Its out guys Official version just posted as an "Update"
ftp://dlsvr03.asus.com/pub/ASUS/mb/s.../P5WDH1101.zip
Lets get some feedback on this one.....![]()
Topboy
Topboy
Description:
EVGA X58 Classified 3, Core i7 980 Extreme(Running Stock ATM), 6GB DDR3 Corsair Dominator GT 2000mhz, 2 x EVGA GTX 580 SC in SLI (Running Stock ATM),
2x WD Cavier Black 640GB Raid 0, Silverstone 1200W PSU,Corsair Obsidian 800d Case, Windows 7 Ultimate 64 Bit.
How is different than the 1101 already out?
Core 2 Quad Q6600 G0 at testing (L724A760)
Asus P5W DH Deluxe
eVGA Geforce 8800 GTX
PC P&C Silencer 750 Quad
2GB OCZ Platinum PC2-8000 EL
Thermaltake Armor
WC: DtekFuzion/ MCW60 / MCR320QP / MCP665
Asus posted 1101 a couple of weeks ago then pulled it and now its back as "Updated". No word on the difference but some users were having issues with the originally posted version before it was pulled.
Topboy
Description:
What site are you going to where it shows it as updated?
I went to the asus global->support and they still have 0801 in the bios download section.
i went to the global site too and clicked on the download link at top. This fired up another browser session where you can search for the type of MB you have. It was under the ALL catagory
Description:
Asus Update is shows the same information as the "old" 1101...![]()
Regards,
Primoz
CPU: Q2C 6600 @ 3712mhz 1.456V
MOBO: DFI LT P35
MEMORY: Gskill F2-6400PHU2-2GBHZ
GPU: ASUS 8800GTS 320mb
PSU: Enermax Infinity 650W
CASE: CM Stacker 01 rev. 2.0 balck
COOLING: MCP355+Alphacool moded TOP, AQ MP-05 SP LE, Cooltech DUAL, EK RES 200
The file on the ftp servers has a date of 8/11.Originally Posted by Primoz78
well im about to try it ou so here goes nothing
Description:
I have downloaded it from the link in the first post...and this are the results...try yourself to be sure...Originally Posted by Plaicd
Regards,
Primoz
MOBO: DFI LT P35
I mean the ftp server shows 8/11.
ftp://dlsvr01.asus.com/pub/ASUS/mb/s...20DH%20Deluxe/
But when you extract it, the rom file shows 8/8.Originally Posted by Plaicd
Core 2 Quad Q6600 G0 L723A930
3.6GHz 24/7
ASUS P5K Deluxe Mobo
Thermalright Ultima-90
Sapphire HD 2900 XT
2x1G Mushkin XP2 DDR2 800MHz
OCZ GameXStream 700W PSU
Antec 900 Case
2X WD Raptor
Vista
Im sure it does.
If it was new bios it would not have been uploaded to the ftp a week ago is all I meant.
No thanks, had enough of that one last time it was out.Originally Posted by topboy
Geezzz... couldn't believe this, don't you guys know how to use file compare ?
Here open a Command Prompt box and type "comp /?" or "fc /?" and do that damn comparison to see any difference between the old & new even its same version.
Some "Extreme Overclockers" huh ?
It would be VERY bad on ASUS' part to release 2 different BIOS versions under the same exact name-regardless of how short the first one was posted or how small the changes are/were.
I doubt it's different. This would be VERY bad revision history practice. Of course it is ASUS after all...
That said though, someone be the guinea pig and try this sucker out!![]()
Hmm.
Well, i've got it on my P5W DH and i'm only seeing 360 FSB on water @ 1.485V
I've tried all the fixes on the Probelms/Fixes thread. I'll have to double check my 6600's stepping when I get back home, or get this stupid attachement ot open. Freakin' work email strips anything useful coming in I swear.
This is a bit OT, but I just got my P5W DH today and there isn't a sticker on the box that tells what bios is loaded. I'm not gonna have my e6600 for another week or so. Is there any way to tell what bios I have? It does say on the label that it supports core2duo end core2extreme. I've just seen other folks in here say that some had stickers that stated what bios was loaded.
Ain't on the box - just on the BIOS chip itself. And it's usually wrong anyway. If it says 0701, you're good for C2D.Originally Posted by Psitech
It's on the bios chip which is located on the lower right hand of the MBOriginally Posted by Psitech
i had better flash to the 'real' 1101 quickly if they pulled the old one
and yes
kind of dumb if they made it look teh same but had 2 versions
thats why you call it '1102'
i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
it's the same bios, the file was never removed from FTP, only on the website
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
OH MY GOD
This is not good
Just updated the bios with this 1 in EZ Flash in the bios.
It erased the bios and when it went to read the floppy bios file it said could not read file. GREAT 3 day old board and a dead mobo.
Im so sick of Asus, ive had nothing but problems with this board since new, and not even overclocked at all. Installed with default settings in bios all safe settings. Still was unstable as hell.
So i have a 60 mile drive tomorrow to take the board back and im changing it for something else.
Please recommend a new motherboard manufacturer for my C2D
Many Thanks in advance
Description:
Ugh, still got the rig on?Originally Posted by topboy
If you didn't rename the rom you need to type afudos /ip5wdh1~1.rom
Because the filename is too long. You should have type "dir" in dos and it would show as p5wdh1~1.rom and you just type that instead.
Anyway.. have you tried the bios recovery tools explained in the manual???
Before the MB bios was wiped, the seting in bios were set to boot from harddisk only.
I was using the EZ Bios update thing in the bios when it did the following.
1. Erased the bios
2. Failed to read floppy drive new bios file.
3. rebooted machine and it does nothing.
4. Inserted Asus CD and it does nothing
Anything else i can do....Thanks for the advice
Description:
have you tried the thing where u're supposed to leave a floppy with the bios file name p5wdh.rom in for 5 minutes????????
This is why I tell people to use afudos![]()
