Results 1 to 8 of 8
Thread: sealed box insulation dry-ice run
    Champion
    Jun 2003
    cape town
    Talking sealed box insulation dry-ice run
    Conroe – E6600 2.4ghz
    Asus P5B Deluxe Wi-fi
    2 x 1Gb TeamXtreem ddr2 800
    1 x 7900GT 512mb @ 700/800 – 1.55v (just in case)
    36Gb WD Raptor
    Aopen 700w
    30kg DryIce
    base and air temps
    (air usually at -14' due to fan blowing over a tray of dry-ice inside the box)
    cpu reported -58 in the bios and motherboard -10
    3 hours later
    notice 0 condensation on the board
    not even under the block around the cpu
    some results
    Jul 2003
    Thats a good idea, mix of V-Teks DI air box with CPU tube and no insulation
    XIP
    Nov 2004
    NYC
    Nice run there Flytek
    Just make sure no liquid touch the bare board
    Jan 2005
    belgium
    euhu very good thinking there .
    great work and nice benches
    Aug 2005
    Somewhere on earth between Taipei, Paris and Montreal
    nice work flytek
    Have some pics about your DI Block ?
    Do you use alcohol with DI Pellets ?
    thanks!
    Overclocking-TV Staff
    Quote Originally Posted by hipro5 View Post
    Ha, ha, ha.....NO WAY.....When I show someone preparing to take a shot, I hided the cigarette....
    Jun 2005
    Ozzzy
    are u sponsered by isogenix?
    DFI SLI-DR Expert (12/5/06)
    AMD Opteron 170 (CCB1E 0550 VPMW)
    2 x 1GB Team Xtreem PC4000 Samsung UCCC
    Enermax Liberty 620W
    Sparkle 6800GT 420/1050
    Storm G4 Waterblock, MCW55, MCP655 Pump, Dangerden Asus AN8 Chipset Block
    Radiical Radiator
    LG Burner
    2x Seagate 200GB SATAII HD @ RAID 0
    CM Stacker
    Champion
    Jun 2003
    cape town
    Trouffman - soz no designs for the block but the square base is hollow to the same diameter as the pipe and to about 15mm away from the cpu core.
    and yes we just used two capfulls of acetone with the pellets.
    knob - no we're not sponsered but they will enjoy that picture i'm sure
    Aug 2005
    Ok thanks for those info
