Page 1 of 3 123 LastLast
Results 1 to 25 of 67
Thread: P5W - FSB Wall testing and conclusion
    Feb 2005
    Somerset UK
    FSB WALL TESTING RESULTS AND A CONCLUSION
    I did some work last night regarding FSB wall on this board....
    P5W DH deluxe with Bios 1101
    E6700 OEM Step 6 B2
    2GB OCZ 6400 Plat 4,5,4,15
    Results:
    I have been having real issues at 380FSB and Above. I tried out an E6600 and that worked up to 400FSB, but no higher.
    Another post of the foum put me onto crystal http://crystalmark.info/download/index-e.html which lets you change the multi in windows on this board.
    So I tried the E6700 at 9x and 8x to see what happened.
    The only Bios setting that helped at all was to set the ram to SPD - no voltage changes let me go higher than 379FSB. With SPD on i could do 410FSB before it would go no further. I should point out that SPD sets my ram at 5,6,6,20 - miles out from what it should be.... this got me thinking...
    Next I booted with SPD settings and used memset http://rv.page.cegetel.net.perso.cegetel.net/MemSet.zip to see all the ram settings. I took a screen shot and saved the memset settings.
    Then I rebooted changing back to manual RAM settings in the bios 4,4,5,15
    When in windows I opened memset and changed all the settings apart from 4,4,5,15 to be the same as the screen shot at SPD.
    I was then able to go right up to 440FSB before i suffered any issues.
    Summary:
    1. FSB Wall at 380FSB with manual Ram settings in Bios
    2. FSB Wall at 400FSB with SPD ram settings in Bios
    3. FSB Wall at 440FSB with manual Ram settings in Bios but changed to match SPD in windows with memset.
    Conclusion:
    Asus need to provide access to far more RAM settings in the Bios. This might well be the cause of the FSB wall and would explain why different people get the wall at different points... down to when the RAM fails due to its settings.
    Wonder uis Asus read this forum... maybe a bios with access to all ram and some multi adjustment like the Gigabyte boards would be good.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    interesting got memtest screenies for those 3 scenarios ?
    Feb 2005
    Somerset UK
    Quote Originally Posted by eva2000
    here is the memset (yes i know its the old version) screen shot i took at SPD
    And here are the memory settings when set manually in the bios at 4,5,4,15
    the change i make is to change all settings from tRFC downwards to match the first pic.
    Sometimes the bottom three settings vary on boot without changing anything else. Also slight FSB changes in the bios change the tRFC and down, sometimes dramatically. I did have tRFC at 13 after one boot eeek
    Memory Addict
    Aug 2002
    Brisbane, Australia
    hmmm sounds like maybe tRFC or tRD related.. try only loosening these 2 values and see how far fsb go
    this was all tested with maxed MCH volts right of 1.65v ?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thank you so much seems your findings seem to apply to my Intel D975XBX Badaxe too! i loosened tRFC and tRD from 35/6 to 40/7 and went from 433fsb max fsb to now benching at 440fsb on 1067fsb strap (will try higher later )
    Maybe all motherboard manufacturers need to do is open their bioses to the other memory timing options that memset has available so we can further fine tune how high the fsb can go ?
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    do those two values effect real world memory performance ? or is it one of those settings that really only effects stability ?
    hhmm odd i do not have tRD on my 965 chipset with the memset i use ? hhmm
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Mar 2006
    I would've thought it would have an effect on performance, but apparently memory timings are less relevant to Conroe than they were with other CPUs so I doubt changing those "extra settings" will make a huge difference.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    they do effect super pi times if that's what you mean
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    ok using th elatest memset
    wow my tRFC is 0 by default! maybe that can explain why i can not make my memory run 925+ stable.
    still can not find tRD, hhmm
    *edit*
    nope that dont work lol
    hhmm something odd with this DS3 and ES chip and this Ram
    8x multi 950+mhz 4-5-4-12 ram = 32m stable but can not do 1000
    9x multi 925mhz 4-5-4-12 ram = no good.
    8x multi 950 i think is ok for 4-4-4-12 ill check my screenshots see if it worked.
    so what is the max bootable from the bios you guys can do.? best i can do from my DS3 is 400mhz 1:1 4-4-4-12. w/ 2.0v on ram. have not tried 1.9v 2.1 2.2 2.3 and 2.4v on the ram does not matter.
    infact 2.4v wont even POST.
    hey eva. my HZ's are 0631 these should be D9's yes ? they sure dont act like it. but again. you said before you think maybe my mobo is bad for high dram freq. i believe that is probably correct.
    Heat Ebay Feedback
    Xtreme Guru
    Jan 2005
    waukegan
    do 900 4-4-4-12. that should be stable and still give good b/w. or maybe you can tighten some timings since ram freq would be lower. keep it efficient ya know?
    mobo: strix b350f
    gpu: rx580 1366/2000
    cpu: ryzen 1700 @ 3.8ghz
    ram: 32 gb gskill 2400 @ 3000
    psu: coarsair 1kw
    hdd's: samsung 500gb ssd 1tb & 3tb hdd
    Memory Addict
    Aug 2002
    Brisbane, Australia
    yeah 0631 should be micron d9s mine are 0629s
    i'm trying to tighten the timings down to see how tight i can do at 438-440fsb heh. I noticed one thing if i have memset open there's instability in benching/testing stability. Close memset after making your changes, and more stable
    have you tried remounting chipset heatsink again.. my 1st mount i dropped to max 432mhz 4-4-3-8 at 2.2v on my ram, 2nd remount better contact and manage 488mhz 4-4-3-5 at 2.2v!
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    my chipset never gets above 38c. i have a 40mm fan on it.
    plus this DS3 uses pushpins to hold the chipset in i would have to pull the board out ot do that. and eww alot of work lol.
    900 4-4-4-12 is impossible on 9x multi. its not stable enough i think.
    8x multi yes. but the FSB of 450 is not bootable from the bios.
    this board is quirky for sure. im hoping gigabyte will be able ti fix the little quirks.
    but i am not complaining at all $145 very well spent. i can still overclock higher than i did with 2 different p5w dh boards lol.
    and i can not do tighter @ 800mhz 2.0 2.1 or 2.2v the system wont boot. 4-3-4 or 4-3-3 nothing works.
    Heat Ebay Feedback
    Memory Addict
    Aug 2002
    Brisbane, Australia
    yeah when first got badaxe my PC6400PHU2 HZ wouldn't even boot at 400mhz 4-3-3-12 at 2.2v but after remounting chipset block can do 400mhz 4-3-3-8 at 2.2v now
    Feb 2006
    The Netherlands - Rotterdam
    got the FSB up from 420 tot 433, still need to try the last method of matching de SPD timings using memset. Thanks for this info!
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    was your chipset getting too hot though ? or did you remount it to try and make it run cooler ? meaning, were the temps ok already and you just remounted it just because.?
    i also have a 80mm fan blowing on the ram, and also another blowing on the entire PWM area.
    maybe ill pull it out later and try it. right now i am doing Laundry hehehe.
    Heat Ebay Feedback
    Git-R-Done
    May 2006
    Toronto, Canada
    Interesting...
    So, if you take the SPD settings (other than timings), and tweak the timings (tighten them up) are you still able to acheive this higher FSB, or does it start to fail again?
    Xtreme Legend
    Mar 2006
    France
    ->Lestat:You say that your tRFC is 0,is your others values are correctes?
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Lestat
    my chipset was cool as a cucumber even passively.. but seems remounts or getting the right mount helps as 432mhz to 488mhz is a huge diff!
    Decided to see how far i can tighten the additional timings knowing the effects tRD has on higher fsb.
    Software used: Systool dual 32M Pi tests as 99.99% of time if you can pass dual Systool 32M pi you can pass Super Pi 32M.
    Using the memset values for the following:
    tRFC | tRD | Write to Precharge Command | Write to Read Command | Read-Write Turnaround clocks | Write-Read Turnaround clocks | tRTP
    Managed to pass with following settings:
    • 440fsb = 40 | 7 | 12 | 10 | 8 | 5 | 4
    • 438fsb = 36 | 7 | 12 | 9 | 8 | 5 | 4
    • 438fsb = 35 | 7 | 12 | 10 | 8 | 5 | 4
    • 438fsb = 34 | 7 | 12 | 11 | 8 | 5 | 4
    • 438fsb = 33 | 7 | 12 | 11 | 8 | 5 | 4
    • 438fsb = 32 | 7 | 12 | 11 | 9 | 5 | 4
    • 438fsb = 30 | 7 | 12 | 11 | 9 | 5 | 4
    • 438fsb = 28 | 7 | 12 | 11 | 9 | 5 | 4
    @438fsb = 28 | 7 | 12 | 11 | 9 | 5 | 4
    @438fsb = 36 | 7 | 12 | 9 | 8 | 5 | 4
  19. #19
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    Quote Originally Posted by FELIX
    since i have updated to the new version it does not show 0.
    yeah everything else is ok i think but how can we tell ? ther eisnt anything else that can read the settings is there?
    Felix where is the tRD for the 965 chipset ? or the DS3 mobo ?
    here are some pictures be sure to look at the description for each one.
    PICTURE 3
    Here is my Bios. what do you guys recommend for these settings ? i only ask cuz the names used in the DS3 are different
    PICTURE 1
    this is memset showing the manual settings plus all the other ones
    PICTURE 2
    This is memset showing the settings for AUTO SPD
    Attached Images Attached Images
    Heat Ebay Feedback
  20. #20
    Xtreme Legend
    Mar 2006
    France
    -I don't find tRD in 965 datasheet,it's probably exist,but I don't know where.
    -ACT to ACT delay->Act. to Act. delayed (tRRD)
    -rank Write to Read Delay->Write to Read Delayed
    -Refresh to ACT Delay->Refresh cycle time (tRFC)
  21. #21
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    Felix any chance of giving them proper names so stupid people like me understand what they are lol ?
    Heat Ebay Feedback
  22. #22
    Jun 2006
    so the problem that P5wdh can not do high FSB only because RAM timings stuff?
    if so im sure someday with right bios it will rocks.. LOL
  23. #23
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Cocacola
    if that's the case maybe higher vdimm + higher mch volts = higher fsb too ?
    also would explain why some memory can take your board's max fsb higher than other memory i.e. PC5400UL micron fat body d9s seem to take my fsb higher than the newer micron D9GMH where fsb limit is an issue
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thank you simonmaltby.. you've given me an extra 56-62mhz on my E6600 cpu
    Well so far 3954mhz is max 32M.
    Here's the break down of results for max 32M
    @3898mhz - 9x433fsb max
    with tRD at board default 6
    @3934mhz - 9x437fsb
    @tRD of 7 with tRFC 28 and looser additional timings
    @3934mhz - 9x437fsb
    @tRD of 7 with tRFC 32 and tighter additional timings
    @3954mhz - 9x439fsb
    @tRD of 7 with tRFC 36 and additional timings needed for 439fsb
    Couldn't get 32M @440fsb for now probably more tweaking needed or more vcore/mch volts.
    But here's 8M
    All 32M times run from same session of windows, so probably not optimal for fastest times yet
  25. #25
    Jun 2002
    What speed did you boot at Eva?
    Problems with your OCZ product? Feel free to PM or email me here
