Im using a Asus P5WDG2 WS Professional motherboard. and 2 7900gtx video cards in sli mode with the moded driver it works great, every know and then i do see some video drop out while playing oblivion 1/10th of a second black screen then back to normal. i started playing with the following settings in bios and it SEEMS to be making a difference but i was wondering if any of you gurus really knew what these settings do and what they shoud be set at for nvidia cards on a 975 chipset. here are the settings in bios.
Peg Buffer Length: auto, long, short
Link Latency: Auto, slow, normal
Peg Root Control: Auto, Disbable, Enable
Peg Link Mode: Auto, slow, normal, fast, faster
Pci Express Slot Power: Auto, Light, Normal, Heavy, Heavier.
Leaving these settings to auto do NOT seem to be whats best for an Nvidia SLI configuration but i have no imperical evidience to back that up.
Lee
BTW One of these settings seems to have made a big difference in my gpu temps. (for the better im running about 64c not as compared to 74c when everything was set to auto and i ran a 3d mark 06 test after the bios settings change and the difference was 75 points slower.. i believe thats within the margin of error for 3dmark 06 i ran an 11,574.
Thanks Lee
