Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: [Incompatibility?] Giga DS3 and Gskill HZ PC6400
    Apr 2005
    Portugal (Tuga Powa)
    A fellow of mine tried the mount an Intel 940D in the Gigabyte DS3 and GSkill HZ 2Gb PC6400 (those D9s..). But stranglely doesnt boot at all.
    He had to switch to Gskill NS and then to NR and none of them booted.
    Then he switched to 5400LA so he could boot. anyone had this problem? I am very concerned cause I already bought the Gskill PC6400 and the Giga DS3...
    Testing Rig
    Lian Li PC-S80
    Enermax Liberty 620W
    Asus P5K
    Conroe E6600
    2Gb OCZ PC8500 - @650 Club
    BFG 8800GTS 320Mb
    2xSamsung 80Gb SATA II Raid 0
    1xSeagate 320Gb SATA II 16Mb
    Pioneer DVR 110-D
    Water Cooled (MCP655-Storm-Maze4gpu-BIX-1/2tubing)
    Feb 2006
    Telford,west mids UK
    Mine works fine m8 so no need to worry,same board and ram as yourself.
    Apr 2005
    Great! tkx for feeback. I will not worry then...
    Testing Rig
    Lian Li PC-S80
    Asus P5K
    Conroe E6600
    BFG 8800GTS 320Mb
    Pioneer DVR 110-D
    Jan 2004
    Ashford UK
    Quote Originally Posted by MonkSP
    I would my 2gig of G.Skill ZX wont boot in it either!
    May 2006
    Silves
    Mine also wont boot. I have 1gb of Gskill 6400HZ and its a no boot on Asus P5B Deluxe and on Gigabyte DQ6.
    Jun 2006
    BIOS flash?
    Jan 2004
    Ashford UK
    Quote Originally Posted by vudoodoodoo
    BIOS flash?
    Dident make any difference to me,if I put a cheap stick of ddr2 in it set the volts to +3 it will boot,take the cheap stick out,and it fails again,great
    Jun 2006
    Arizona
    @All:
    We have G.Skill people here.
    stuff goes here.. etc etc.. i win.. lalala.. pwn etc
    Apr 2005
    So it's really true about some mems not booting with DS3. Anyone tried to flash bios?
    Testing Rig
    Lian Li PC-S80
    Asus P5K
    Conroe E6600
    BFG 8800GTS 320Mb
    Pioneer DVR 110-D
    Nov 2005
    Germany
    i hear about some problems with elpida chips and 965p chipset, and the
    G.Skill ZX kits have Elpida chips?!
    btw, i am waiting on my DS3 and 2GBHZ Kit
    May 2006
    Quote Originally Posted by Chri$ch
    i heard this as well, hopefully a bios update of some sort could fix the issue
    Intel Core 2 Duo E6600 @ 3200mhz 1.4v // Asus P5W DH Deluxe // eVGA Geforce 7950GX2 // 2GB Corsair XMS2-6400C4 @ 441mhz 4-4-4-12 // X-Fi XtremeMusic // 2 x 150GB Raptors (Raid-0) // 2 x 750GB Cuda's (Raid-1) // OCZ GameXStream 700watt
    Jun 2006
    I got my 2x512 hz g.skill micon d9 today... unfortunately I wont get my conroe and ds3 until august, but I hope they will work fine.
    May 2006
    Herbert's House in Family Guy
    OCZ PC6400 works
    also Corsair PC6400 and Corsair 8000UL works
    Patriot PC7200 wont work
    E6600 @ 3.6
    IN9 32x MAX
    EVGA 8800Ultra
    750W
    Dec 2005
    Brooklyn, New York
    Quote Originally Posted by theteamaqua
    OCZ PC6400 works
    Thanks for verifying that. My 8000UL will be very happy. Well, maybe not that happy with the measly 2.5v this mobo allows (or is it 2.45v?)
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    Sep 2002
    Sydney, Australia
    Quote Originally Posted by thunderstruck!
    2.4v only
    my 5400UL work fine
    Rehabilitation for memory addicts
    Intel Core 2 Duo E6300 ES | Gigabyte GA-965P-DS3 | Thermalright XP90C | 2 x 512MB Corsair XMS5400UL | 256MB GeCube x1800xl
    G.Skill USA Tech
    Sep 2005
    We found the problem. It is causing by the Gigabyte bios auto detection. It boots DDR800 CL4 ram up with CL3. There is no way to boot CL3 up at DDR2 800 and also with 1.8v.
    If you have ram that using CL5, I would suggest use that to boot up the motherboard and set your bios at CL4 on DDR2 800. Save the bios and swap to 2GBZX. That will solve the problem. However, this problem is actually causing by Gigabyte bios not the
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Jun 2006
    OCZ PC6400 works
    How about Patriot PC5300?? Any testing on that?
    Conroe Q6600 G0 w/Tuniq Tower at 3.6ghz 1.45vCore 401FSB
    Gigabyte P35-DS3R
    2 GB Patriot DDR2 800 @ DDR2-1000 2.3V
    Thermaltake Armor Full Tower
    OCZ Gamestream 600W
    46" Samsung LCD 4665F
    8800GTS
    Logitech LX710 Wireless Keyboard/Mouse
    Seagate Barracuda 320gb and 500 gb
    1 TB WD+Maxtor
  18. #18
    Xtreme Mentor
    Jan 2005
    Quote Originally Posted by G.S Technician
    So basically my Gigabyte GA-965P-DQ6 and this memory won't work??
    http://www.newegg.com/Product/Produc...82E16820231073
    2GB ZX kit with 0605 batch, will G.SKILL help resolve the problem and consult with Gigabyte on a bios update?
    What can i do?...if i can't boot with the memory and can't flash bios and don't have any other DDR2 modules...what can i do?
    Can i swap my unused ZX kit with another set?
  19. #19
    Xtreme Cruncher
    Apr 2005
    ya, newegg doesnt charge restocking fee with unopened box rma. I suggest getting the team memory from tankguys.com instead (check bandwidth forum).
    Quote Originally Posted by Richard Dower
  20. #20
    Jul 2006
    Go buy some ram at best buy, use it to post and change the ram setting so that hopefully the G.Skill ram will post now, and then return the other ram to best buy.
  21. #21
    Nov 2005
    Does this problem only affect the DS3? What about the DS4 and DQ6?
  22. #22
    G.Skill USA Tech
    Sep 2005
    Well if Gigabyte is not going to fix it, then all of the ram with SPD 400 CL4 will not boot up. Currently we don’t know when does Gigabyte going to fix it. However I believe they will fix it soon. Since there are a lot of DDR2 800 CL4 memory. We are going to change SPD to CL5 at 800. that will solve the problem too but user need to adjust the timing by themselves.
  23. #23
    Nov 2005
    I think most people buying g.skill know to set their own timings anyway so a wise move.
    I hope my 6400 HZ boots up on my new DQ6, i dont have any other DDR2.
  24. #24
    G.Skill USA Tech
    Sep 2005
    Quote Originally Posted by Scarlet Infidel
    CL3 1.8v for 90% of MT chip is no problem to boot up. however we did find some MT chip for 800 2GBHZ can't not boot.
    it is mistake by Gigabyte.... so our SPD can't not burn as 400 CL4...
    we are going to change CL5...... no good cuz there will be a lot of user misunderstand about the CAS when they read the SPD
    like what happened to DDR500 2GBHZ 3-5-5-10
  25. #25
    Xtreme Mentor
    Jan 2005
    Could users please report their experience of using G.SKILL DDRII 800 memory with the Gigabyte 965P motherboards.
    If you don't have a spare DDR2 module you are in trouble!...it won't boot and you can't flash to a later bios.
    Maybe G.SKILL could repragram the SPD for it to have a CL5 value?
