Results 1 to 4 of 4
Thread: DDR RAM won't work!
Threaded View
    Nov 2005
    DDR RAM won't work!
    can't get ram to work properly.
    can't work with slots:
    dimm 1 & dimm 3
    dimm 2 & dimm 4
    dimm 3 & dimm 4
    works fine at stock but not when oc:
    dimm 1 (one stick of ram)
    dimm 1 & dimm 2 (2 sticks)
    dimm 2 (one stick of ram)
    it's soo weird. after removing the ihs it wont' seem to work. but i'm sure that i didn't damage anything on the chip or scratch any of the capacitors because if i did why would it work with "dimm 1 & dimm 2 (2 sticks)". i think something is up with my dfi motherboard. but i'm not sure what is wrong. doesn't any one have similar issues? let me know.
    thigns i have done:
    clear cmos.
    long cmos clear (8 Hr)
    note: the ram ran stable ibefore
    Processor - Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor
    HSF - ZALMAN 9700 LED 110mm 2 Ball CPU Cooler copper
    MotherBoard - ASUS P5B Deluxe/WiFi-AP LGA 775 Intel P965 Express ATX Intel Motherboard
    Ram - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered Dual Channel Kit System Memory Model F2-6400PHU2-2GBHZ - Retail
    Video Card - XFX PVT80GTHF9 GeForce 8800GTS 640MB GDDR3 PCI Express x16 Video Card
    PwrSupply - Enermax 620W
    Main Harddrive - 250gb
    Slave Drive - [internal] 250gb IDE, [internal] 250gb SATA, [internal] 500gb SATA, [external] 320gb IDE w/ Vantec encloser
    Optical Drives - 2x LITE-ON Black IDE DVD Burner Model SOHW-1693S Black
