Results 1 to 25 of 36
Thread: took off the lid, IHS gone but cpu gone too?
Threaded View
    Nov 2005
    finally took off my ihs. but when i put it back into the socket, i can't get it to boot on. the dfi mobo has 3 red lights. seems liek the cpu nis not being detected. so i tried to put the ihs back on without gluing it and put thermal paste and heatsink on top. still doesn't boot up.
    is it dead?
    any other way i can try before i confirm it's dead?
    i don't see any cracks on the core at all.
    i reseated the heatsink twice before i tried putting the ihs in between to bootup
    edited! 7.22
    found out the problem. i can't seem to boot with 2 rams sticks in the slot. if i only boot with one. it works perfectly fine. but i want to be able to run both my sticks. HELP
    Attached Images Attached Images
    Processor - Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor
    HSF - ZALMAN 9700 LED 110mm 2 Ball CPU Cooler copper
    MotherBoard - ASUS P5B Deluxe/WiFi-AP LGA 775 Intel P965 Express ATX Intel Motherboard
    Ram - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered Dual Channel Kit System Memory Model F2-6400PHU2-2GBHZ - Retail
    Video Card - XFX PVT80GTHF9 GeForce 8800GTS 640MB GDDR3 PCI Express x16 Video Card
    PwrSupply - Enermax 620W
    Main Harddrive - 250gb
    Slave Drive - [internal] 250gb IDE, [internal] 250gb SATA, [internal] 500gb SATA, [external] 320gb IDE w/ Vantec encloser
    Optical Drives - 2x LITE-ON Black IDE DVD Burner Model SOHW-1693S Black
