Hiding from the cops and people I ripped off
Figured Out How To Read Temps In Fedora
Hey guys I figured out how to finally read my cpu temps in linux... Here are some links in case anyone wants to do this as well.
1) DL GKrellM then unzip to your desktop.
2) Open a terminal-
a) Application
b) Accessories
c) Terminal
3) Type yum install gkrellm (this will do all the work for you)
4) Then you need 2 more files
a) i2c-2.10.0 then unzip to your desktop
b) lm_sensors-2.10.0 then unzip to your desktop
5) Now configure your sensors
a) open terminal
b) type sudo /usr/sbin/sensors-detect (I just said yes to everything but had a problem on next boot and dont know if it was from the yum update I did) What I would do is say yes to them all and if it gives a problem on next boot just hit any key when the Fedora screen comes up. If it shows 2 Fedora installs choose the second one. But, I think this was me not the sensor config.
6) With a fresh reboot open another terminal and just type gkrellm and it will run. I have not figured out how to keep the prog running without the terminal open but for now just minimize it.
7) Configre your sensors by right clicking on the top of gkrellm.
a) Choose configuration
b) Click on builtins (arrow on left opens the drop down)
c) Click sensors
d) Click the arrow next to temps and choose all three check boxes and click ok.
You should see your cpu, system and mobo temps now in the GKrellM program. If anyone needs any help just post or pm me. But, know I am a huge Linux n00b
Here is a pic of my desktop so you can kinda see my GKrellM config.
- You may not post replies
- You may not edit your posts
Forum Rules
