Results 1 to 1 of 1
Thread: Using the 7950 GX2
Threaded View
    Oct 2004
    Old Vizima
    Using the 7950 GX2
    If you find the 7950 GX2 is not working in your motherboard do check the following:
    Multi-GPU mode on. (Click the images twice, once to load and once to enlarge)
    Hardware acceleration- single display performance mode, Multi-gpu performance- auto select.
    Set your desired detail settings and filtering on a global scale. Leave application profiles alone. Leave SLi settings alone.
    IMO experience with the current driver changing applications on a per application basis breaks proper multi-gpu function. I had to install the driver again when I changed my Oblivion application profile directly.
    A list of tested motherboards below:
    http://www.nvidia.com/content/geforce_gx2_sbios/us.asp
    The general 7950 GX2 FAQ below:
    http://www.nvidia.com/page/7950_faq.html
    Just because nVidia hasn't tested your motherboard yet does not mean the 7950 GX2 will not work in it. There are plenty of examples around these very forums. If your motherboard is on the tested list update the BIOS to the tested version.
    A good place for general advice:
    http://www.nvnews.net/vbulletin/
