHz
    OCZ GameXStream 700W PSU
    Antec 900 Case
    2X WD Raptor
    Vista
