Results 1 to 12 of 12
Thread: Aaargh!! (Fixed now) :)
Threaded View
    Xtreme Recruit
    Jul 2006
    Edmond, OK USA
    Question Aaargh!! (Fixed now) :)
    Ok, so I get my computer, go to power it up and NOTHING. Press the power button again and nothing. I go to reseat everything and while reseating the 24pin power connector it starts to run for about 2 seconds then shuts off again. Try it about 20 more times nothing, then once again it lights up then goes off.
    It's a Gigabyte DS3, HIS x1900xt, 2 x 250gb 3g/s Seagate, E6600, GSkill DDR2800, etc. with the Black Stacker 830.
    After checking everything I could think of I took it to a computer shop so they could check the powersupply, board, etc since I don't have the stuff here to do it.
    I am thinking it's either the board or possibly the powerswitch on the case.
    after the computer shop tested the PSU it was good, then they tried a few other things, including shorting the connecting pins on the powerswitch from the case to the board. When they did that, it powered right up. So apparently in shipping my power switch got jacked. So they are replacing it in the morning.
    Talk about frustrating.
    If anyone has anything like this or thinks this might be the problem (power switch connector in the case) please let me know.
    I don't think it's the board or else that wouldn't have worked right?
    SEPIUS EXERTUS, SEMPER FIDELIS, FRATER INFINITAS "Often Tested, Always Faithful, Brothers Forever"
