Elllo! (forgot an important part of the story)
Spec:
Asus P5B Deluxe Wifi
Intel E6400
Crucial Balistix 6400
X1900XT
500W Mist
Raptor 74G
Well got this new rig yesterday, set it up and installed windows. And no problems whatsoever.
Then I went to a Lan a my friend of mine had and came back a coupple of hours ago today.
Then I booted up again no problems now either.
Then I updated to the 0507 Bios. Still no problems.
Then I began to oc it. Sett the RAM to 2.25V VCore to 1.35V and VNB to 1.45 Vfsb to 1.35. And so on I could overclock to 380Fsb and still run PI 1M but 2M didnt go so I decided to max out V on Vfsb and VNB. Saved Bios and it booted up and finnished 1M nicely then I tried 2M and then a couple of seconds into the instance the computer crashes and turns it self right of. And it does not boot, only flickers in the fans.
Ive tried to take out the battery move the jumper waited some sec and the put it back again (Samething as the Manual says). Still no... Only thing that happens is that the CPU fans move and dies very fast.
I have tried putting the RAM in all places just 1 stick, ive unplugged everything. Still no boot. Ftw is wrong? Did I kill it with VNB?
I am going to try an other PSU and Other RAM, Il look for another 775proc to test with to.
Just tried with another pair of rams Corsair PC5400 and a Intel 641 all of theese components work. Same problem, PSU left.
Just tried woth another PSU. This one is only 20pin 4pin, but it should not be a problem, booted up and then some smoke came from the some fets under the Wifi card.
What are those fets Job?
This board is ready for RMA?
There is a ring around the burnt SMD FET.
Thanks in advance![]()
