Results 1 to 7 of 7
Thread: PC Mark2004 Problem: Grammar Check failed
    Nov 2003
    europe - germany - cologne
    the benchmark shows no score after it finished
    then i checked the details and it show allways that the grammar check failed.
    any solution for this?
    Sorry for my bad english...
    System1
    System2
    Xtreme Mentor
    Nov 2005
    Devon
    I have same with X2 3800+ @2.3GHz and over. When I decrase cpu to 2.2ghz it is fine with grammar check!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    xtreme energy
    Oct 2004
    Europe, Latvia
    There is a solution, use PCmark05
    This problem is on all dual core cpus
    Xtreme Cruncher
    Apr 2006
    Finland
    With the PRO-version one can get around the bug by running just the grammar test first and then the default test will pass.
    Nov 2003
    sure?
    i have test a pro version from a friend. same result. grammar check failed...
    overclock, default, underclock (!) nothing help.
    so i kick it from my hdd
    System1
    System2
    Xtreme Cruncher
    Apr 2006
    Finland
    Quote Originally Posted by webwilli
    sure?
    Yup, works for me.
    Xtreme Cruncher
    Apr 2006
    Finland
    Quote Originally Posted by mtzki
    Yup, works for me.
    With an X2, but not with Conroes it seems. Can't even get the single-threaded grammar test to pass (E6600/E6700 and P5W DH, win xp). Tried underclocking everything too. Anybody succeeded with this?
