http://p5wdh.de/downloads/asus/bios/p5wdh1305.zip
No release notes...
No release notes...
INTEL
i7 920 @ 4.0GHz (1.327v) | Foxconn Bloodrage | 6GB OCZ @ 1600MHz (8-7-7-24) | 2x BFG 275 OC | X25-M 80GB | 2x WD Raptor 74GB RAID 0 | Corsair 850HW | CoolerMaster Scout
LOL...I'm always at work when a new bios comes out! Someone test & post please!
Core 2 Quad Q6600 G0 L723A930
3.6GHz 24/7
ASUS P5K Deluxe Mobo
Thermalright Ultima-90
Sapphire HD 2900 XT
2x1G Mushkin XP2 DDR2 800MHz
OCZ GameXStream 700W PSU
Antec 900 Case
2X WD Raptor
Vista
It has notices about C1E and the other thing obstructing your ability to raise the vCore. And it makes the in-BIOS flasher lock.lol
Can't report on anything else atm ... I'm having some major difficulties with my setup![]()
t
Downloaded, busy reinstalling windows atm so will test later.
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
those 2 reminders are the only visible diference i could see.
going to OC, to see if there's any substancial diference from the previous bios.
any chance off changing the multipler?
Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
E6850@ 4500
1000w psu/vapo Ls/2x74gb raptor raid.
Jebus, I wish ASUS would spend a few dollars proofing their English copy with someone that actually speaks the language. It appears that they use Google Translate to generate the English copy.
"Enable EIST. You may not adjust Vcore."![]()
Interpreted literally, the lay-user will understand that as two separate statements. One advising that EIST should be enabled. And the other stating that Vcore may not be adjusted.
"You may not adjust Vcore while EIST is enabled."
ASUS: you can have that one for free.![]()
-phil
Intel Core 2 Duo E6600 (week 24 A - lapped) 2.4GHz @ 3GHz (vcore 1.35)
ASUS P5W DH Deluxe 1901 (66MOAG/G0AAY)
Noctua NH-U 12 w/ 2 X Coolermaster 120x120mm
OCZ Platinum XTC PC2-6400 2X1GB - 4-5-4-15 (OCZ2P8002GK)
OCZ ModStream 450w
BFG nVidia GeForce 8800 GTS (320MB)
WD Raptor 74GB
SB X-Fi XtremeMusic
Originally Posted by phile
this is good to hear , tomorw my first of many conroe's comes in a E6600 and next week a E6700 , and within 3 weeks X6800![]()
Whoha!!! Flashing and testing right nowOriginally Posted by DarkSephiroth
| ASUS REII || i7 920 || 6GB G.Skill DDR3 16000 Perfect Storm || Sapphire"VAPOR-X" HD 4890 CF || DELL U2410 ULTRASHARP 24 || Corsair 850HX || Samsung F1 1TB x 4 || Seagate7200.12 1TB x 2 || 3 x OCZ 30GB Vertex @ Raid0 || Pioneer DVR-216D || G15V2 || MX518 | Qpad XT-R || Win 7 |
| Obsidian 800D || HK Rev. 3.0 LT || BP BF AIX58NSE || BP BF MOS AMOS II || BP BF MOS AMOS III || MCP655 + EK X-TOP Rev.2 || EK-Multioption RES 250 Rev.2 || Tygon R3603 || XSPC RX360 + Yate Loon D12SL-12 || BP Compression Fittings 1/2in. || T-Balancer/bigNG |
wtf.. Couldnt you do that before?Originally Posted by DarkSephiroth
Im running disabled and 3-3-2-4 1:1 400FSB with my 0701 bios..
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
w0000000t flashing later!!Originally Posted by DarkSephiroth
Lawry, man, cant you do that on other bios's ???Originally Posted by lawrywild
Damn?
Spectating;
Here don`t worksOriginally Posted by DarkSephiroth
Mine still wont boot over 380.Please tell me what settings i need.I have system in sig except its a E6600 B2 in it now.I have tried up to 1.6V in bios and still no go.Sam with this new bios as the ones b4.Havent tried 0801 though maybe its better or maybe my C2D just plain suck.Its a week 24 btw if thts good or bad....
no mateOriginally Posted by M.Beier
No bios yet has let me boot over 370fsb without enabled spd timings (5-6-6-18)![]()
It's quite a common issue, maybe ram, maybe mobo.. don't really know..
this bios is not official release right ? beta ?
i||uSi0n^
Intel Core 2 Quad Q6600 *G0*
ASUS P5W DH Deluxe
G.Skill 2GBHZ DDR2-800Mhz (Dual Channel)
XFX Nvidia GeForce 8800 GTS 640MB DDR-III XXX Edition
SoundBlaster X-Fi Xtreme Music
Seagate 500GB 7200.10 S-ATA-II 300 NCQ 16 MB Cache
Pioneer DVD-RW DVR-112D
Antec P180 Casing
Zalman CNPS9500 LED
Antec True Power Trio 550W Power Supply
Windows Vista Ultimate Edition 32-Bit
Samsung 206BW 20" Widescreen LCD
No, I use 0701, the bios with bugged 1.7v and the second highest V on vcore is bugged as well![]()
Spectating;
nope, same thing again, need spd timings..![]()
Mine's always posted over 400 manual memory timings with any of the bios versions, so I dunno.
Wait, so it doesn't let you disable SPD?
I also changed my ram from slot 1,3 to 2,4. Try that see if it works![]()
I use 1,3 - but gonna give 2,4 a shot one day, maybe its one of those "voodoo" things that gains more mhz![]()
Spectating;
