Hey everyone! Some of you may remember my quick head pressure testing in this thread a couple of weeks ago... Well, I decided to expand upon it and test more pumps that I happen to have sitting around. Below is the data that I collected--PLEASE make sure to read the notes about the data.
The Data:
MAGII LE: (at 11.98V) ~3psig (6.92' -- 2.11m)
3psig ~= 83.03" water column at 4 deg. C (using the same conversion that Lee at SystemCooling does--1.0" = 0.03613psig)
CSP-MAG: (at 11.98V) ~2.8psig (6.46' -- 1.97m)
2.8psig ~= 77.5" water column at 4 deg. C
AqX 50Z-DC12: (at 11.93V) ~5.2psig (11.99' -- 3.66m)
5.2psig ~= 143.9" water column at 4 deg. C
Laing D5 (Swiftech MCP655): (at 11.89V) ~6psig (13.83' -- 4.22m)
6psig ~= 166" water column at 4 deg. C
Laing DDC+: (at 11.88V) ~8.5psig (19.6' -- 5.98m)
8.5psig ~= 235.26" water column at 4 deg. C
Laing DDC+ w/unmodded Alphacool top: (at 11.87V) ~8.2psig (18.9' -- 5.76m)
8.2psig ~= 226.96" water column at 4 deg. C
Notes:
My results for both the 50Z and CSP-MAG basically match those obtained by Lee over at SystemCooling but, for some reason, the MCP655 I tested [apparently] ended up putting out a lot more head pressure than it was supposed to (based on Swiftech's specs and Lee's testing--1.2psig over Lee's result). Curious, I repeated the test numerous times with two different MCP655's and I came up with the same result every time. One of the MCP655's is new and the other one that I used is from a batch that we received in November of 2005 (it was pulled from the water cooled cardboard box display machine).
So, yeah, aside from the somewhat puzzling data from the D5, everything else seems to be pretty good.
...and here's a quick photo that was taken while testing the CSP-MAG:
Also, incase anyone is wondering and/or confused by all of that extra tubing, I modified one end of my waterblock testing setup to carry out the pump head pressure testing. I used the red-handled shutoff valve, that's in the right half of the photo, to isolate the test-pump from the rest of the loop (this way, I'm only dealing with the pressure gauge).
Thoughts? Comments? Suggestions?
