Um, nice SS but what vcore are you using for that 4.2 ghz QX9650 ? 1.425v just for 4.0 ghz seems a bit high unless you're compensating for vdroop without a pencil mod for it...(then who knows what it might be under load...)
And what do you mean, if "someone can help you please?" Is something wrong with your system right now? We can't just tell you what will be a 'stable' system with a screenshot of a successful superpi run...only you can test that (games, 3dmark, prime95, etc). Disable hyperpath3 and dram throttling threshold (whatever that is), and eist and speedstep...then test.
Is your 4 ghz one stable with any lower vcore than 1.424v? And once again, what vcore were you using for the superPI at 4.2 ghz? (i can't believe how many people forget the first question when there is one right under it).
