Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Asus P5b Vanilla Stuck @2.6GHz
    Apr 2006
    Exclamation Asus P5b Vanilla Stuck @2.6GHz
    Hi everyone, New to OC. Just Build my first system. I am stuck @2.6GHz (326*8).My pc wouldn't post over 330*8. I guess I am doing something wrong. Please help me out. Thanks.
    Pc #
    Asus P5b Vanilla - Bios 0309
    E6400 @2.6GHz
    2gb CORSAIR XMS2 675
    Thermaltake Big Typhoon with SILVERSTONE FM121 fan
    Tep #
    Idle: AC on 32c / AC off 35c
    Load:Ac on 42c / AC off 45c
    Pictures #
    Apr 2003
    Tallinn, Estonia
    disable spread spectrum, set ram freq to lowest possible (1:1), set C1E support to disabled, set execute disable bit to disabled. and try again.
    also set boot fsb to 334 or higher.
    good luck
    Apr 2006
    Thanks for your reply .. I will try that now .. Thanks again.
    Nov 2004
    Set configure DRAM by speed to Enabled... i could not post high fsb with my p5b deluxe unless i let the board decide the timings.
    | Intel 2500K @ 5GHz | Noctua NH-D14 | Asus P67 Sabertooth | Samsung 2x4GB DDR3 @ 2133 MHz | Crucial M4 256GB | Asus GTX 770 OC | OCZ Fatal1ty 750W | Qnix QX2710
    History: AXP-2400M, AXP-2500M, Core2 E6600 - all minimum 50% overclock
    Apr 2006
    Update:
    Update:
    Thanks guys for your help. Now @2.7ghz stable. I tring to get 2.8Ghz. My Cpu V is 1.45 .. Is it safe? Also, What is the highest safe V I can use? Please let me know. Thanks.
    Cpu Idle : 38c
    Load: 45c
    Xtreme Guru
    Jul 2004
    just out of curiousity, what is the week of that e6400?
    Apr 2006
    Quote Originally Posted by trans am
    I got it two days ago. Is there other way to find out?
    Apr 2003
    Tallinn, Estonia
    stealer, use speedfan or whatever to monitor vcore.
    you'll see that P5B undervolts a lot.
    with that cooling you have - 3.2-3.5ghz prime stable is realistic.
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by stealer
    Look for a number on the cpu or retail box similar to this:
    L626A682
    In this case it's week 26
    L6 "26" A682
    Apr 2006
    Quote Originally Posted by caater
    I wish
    Update:
    2.7Ghz Stable
    338*8
    CPU V : 1.43v
    Mem V : 2.1v
    Tem: AC Off # Idel 38c, Load: 45c
    Is it safe now to up the Cpu V to 1.47-1.5? Can you guys please help me out with MEM Timings? I realy wantto run my E64000 @2.8ghz.
    Update 2:
    2.8Ghz Unstable
    350*8
    CPU V: 1.45v
    Mem V:2.1v
    Tem: Idel 40c, Load 45c
    Failed GO -Sp2004 test under two minutes.
    Apr 2006
    L626A682
    L6 "26" A682
    It is 26
    Xtreme Guru
    Jul 2004
    I wish
    Update:
    2.7Ghz Stable
    338*8
    CPU V : 1.43v
    Mem V : 2.1v
    Update 2:
    2.8Ghz Unstable
    350*8
    CPU V: 1.45v
    Mem V:2.1v
    lets see a cpuz screen for mem timings. then we can help you. You might need to run a divider on the memory at first so you can find your max cpu speed. then do the memory last. you can increase the vcore just keep an eye on the temps.
    Apr 2006
    "You might need to run a divider on the memory at first so you can find your max cpu speed."
    How can Do That? Sorry I am new to OC. Thanks.
    Sep 2006
    Try adjust to 400fsb, most likely you will pass all tests.
    My E6300 under P5B cannot stable in 330-399fsb, but it is extreme stable for 400+ fsb.
    Before going to such hish fsb, remember set ram to 1:1 and probably add a little voltage it it fails.
    Apr 2006
    Quote Originally Posted by happyhehe
    My Pc won't post over 360*8 .. Tried 400*8 same problem. I guess my ram isn't good enough. I tring to make it stable @2.8ghz. can you gues please help me with the mem timings so that I can run at 2.8ghz. thanks.
    Sep 2006
    Oh..I notice that some of your mem-timings are using its default WORNG values.
    Try to use this software in windows environment to see the actual values.
    http://rv.page.cegetel.net.perso.ceg...Set22beta2.zip
    Copy those values to a piece of paper and then set accordingly in bios.
    I think the unstable problem is due to mis-setting of mem.
    You ram is good when compare to mine.
    i am using SyncMax Express DDR2 667.
    The max point it can go is DDR920 4-4-4-12@2.1V .
    It is well behind others report due to the limitation of vdimm
    Apr 2006
    Thanks for the info. I changed my mem values but still unstable @2.8ghz. Go Sp2004 both core failed after 15 sec. I guess I have to stick with 2.7Ghz
  18. #18
    Sep 2006
    I am sorry to hear that.
    I guess there must be someone using the same hardware config as yours.
    They may give you actual solutions to your problem. Good luck!
  19. #19
    May 2006
    This board is cheaper than p5b deluxe around $70 but overclock almost the same with p5b deluxe. I see few people in forum can go up to 500FSB with E6300. I guess your problem is the RAM, the max for Corsair around 1.9v if you go higher than 1.9v it will be crash.
  20. #20
    Jul 2006
    Portugal
    965 chipset dont alow the use of anything less than 1:1, it only lets you use multipliers.
    no way dude if you have a week 26 cpu you have to get it at least to 3.2ghz prime stable.
    be aware of the vdroop because if you set 1.5v in bios , the most likely is that you'l get 1.42v under load.
    set all the memrory timings manually in bios like this ---> 4-4-4-12-4-42-3-10-5-13 it worked for me, before i discovered that timings my rig wouldn't prime for 5 seconds. after that, its hard as a rock.
    try skkiping the range between 330/400 start from 405.
    BTW what program are you using to check temps?? i used a BT here and mine got prerry much warmer than yours. running @ stock now. WC next week
    hope it helps
  21. #21
    Apr 2006
    I believe what is holding you back from your overclock is not being able to up the mch voltage. I know that I cannot boot with mch at stock voltage and I don't have to run near that much vcore thru the cpu.
    P182
    E6400 @ stock
    Asus P5B Deluxe
    8800 GTS 320 mb
    G.skill PC6400 2x2 gigs
    CL x-fi xtreme music
    PCP&C Silencer 750
    3 x 160 gb 16 mb cache WD r.e. hard drives (raid 0)
    Dual Layer burner
    Ultima 90
    Vista 32
    Coming soon: 4x4 or penryn, another 4 gb's of memory, and Vista 64
  22. #22
    May 2006
    Québec, Canada
    It's probably your memory that hold you back a bit.
    Try lowering the Vcore and see if you can get it stable.
    I have an E6600 stuck at 3Ghz because of my OCZ Plat ram that don't want to run 1:1.
    Rig : Core 2 Duo E6600 | Scythe Mine | 2x 1gb OCZ PC2-6400 Platinum XTC | Asus P5B Premium Vista Edition| eVGA 8800GTS 320Mb | 1x Seagate 80gb SATA2 2x 250gb WD SATA2 SE16 Raid0 | SB X-Fi | OCZ GameXstream 600W | Silverstone TJ06 case
  23. #23
    Apr 2006
    Thanks everyone for your kind help. I will try 405*8 now ... Last time I tried 400*8 my post didn't post. I am using Speedfan,Cpuz, Go Sp2004 and super Pi.
    In Speedfan, its says my coreA is 2.7v and coreB3.7 .. how do i find the totall V? Do you guys any other good software to see the totall V? Thanks.
  24. #24
    Apr 2003
    Tallinn, Estonia
    use asus probeII, if i remember correctly, speedfan didnt show cpu voltage with P5B.
    or was it cpu temp? or both
  25. #25
    May 2006
    Québec, Canada
    Speedfan isn't 965P compatible.
