XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking > Xtreme Pi
Reply
Old 08-02-2006, 05:46 AM   #1
Stoolman
Stoolman's Avatar
Need help! Japanese translation for using Eram, copy waza and autogear!
I see all the Japanese benchers are using this software for benching superpi.
Now.... I wonder it anyone can tranlate the buttons, and messages in these programs, and post pictures of the program windows with an english translation of the buttons functions...
This way it is easier for the rest of us mortals to compete
__________________
Cool things in progress...
Stoolman is offline   Reply With Quote
Old 08-03-2006, 02:44 AM   #2
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
I'd love to know how to use Eram and autogear! Maybe one of them will be friendly enough to let us know Copy waza is just transfering a large file (from one partition to another?) and then running.
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 08-03-2006, 02:45 PM   #3
ent
ent's Avatar
Im also really interested in it
__________________
ent is offline   Reply With Quote
Old 08-05-2006, 10:46 PM   #4
bachus_anonym
Corsair Engineering
bachus_anonym's Avatar
Send a message via MSN to bachus_anonym
Kyosen and PRTeamJapan (Fredyama) has already explained it few times, actually...
Eram is basically free RAMDISK software. To install, it you need to right-click on a .INF file (from downloaded package), then from the context menu choose Install and reboot after it's done. After that, you should have RAMDISK installed that can be configured by going to Control Panel and opening it;
Copy-waza is a tweak involving copying a large (e.g. 2GB) file between partitions, right before running SuperPi calculation, like 32M. When I tried it, for some reason it worked only when I did it twice in a row. Say, C:/ is where you have SuperPi installed and F:/ is some other partition, can be a second HDD. First, I copied it from F:/ to C:/ and then again, from C:/ to F:/. Immediately, after it's done Click OK to start e.g. 32M calculation... Result: before vs after;
AutoGear, from what I understand, is a little tool that does pretty much the same thing as manually setting Real-time priority for SuperPi from Task Manager, before running it. So, you can probably skip that.
I have to say, that Copy-waza is an awesome tweak, probably one of the best, if not THE best SPi tweak, at least in my testing... Awesome find and kudos to TeamJapan for that
I will try to dig out those posts by TeamJapan guys for ya...
UPDATE: There, not much about AutoGear, though... But as I mentioned, I think this is not very neccesary...
http://www.xtremesystems.org/forums/...3&postcount=27
http://www.xtremesystems.org/forums/...&postcount=525
http://www.xtremesystems.org/forums/...&postcount=570
__________________
3ch 3x2GB WR - Dominator 2000C7GT @ DDR3-2560 7-8-7-20
bachus_anonym is offline   Reply With Quote
Old 08-06-2006, 09:02 AM   #5
Stoolman
Stoolman's Avatar
Thanks a lot Bachus, now I see...
I will try these tweaks later on tonight...
__________________
Old 08-06-2006, 11:00 AM   #6
ent
ent's Avatar
Thx for explanation Bachus
__________________
Old 08-09-2006, 12:53 AM   #7
fredyama
PRTeamJapan
Thanks so much Michal-san for your thorough explanation of each tweak
It is quite difficult for me to translate in English as I do not know what they are talking about even in Japanese
AutoGear is for real time process as you have indicated.
You can easily set and run PI once you register in there rather going through an usual step.
Anyway, you've got to try them under your own set up to find out your optimal point as always
Cheers
fredyama is offline   Reply With Quote
Old 08-23-2006, 08:38 PM   #8
M.Beier
"HW addict"
M.Beier's Avatar
Send a message via MSN to M.Beier Send a message via Skype™ to M.Beier
... I could hit myself, never used copy-waza
__________________
Competition ranking;
AOCM II 2008: #2(01SE,AM3,8M), AMD-OC 2009 DK: #2(max freq), Gigabyte TweaKING 2009: #4(32M, 01SE)
Highest freq for Ras to CAS; 5(?),7 (1000,1275)
HWB hunt on gfx classics to be initialized soon!
M.Beier is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
