Results 1 to 3 of 3
Thread: Guide: Use the internals of OcBible!
    May 2005
    With my destiny :)
    Here at Aoaforums I created a thread.
    I do not want to repeat the same posts.
    You can get the most from OcBible.
    Post here questions etc...
    Always there at Aoaforums you can download the dlls etc...
    AMD critical temperature
    This code allows you to run a form like AMD critical temperature estimator.
    Code:
    using System;
    using System.Drawing;
    using System.Collections;
    using System.ComponentModel;
    using System.Windows.Forms;
    using System.Data;
    namespace AMD_critical_temperature
    	public class Form1 : System.Windows.Forms.Form
    		private System.ComponentModel.Container components = null;
    		private Functions OcBible;  // Add reference for Functions.dll
    		public Form1()
    			InitializeComponent();
    			OcBible=new Functions();
    		protected override void Dispose( bool disposing )
    			if( disposing )
    				if (components != null)
    					components.Dispose();
    			base.Dispose( disposing );
    		#region Windows Form Designer generated code
    		private void InitializeComponent()
    			// Form1
    			this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
    			this.ClientSize = new System.Drawing.Size(292, 266);
    			this.Name = "Form1";
    			this.Text = "Form1";
    			this.Load += new System.EventHandler(this.Form1_Load);
    		#endregion
    		[STAThread]
    		static void Main()
    			Application.EnableVisualStyles();
    			Application.Run(new Form1());
    		private void Form1_Load(object sender, System.EventArgs e)
    			double critical_temp=OcBible.AMD_critical_temperature(2200,2180,2150,35,42,48);
    			MessageBox.Show(critical_temp.ToString(System.Globalization.NumberFormatInfo.InvariantInfo) + " Celsius.",
    				"AMD critical temp is",MessageBoxButtons.OK,MessageBoxIcon.Information);
    			this.Close();
    May 2005
    With my destiny :)
    Gauss-Jordan
    This routine uses Gauss-Jordan elimination (full pivoting).
    Here is a C# sample code:
    Code:
    using System;
    using System.Data;
    namespace Gaussian_elimination
    		private Solve Linear_system;   // Add reference for Solve.dll
    		public Form1()
    			Linear_system=new Solve();   // Class initialization
    			if( disposing )
    			// Form1
    			this.ClientSize = new System.Drawing.Size(248, 190);
    		#endregion
    		[STAThread]
    		static void Main()
    			double[] solutions=new double[4];
    			double[,] a=new double[4,5];       // Let's make a 3x3 linear system
    			a[1,1]=10;	a[1,2]=22.5;		a[1,3]=71.25;		a[1,4]=-46.57;
    			a[2,1]=22.5;	a[2,2]=71.25;		a[2,3]=253.125;		a[2,4]=-141.075;
    			a[3,1]=71.25;	a[3,2]=253.125;		a[3,3]=958.3125;	a[3,4]=-487.4925;
    			solutions=Linear_system.Gauss_Jordan(a,3,4,5);
    			if (Linear_system.Gauss_Jordan_solutions() != 0)
    				for (int i=1; i<=3; i++)
    					solutions[i]=Math.Round(solutions[i],5);
    				MessageBox.Show("x1 = " + solutions[1].ToString() + "\nx2 = " + solutions[2].ToString()
    					+ "\nx3 = " + solutions[3].ToString(),"Solutions are");
    			else
    				MessageBox.Show("No solution can be found!","Ill conditioned problem!",
    					MessageBoxButtons.OK,MessageBoxIcon.Error);
    			this.Close();
    May 2005
    With my destiny :)
    SOR w=1.25
    This is an iterative method.
    Code:
    using System;
    using System.Data;
    namespace SOR_positive
    		public Form1()
    			if( disposing )
    			// Form1
    		#endregion
    		[STAThread]
    		static void Main()
    			solutions=Linear_system.SOR(a,3,4,300,5,1.25);
    			if (Linear_system.SOR_solutions() != 0)
    			else  // If method diverges we should know what is going on
    					+ "\nx3 = " + solutions[3].ToString(),"Return values are");
    			this.Close();
