Results 1 to 24 of 24
Thread: Gigabyte DS3 BIOS Settings Thread with Screen Shots
    Oct 2003
    Durham, NC
    Here are my BIOS settings for the Gigabyte DS3 with BIOS F4a. I couldn't overclock worth a damn until I found this combination. I was stuck at 300 * 7, which was horrible of course. Hopefully this thread can help some people!
    BIOSTAR TP67B+ | RPP 750W
    Core i5-2500K @ 4.7 GHz | TRUE
    256GB Samsung 840 Pro | X-Fi Titanium
    16GB G.Skill Ripjaws X | Sapphire HD 7950 3L
    Aug 2006
    I can raise it to 475 x 7 without any volt mods at all, all normal.
    also for SATA port 0-3, I set it to ENABLED so no big deal I guess
    Oct 2003
    Durham, NC
    Mine needed juice.
    May 2006
    I cannot believe your VCore, I have to do 1.5V just to reach 3.3GHz 367x9! Do you think by overvolting the FSB and VMCH, the VCore doesn't need to be as high?
    Oct 2003
    Durham, NC
    Quote Originally Posted by Brahmzy
    If I use more VCORE or VMEM, my system becomes unstable immediately. I don't think my Scythe Mine is good enough for 1.4V+ VCORE because my CPU does better with less voltage. Also, I have bumped up the MCH, but I also have a 40mm fan blowing on it to help compensate for the extra heat:
    May 2006
    Thanks for the pics...I need to NOT compare your chip to mine. These retail E6600's are completely different when it comes to OCing.
    Xtreme Legend
    Mar 2005
    Australia
    lol my E6300 benches at 3D/SuperPI at 3465MHz with default vcore.......i'm gonna undervolt it to see how low i can go
    wish i had a board that can do 600MHz FSB
    Team.AU
    Got tube?
    GIGABYTE Australia
    May 2006
    helpful guide. Had a little problem getting over 3ghz with the same setup myself, until last night. Might have to try that 40mm fan idea, I could cook bacon on mine
    Apr 2006
    do best buy, radio shack, or those type of places sell 40mm fans? I don't feel like ordering something that small online. Also i don't have a hot glue gun...any other ways to mount it?
    Oct 2003
    Durham, NC
    Quote Originally Posted by BottomsUp
    I turned the fan slightly on an angle and used two screws to mount it. The screws were slightly bigger than the holes on the fan so they provide a stable mount with no wobble. The screws were also big enough to screw snugly into the space between the fins on the heatsink. I screwed both down until the fan was level:
    When I was done, the Scythe Mine would not fit so I bent a few fins up on the Mine to accommodate the 40mm fan.
    Apr 2006
    Quote Originally Posted by aldamon
    any idea how much active cooling on the NB helped your OC?
    Oct 2003
    Durham, NC
    No. Sorry. I put on the fan before installing it for the first time.
    May 2006
    Take it off and try clocking
    Jul 2006
    thats weird. i got the same board but it looks like you got ALOT more options than i do on the overclocking tab
    Aug 2005
    Quote Originally Posted by TravisaKaBiggie
    You have to push Ctrl+F1 in the main BIOS screen to enable the advanced options
    Gigabyte 965P - DS3
    Intel C2D E6400 @ 2.8Ghz
    eVGA 8800GTS @ 675/1025
    G.Skill 2GB DDR2-800
    Ultra XVS 700W
    Creative Audigy 2 ZS
    Oct 2003
    Durham, NC
    Quote Originally Posted by delas52
    Hopefully Gigabyte turns that crap off in a later BIOS. It's pretty annoying!
    Quote Originally Posted by trojan
    Negative I live in NC and it's HOT right now.
    Jul 2006
    Anyone have any good guides for a noobie OCer? I have ds3, e6400, xp-90c +80mm fan, 2gb TeamGroup 667 3-3-3-8, 7900gt card.
    I'm wondering whats the best way for a first timer to go about doing this...ive been researching a bit into ram ocing but im still a noob. I want to get anywhere between 3ghz to 3.4ghz.
    Also if I play around with bios ocing functions and restart i dont want to really wrong the risk of things up enough to mandate cmos reset jumper thanks. Any suggestions?
    nzxt lexa + Corsair HX620W Modular
    Asus P5KE-WIFI with e6400 XP-90c +92mm smart fan + AS5 compound.
    GSKILL DDR2-1000 4GB RAM
    eVGA 8800GT + Viewsonic VX2025wm
    Creative X-fi music logitech G51 5.1
    Seagate Barricuda 320GB 7200.10RPM HD
  18. #18
    Aug 2006
    WOOT thx for the settings - i apprieciate it when i get my DS3 and my E6400 i'll definetly. do something similar and if i get stuck on the bios settings definetly will help - thx so much-- BTW don't delete the hosting picture =P
  19. #19
    May 2006
    As soon as change my VFSB I can't even POST. It HAS to be set to AUTO.
  20. #20
    Aug 2006
    then set it as auto then =P
  21. #21
    Jul 2006
    Can I just ask you guys who are OCing successfully which SATA ports you are using? The orange or the other ones?
  22. #22
    Dec 2005
    Brooklyn, New York
    My E6400BOX is arriving today. I will post my BIOS screenies for those interested after I find my max OC on water. (Shouldn't take long)
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
  23. #23
    Jul 2006
    anyone have any idea of how best to decent oc e6400, ds3, 2gb teamgroup xtreem 667 3-3-3-8. I only been able to get it up to 2.6ghz 8x333fsb, stock volts...Im a noob ocer...so im not really sure what settings work best.
    im trying to learn and all, but searching through the forums here hasn't yielded any helpful results, I have only got minimal info from google, and more so from here
  24. #24
    Nov 2005
    PHX
    Ugh...I've got windows installed, but prime fails quickly. I did a memtest and that failed. Raised the vdimm to 2.0 on this Corsair XMS 2x1024 CL4 and it lit up just as well. The CPU-Z shows SPD @ CL5 and the ram's over a year old. Silly Fry's...maybe PC Club has something better?
