Corsair PC6400C4 1G x 2 run 560 4-4-4-4 vdim 2,55volt using Badaxe i975 vdim mod ! stable with spi 32m : http://valid.x86-secret.com/show_oc?id=110663
Shwooott !!!! That is some nice memory you have
Intel QX8950
Asus P5K3 Deluxe Super WiFi
Cell Shock DDR3 PC3-3049504
2 x 2900XT 2GB Saphire
Antec 350W
Very nice! Something for those with too little budget to afford 6400C3 or 8500C5 but still wanting some good clocking, more affordable Micron D9 based kit and stick with Corsair at the same time. Although 6400C4 probably won't match 6400C3 at CAS3 but might quite likely do about the same at CAS4, give or take...
Thanks for sharing, Hazzan
Thinking of getting some of this for a Giabyte DS4 and a Conroe E6600 will it be a good match?
Silverstone TJ07
i7 920
EVGA X58
Corsair Dominator 6gb 1600GT 2000MHz 8-8-8-20
Thermochill PA120.3
Big NG fan controller
Heat Killer v3 CPU Acetal
EK Full block GPU
ATI 5870
Corsair HX850
1X 1TB Samsung
1X 500GB Seagate
1X Crucial SSD 64GB OS
It should do very well with an E6600 and the DS3.
dam, nice mem yo!
how high it run with CL5?
try with tight timing,its always best for me
Intel Core 2 Duo E6300 6B2
Gigabyte 965P-DS3 f6b
Corsair 5400UL v1.5
Leadtek 7900GT 640/880 daily use
WD Raptor 7400ADFD
I have ordered a 2gb kit of these sticks. I will be using with my P5WDH and E6600. What will they do with 2.40 vdimm? And also is it possible to work 3-3-3-4 at 400mhz?
Asus Rampage II Extreme - Intel Core i7 920 - 3x2 GB Corsair Dominator 1600MHz -1792MB Zotac GTX 295 - 500 GB Seagate 7200.12 - 1 TB Seagate 7200.11 - 500 GB WD Hdd - 16x Nec Sata DVD-RW - 26" Samsung T260 - Logitech Pro Keyboard - G5 Mouse - Razermat Control Pad - Lian-Li V2000 Case - Tagan 700Watt BZ Psu - Logitech Z5500 Speakers
@hazzan
how about 2,75 vdimm hhmmm 600 maybe give it a try man
