What are the safe levels for an X2 3800+? Right now I am OCed at 2.2ghz and idle at 34C with a load of 51C at the highest. How much hotter can my CPU get while still being stable?
I try and keep temps <50C personally, but you should be fine for stability up to 60 at least.
MB Reviewer for HWC
Team OCX Bench Team
it's also a good idea to know what motherboard you are using when asking for this kind of information. not all them read the same, and some read way off - like my expert mb.
Desktop
[Asus Rampage III Gene] [i7 920 D0] [12GB OCZ3B2000C9LV6GK] [HIS HD 5970] [SeaSonic X750 Gold ] [Windows 7 (64bit)] [OCZ Vertex 30GB x3 Raid0] [Koolance CPU 360] [XSPC Razer 5970] [TFC 360 rad, D5 w/ Koolance RP-450X2]
HTPC
[Origen AE S10V] [MSI H57M-ED65] [ i5-661 w/ Scythe Big Shuriken] [Kingston HyperX LoVo 4GB ] [ SeaSonic X650 Gold ] [ OCZ Vertex 30GB SSD ] [ SAMSUNG Spinpoint 640GB 7200 RPM 2.5"][Panasonic UJ-225 Blu-ray Slot Burner] [ Ceton InfiniTV4]
My mobo is the Asus A8N-SLI Deluxe. Does it read incorrectly?
I go by the lower temp on thecoolest's CoreTemp program.
AMD X2 3600+ Brisbane @ 3GHz | Biostar T-Force 550 | 2GB Corsair XMS2 6400C4
eVGA 8800GTS @ 640/2080 | Hitachi Deskstar 160GB SATA-II
OCZ GameXStream 700w | Fuji-Plus 19" | NEC 3550a 16x DVD+RW
Whoah...weird. I just tried to OC to 230mhz, but instead of getting me to 2.3ghz, it gave me 1.83ghz. Why?
Wait, did it underclock because the stock voltage isn't enough for 2.3ghz? If so, what is the default voltage for my proc?
gradually increase the HTT when OCing. dont just jump up to some high number. it should show the default voltage in the bios if you changed it or not.
No, in the bios it just says, "Auto" before changing it. And even when going up in 10mhz increments it wont go above 2.2ghz.
stock voltage is "1.30 V/1.35 V"
it might be something else that is causing the problems though. what is your ram and whats it running at? my corsair ram was not at the standard voltage when installed, it was at 1.8 when it needed to be at 2.1 ... or atleast that was the factory standard. it ran at 1.8 fine, but obviously it would have major trouble being overclocked at that low of voltage.
