Results 1 to 8 of 8
Thread: Regulating fan speed on P5B Deluxe?
    Jan 2004
    Frankfurt, Germany
    Hey anyone got Speedfan working with a P5B Deluxe. I can see the actual fan speeds but there's no way to set the percentage, these things are just missing. Anyone got a solution?
    Jun 2006
    Disable Q-Fan stuff in the BIOS.
    Jan 2004
    Frankfurt, Germany
    Still doesn't work. Speedfan doesn't show anything to change.
    Jul 2006
    ughh... i dunno how many times ive said this
    fan speeds can only be controlled if 1) it has a 4 pin connector to the mobo or 2) u have a fan controller
    My Rig:
    i7 3770k
    Sabertooth Z77
    MSI GTX680 reference
    2x8gb Mushkin Redline 8-8-8-18 @1600
    Corsair Neutron 256gb
    2x Toshiba 7200rpm 3TB(Raid 0)
    Corsair 600T White
    Corsair HX750
    Asus PCE-AC66
    Hanns-G 27"
    May 2006
    Québec, Canada
    Does SPeedfan detect your CPU temps ? It doesn't on My P5B
    Rig : Core 2 Duo E6600 | Scythe Mine | 2x 1gb OCZ PC2-6400 Platinum XTC | Asus P5B Premium Vista Edition| eVGA 8800GTS 320Mb | 1x Seagate 80gb SATA2 2x 250gb WD SATA2 SE16 Raid0 | SB X-Fi | OCZ GameXstream 600W | Silverstone TJ06 case
    Jan 2004
    Frankfurt, Germany
    Quote Originally Posted by rpg711
    crap board.
    gotta get 2 of them small fan mates then
    Jul 2006
    .ID
    There is no way the current SpeedFan can detect sensor chip in the P5B Deluxe,
    since its using the latest one Winbond W83627DHG, not the common W83627EHG.
    This latest Winbond W83627DHG chip was released just recently at Q1 or Q2 2006 !
    Heck, even Winbond still doesn't want to release the spec or datasheet easily !
    Just wait a little longer, rumours around that it has some hidden "surprises" ..err.. I mean features !
    Jun 2006
    Quote Originally Posted by bing
    Hmm, interesting. Speedfan's lack of support for the P5B is a major reason I am resisting buying this motherboard, since fan control and quiet computing generally are important to me.
    I don't suppose you've heard any 'rumours' about when the new sensor chip might be supported and what level of control Speedfan will have for the P5B: (1) both CPU and chipset temperature readings? (2) all fans connected to motherboard speed monitored and speed controlled via PWM?
    Unless support comes soon I will probably just go with the P5WDH and sacrifice (probably) on the o/c side. I am very curious about these surprises in store that you mention -- I take it from your eliptical remarks that the hidden 'features' will be positive (e.g. more control)?
