Results 1 to 19 of 19
Thread: 3.4GHz stable Retail E6600/DS3...
    May 2006
    EDIT: Removed "Woohoo" from thread title as I was informed by a certain member that this OC is not "Woohoo" worthy.
    Well, I decided to try 1.6VCore n see what happened.
    It booted into Windows @ 378x9! I had to set VMCH to +1 to get it there.
    I ran Prime for an hour (I closed up all the intake vents first to get things nice and hot inside) and 3DMark05 ran fine too. The CPU tests in 3DMark05 usually bomb n reboot if things aren't stable. It handled it fine! I'm still only 1M Super Pi'ing at 15sec, was hoping 3.4GHz meant 14sec. Oh well.
    The highest the CPU got was 52C and it idles around 34C.
    I'm happy. This is where I wanted to be. 1GHz overclock. I think I'm done OCing.
    For those who are awaiting their E6600/DS3 combo, here are my settings:
    No-Execute Memory Protect = Disabled
    CPU Enhanced Halt (C1E) = Disabled
    CPU Thermal Monitor 2 (TM2) = Disabled
    CPU EIST Function = Disabled
    Virtualization Technology = Disabled
    Legacy USB Storage Detect = Disabled
    CPU Host Frequency (Mhz) = 378
    PCI-E Frequency = AUTO
    System Memory Multiplier = 2.0
    DIMM OverVoltage Control = +3 (2.1V)
    PCI-E Voltage = AUTO
    VMCH = +1
    FSB = AUTO
    CPU Voltage Control = 1.6V
    System:
    Antec P180B
    Antec Trio 550
    Gigabyte GA-965P-DS3 BIOS F4c
    Retail E6600 C2D
    Thermalright Ultra-120
    Whisper copper NB cooler
    2x1GB OCZ Platinum EL PC6400
    eVGA 7900GT KO "AR" @ 575/1540
    Zalman VF-900 GPU cooler
    Vantec IceBerq ramsinks
    X-FI XtremeMusic
    2 WD740ADFD Raptors in RAID0
    1 WD 250GB 16mb SATAII HDD
    2 Samsung DVD-RWs
    ViewSonic VX922
    G3 Laser
    Xtreme Mentor
    May 2005
    San Diego, California
    Congrats
    I'm curious about voltage scaling, how far can you go on stock volts and how many volts does it need for 3.3? Lower clockspeed might be more of a sweetspot.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
    May 2006
    3.3GHz needed only 1.5V and "AUTO" VMCH (for me anyway)
    Also, I just tried 1.6V first, tonight I'll lower it, one step at a time, to see if I can get away with less VCore.
    Jun 2006
    Congrats mate! And what amazing temps you got there! That's where I want to go with my E6600 when I get it.
    PS: What's your cooling solution?
    EDIT: Nevermind, I didn't notice it in your post at first.
    Core i7 4790K // CM Hyper 212+ // Asus Z97-Pro (BIOS v.1304) // GTX 780 DCII
    Corsair XMS3 2x8GB // Intel 335 SSD (240GB) // Corsair HX650W // Lian Li PC-A10
    Dec 2004
    I'm sorry but 3.4GHz with 1.6 volts is pretty bad.
    Mar 2006
    Why is that low overclock worthy of a "woohoo"?
    My 6700 does 3.75 stable, and my 6400 did 3.6 stable with ease...both on air and both lower than 1.6v.
    Better reset those expectations my friend.
    May 2006
    Quote Originally Posted by thegreek
    Tell me about it! If I could get it do it @ 1.325V, I would have!
    I know it won't do it @ 1.55V, I know it will do it @ 1.6V. Tonight I'll find out what I can get away with.
    May 2006
    Quote Originally Posted by Mako88
    Hehe, did you have a retail E6600 on a DS3? Didn't think so.
    I'm not saying this is a record by any means - but it's decent for the retail E6600.
    I will remove the "Woohoo" from the thread title right now. I don't want to cause any problems here.
    May 2006
    Give the guy a break, he had a lot of problems with his E6600/DS3 from what I've read. As far as running on 1.6V 24/7...I guess you'll be the one to tell us how it works out.
    Jun 2006
    so in a situation like this is the processor simply the bottleneck, or is the motherboard preventing the system from going higher? Seems like lots of people are having their RETAIL processors cap out lower, in the 3.4 GHZ range.
    Mine does 3.2 at 1.4375 volts. It won't post at 3.4 and 1.5 volts. Regardless, it's high enough for me.
    Intel i7 2600K @4.??, Asus P67 Pro Mobo
    noctua nd-d14 - Cooler Master HAF 932
    Geforce GTX470 - 16GB Ram G.Skill RIPJAWS
    128GB Crucial Solid state drive, and a few 2TB drives
    60 inch samsung LCD LN60C630
    Lenovo t60p - Core 2 duo T7200
    2GB RAM - 120GB hard drive
    ATI x1400 - fingerprint reader, NMB keyboard, etc.
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    damn you needed 1.6v just for 3.4ghz ? holy crap dude thats horrible.
    its not your fault though thats the retail e6600's
    my Step5 B1 ES does 3.6ghz @ 1.33v and after the droop it is 1.2x
    400mhz fSB auto everything. vcore 1.33
    pci-e freq 100. (not auto, auto is not good you need to manually set 100)
    i sually set 1.35vcore though for 24/7 as i dont need any mysterious reboots. but 1.33 is 100% prime stable.
    change that to 100 or 105 or even 110. leaving it on auto wont give you the best overclocking. as it will float around as you increase the fsb. lock it in at 100mhz where it should be.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    May 2006
    Quote Originally Posted by Lestat
    Man I wish I had an ES proc! Must be nice Lestat
    I will give the PCI-E freq change another shot, but I seem to remember setting it to "100" broke my 3.2GHz OC.
    And yeah, not too happy about the voltage, considering @ 3.2GHz, it only needs 1.45V. I may just continue to run it at 3.2GHz as my "sweet spot," I'm just glad I was able to get the thing stable @ 3.4.
    Oct 2002
    Wisconsin
    I wish I could even get my DS3 and E6400RT to overclock. I runs fine at with memory running at 333mhz. Anything above 1mhz and it will just beep and shut down. I tried several suggestions like disabling certain stuff in the bios but that didn't help. It worked fine with my Presler 920D in overclocking.
    eVga 780i SLI
    E8400@4.2ghz(483x9)@1.44v Cooled by Coolit Elite
    2xXFX Alpha Dog Edition 8800GT's 702/1890/2000 on stock cooling.
    2x1GB OCZ pc8500 4,4,4,12 1T@2.75v
    2xWD 150GB Raptor-X in Raid-0
    PC Power & Cooling 750Watt Quad Silencer
    Creative X-Fi ExtremeMusic
    Samsung 244t 24" Widescreen LCD
    20,001 3DMark06 WinXP SP2
    http://valid.x86-secret.com/show_oc.php?id=302461
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    if 100mhz PCI-e doesnt work try 105 or 101 or 110.
    some boards, and this isnt a DS3 issue, its just random tidbits thru my experiences, some board need 101 to actually lock the pci-e bus.
    typically though, if 1 ds3 need to do that then they all will and mine does need 101 or 105 or anything i lock it at 100 and way i go.
    i can cold boot from 100% stock to 400mhz FSB in one bios reboot.
    i dont need to do short hops or anything. i can make that big leep form 266 to 400 all at once. and it works every single time.
    and its nice having one but the price we paid for them woah... much higher than retail.
    with good ram the board will do 435x9 BUT i have to take a huge leap in vcore.
    going from 3.6ghz to 3.9ghz just 35mhz on the FSB i have to go from 1.33v to 1.5v .
    but the baord gets flakey.
    if i can never ever go over 400 mhz im happy as i can be.
    low volts.... runs cooler, high clocks i mena thats a 1200mhz overclock.
    not too shaby considering im using nothing but generic black label samsung DDR667
    this board is extremely picky about what ram you use. so be aware of that.
    Heat Ebay Feedback
    Aug 2006
    nice Brahmzy. but 1.6Vcore is a kinda high but if you got some decent cooling. go for it lol. and yes lestat its really picky on ram >.> i'm been worrying about the ram i choose when i get the DS3 board. i was planning on getting some DDR2 667 OCZ or Cosrair at 4-4-4-12 running it at 800Mhz or higher. then loosing the timing to 5-5-5-15.. wat do you think? lol
    Nov 2006
    Dude I owned a S3 version of this board and was stuck at 3.15 with a vCore of 1.45 aswell... Now at 3.4vCore of 1.44 I can do EASILY stable 24/7 with the DQ6. Currently testing it at 3.6vCore 1.536 stable will be pushing it some more soon
    Gigabyte DQ6 F3 BiOS || Intel E6600 || 2GB XMS2C4 || Asus 7950GT || 74GB Raptoя || Logitech Z-680 || Lian-Li PC65B
    AquaXtreme MP-05 SP || Swiftech MCW60 || HW Labs Black Ice Pro II || Laing DDC w/ DDCT-01 || Swiftech MCRES-MICRO
    Nov 2006
    Sweden
    I just wonder about those temps. 52C at full load with 1,6 v.
    I have the same CPU, also ultra-120, MB is DS4 and I get 65C with 1,5v.
    This is in core temp. In speedfan I get 10-15C lower. Which software do you use?
    What fan do you have on your ultra 120?
    And when you say VMCH = +1, I guess you mean +0,1, as you do with dimm. Correct?
  18. #18
    Xtreme Mentor
    Jan 2005
    DQ6...425x8=3.4GHz with 1.4V in bios, 1.360V actual. MCH and FSB set to normal. DDR2 voltage set to 2.0V, 4-4-4-12 @ 850MHz.
    Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
  19. #19
    Xtreme Mentor
    Jan 2005
    I keep all these enabled save for EIST, as it disables itself automatically upon overclocking anyways.
