I’m deciding between buying an Asus P5B or Gigabyte GA 965P-DS3 and wondering if the RAM that is mentioned in the thread title will be compatible with either of these boards. Thanks.
it is working on both motherboard.
i personally tested it and no problem appear
Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
Check out our items on NewEgg
Thanks.
Please, would you announce what chips are on these F2-6400HU2-NR modules?
Well, my Asus P5B Deluxe and 2GBNR isnt working together.![]()
Intel E6600 @ Zalman 9500AT - Hopefully soon some overclocking
Asus P5B Deluxe/wifi
Sapphire Radeon 1900XT @ Vf-900 - 1.2ns memory
G.Skill 2Gb PC6400 HZ
Antec Plusview II
Seasonic S12 500W
Viewsonic 702VA
like? what happened? we test it and it is good on P5B DLXOriginally Posted by tuoho
Really? T_T I bought exactly this ram model, and have not a mobo yet. I casually was thinking in P5B or DS3·it is working on both motherboard.
Can you up CPU-Z screen caps ¡please!?
Thanks.
Pd: DS3 bios version please?
NR doesn't work in my DS3 - as posted here
http://www.xtremesystems.org/forums/...d.php?t=117503
i know. it is weird to me. on my test there is no problem to run
and my kit is just direct pull from the a 1000 of ready to ship kit.
if you can't run it just rma to me and i will return the new one.
GST
