Results 1 to 23 of 23
Thread: Gigabyte 965P DS3 problem
    Mar 2005
    Question Gigabyte 965P DS3 problem
    Hi guys. need your advices.
    On DS3 with retail e6300 , i can't seem to run pass 430 fsb and
    the weirdest thing is this,
    If i put more than 0.1 on the mch, fsb or the vdimm, my board will be very unstable on 430 fsb. especially the vdimm voltage, anything above +0.1v
    it won't even boot at 430. I had tried everything from upping the vcore to the vmch. nothing seems to help.
    thanks.
    May 2006
    Herbert's House in Family Guy
    platform?? RAM, board BIOS version , ....
    E6600 @ 3.6
    IN9 32x MAX
    EVGA 8800Ultra
    750W
    Mar 2005
    ok.
    i am using f2 bios for ds3
    and micron d9.
    thanks
    May 2006
    update to f3 and tell us what happens
    Mar 2005
    hi same problem after flashing to f3 bios
    i realised the problem lies with the vdimm voltage.
    anything above +0.1v it won't be stable above 400 fsb.
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    the reason it wont boot at +0.1 is because +0.1 is only 1.9v
    on auto the motherboard is autodetecting the voltage it needs and it using it.
    when you manually set 0.1 that is kicking it down to only 1.9v and that aint enough for 430mhz FSB.
    it has nothing to do with the FSB you know this right ? it has everything to do with the ram freq.
    +1 = 1.9v
    +2 = 2.0v
    +3 = 2.1v
    +4 = 2.2v
    +5 = 2.3v
    +6 = 2.4v
    adjust your vdimm according to what you need for that ram.
    i dont know much about D9 but if your running the ram at 2.0 divider, that is 1:1 which makes the ram 830mhz you'll need a good 2.1v for that i bet, atleast that much id set 2.2 and see if its ok then drop it down a notch. or even up a notch so you can go higher with the ram divider.
    and when someone asks you what ram your using
    dont say D9 that dont mean anything.
    say what make and model and then add in that its D9 that will help us.
    D9 is voltage hungry so be aware of that.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Dec 2005
    Be carefull with those voltage's, i can get my fsb to 450 by uping the pci-e voltage, the fsb voltage and the g-mch to +0.1, personally i leave the ram alone to sort itself out. Trying dumping a 40mm fan onto your northbridge, threre cheap as chips and should only cost a couple of quid from pc world, that fixed all of my stability issues.
    I7 920 DO 3.3Ghz 1.09V (Still clocking) 3910A313
    TRUE Black 2*Xilence 120 Push Pull
    Gigabyte UD5 F8 Bios
    6GB Patriot Viper 1600 7-7-7-24-1T
    Saphire HD4850
    Enermax Noisetaker 600W
    Coolermaster ATCS 840
    Mar 2005
    yes i get what u mean..but the funny thing is this.
    i can only boot with +0.1v
    anything more than 0.1v it won't boot.
    i try from +0.2v to 0.4v.
    all won't boot..
    that's funny isn't it.
    Jul 2006
    Hi!
    someone have heard about dead DS3?? my was dead out of the box - there is no signal to monitor ... i hear hdd, dvd-dw drive but i cant see anything ...
    i have celeron 326 (new) and 2x1gb 667 (new) - combination with single and dual channel didnt do antything
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    did you clear the cmos already and by that i mean shortin gthe cmos jumper AND removing the battery ?
    also use only stick.
    does the system come on and off over and over or does it just not show any video.
    try this.
    power it on,, if yoiu have no video hit the reset buttin, you will see the cdrom lights blink,, if still nothing do this a few times. or hit the reset buttin about 4 times in a row, dont wait for it to reboot though,, just hit it 1--2--3--4 then see what it does.
    also strip the board .. only cpu, 1 stick of ram and video card.
    if it still wont work...
    this is becoming a habit here,, with these DS3 boards oing to hell.
    i wonder if the 2nd shipment of these boards was bad or something.
    if all else fails return it to whereever you got it for a replacement RMA.
    Heat Ebay Feedback
    Mar 2005
    yea tried all that and even tried a different pair of rams.
    maybe i just gotten a bad overclocker.
    thanks anyway.
    anyway what's the s/n of your board?
    just for reference purposes.
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    its 4am you think im about to go searching for the s/n ??
    hehe just kidding!... but really it is 4am lol.
    whats really screwed up is that htis board doesnt have a bios chip persay.
    i believe the bios i inside the GSATA II chip.
    Heat Ebay Feedback
    Xtreme Legend
    Mar 2005
    Australia
    you RAM could be just hitting the limit
    what RAM is it exactly because i tried D9 RAM that topped out at 330MHz........................................and it absolutely hated anything above +0.1Vdimm
    Team.AU
    Got tube?
    GIGABYTE Australia
    Mar 2005
    This rams have micron D9 modules on it and have been tested up to 2.4 vdimm and have been to the 1000 mhz range(On a Badaxe mobo). Just couldnt figure out why i cant go beyond +0.1 vdimm.Everything else could be adjusted but just could not raise the bloody vdimm.If i raise it to 0.2 volt it crash.
    Banging my head here. Tried almost all the settings nothing works. This is crap.
    Oct 2005
    Have you tried to isolate the problem, by only OCing the RAM?
    This is what I would do, then play around with the settings in the BIOS, and see if I can remedy the issue.
    Jul 2006
    Quote Originally Posted by Lestat
    try this.
    hi!
    i did what you say. Clear_cmos was first thing what i did.
    my dvd drive flashing when i hitting reset button, but still i cant see anything.
    before ds3 i had ultra-d with opteron 144. DS3 was "dead" out of the box, so i dont know nothing about starting OS (XP)
    i have 2 x 1gb 667 GoodRam - single and dual channel tested. mobo, ram and cpu are new, i dont think so that RAM is broken.
    maybe that this celeron 326? or pci-e x16 is broken ? (now i dont have any ald pci card ... )
    Mar 2005
    Tested Ocing the RAMS only. No results same thing did up to 900 Mhz but could not increase the vdimm more than 0.2. What a load of crap here. I am beginning to feel that the gigabyte boards are inconsistant in build.
  18. #18
    May 2006
    Silves
    Quote Originally Posted by logigamer
    hi!
    I doubt your mobo is dead. I had problems with ram also. My Gskill6400HZ just dont boot with the Asus P5B Deluxe and with the Giga DQ6, so i do think the problem is or ram.
  19. #19
    Jul 2006
    Quote Originally Posted by Silves
    oh, You think? hmmm... i must find someone with diferent ddr2 ... all my friends have DDR1 and s754/s939/am2 ... ... its time to meet new friends
  20. #20
    Jul 2006
    borrow the am2 ram its ddr2
  21. #21
    May 2006
    well from what i have seen 460fsb is maximum the retail E6300 can do .. with 7x multi of course... (on air, tower 120)
    that dude did it with DDR2 PC8000 1000Mhz or 500Mhz dram, so ... yeah
    E6600 @ 3.6
    IN9 32x MAX
    EVGA 8800Ultra
    750W
  22. #22
    Mar 2005
    MY rams are the cheap kingston micron D9 rams and have been tested on a badaxe to 1000 mhz 2.4 vdimm. Strange thing is this mobo doesnt like this pair of rams and from what i have seen it favours those xtreem rams, adata and corsair micron rams. Anyway i have nothing more to say and am still stuck.
  23. #23
    Jul 2006
    Portugal
    Quote Originally Posted by cliffy
    thnks cliffy that helps to me (+0.1v vFSB,PCI-E, MCH ):
    E6400@3100mhz@1.36v & Gskill LA PC 4200 @ DDR2-776Mhz CL4-4-4-12 @2.0v
