Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: watercooled retail X6800 on ASUS P5W-DH
    Mar 2006
    GA
    Here are my results so far. Keep in mind that this is meant to be a 24/7 rig along the line of mdzcpa's build.
    The system configuration:
    Retail X6800
    P5W-DH Deluxe BIOS version 0701
    X1900XT and X1900XTX in Crossfire mode and watercooled in seperate loop
    2 Raptor 150 hard drives in raid 0
    X-Fi Platinum sound
    PC Power and Cooling 1000 watt psu
    OCZ PC2 8000 memory
    The waterblock on the cpu is the Swiftech Storm.
    More to come....
    May 2004
    Quote Originally Posted by thunderstruck!
    1. Run 2x prime95. You have 2x cores.
    2. Vcore set in bios?
    3. Max?
    he is running dual prime.
    Mar 2006
    GA
    Vcore in the bios is set to 1.475.
    Jun 2003
    What voltage is the chipset at?
    Is x13 the default multiplier for that cpu?
    INTEL inside
    Oct 2004
    Québec, Canada
    can't see your pic
    retired computer enthusiast
    Banned
    Sep 2005
    East Coast USA
    wow a whole 8 minutes................good luck
    Sep 2005
    Denton, TX
    ouch 49c with a storm... Tried any max clocks with stock volts? Maybe try 9x and 10x multi. Kind of give us an idea about the retail 66 & 67
    Current 24/7 settings
    Delidded L628B e6400@ 3.6ghz 1.38v
    3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
    Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
    x1900xt 690/780
    Mar 2006
    GA
    Quote Originally Posted by Plaicd
    Chipset voltage is at 1.55.
    Default multiplier for this cpu is 11.
    Jun 2003
    Portugal!
    should you be lowering the multi (since it unlock) and raising de fsb like 400*9 or something like that?
    GAME-AMD x6 1055T|ASUS M4A870TD|8GB DDR3|HD5858|SSD RAID0|Seasonic!700w
    VMWARE-E6420|Asus P5Q-VM|4GB|320GB|BEQUIET!600w|
    NAS-Via 1.5 GHz ITX|Dual Gigabit|1gb ddr|2*3TB WD
    MbP 13"|C2D 2.53GHz|4gb DDR3
    Barton 2600+@2800mhz SuperPI 37s Sempron 2800+@2665mhz SuperPI 35,5s OLD SCHOOl
    -Apple Iphone 3g |X10 mini Pro 2.2.1|Nintendo WII|PS3 Slim
    Mar 2005
    you should go for a max and tell us
    Cooler Master Cosmos S
    Corsiar HX650
    Asus P7P55D-E
    Intel i7 870 (ES)
    4GB G.Skill Ripjaws 12800CL7D
    Intel 160GB SSD
    EVGA 8800 GTX
    Mar 2006
    GA
    Quote Originally Posted by Pied
    I will try lowering the multiplier for max FSB.
    I am Xtreme
    Aug 2003
    Ouchies hot Do you think you can try single 1m max clock?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Dec 2005
    NYC
    That's a respectable overclock!
    I pumped through an extra 700MHz from my intel as well
    Jun 2006
    so did i.
    Processor: Intel Core 2 Quad Q6600 G0 2.4@3.33 Ghz (1.28 vcore under load) with Arctic Cooling Freezer 7 Pro
    Videocard: BFG GTX 260 w/ Dell SP2309W
    Mainboard: Asus P5Q-E Pro w/ Antec TruePower 2.0 550 SLI-Ready in Antec 900
    Memory: 4GB @ DDR2-740.
    Speakers/Sound card: Logitech Z-2300 w/ Creative Labs X-Fi Xtreme Music
    Harddrives: RAID0 with 2 x 500GB Seagate Barracudas SATAII
    Jul 2006
    lookls pretty good
    what kinda wc is it, i know your using the storm but what about other patrs
    Apr 2006
    Italy
    mmm...49°...someone that has a b1 chip could please tell if b1 are as hot as b2 or there are some differences?thanks
    Fabio
    ps happy to receive a b1 step..i don't like this new revision
    i prefer to see 5ghz on my chip
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Mar 2006
    GA
    Quote Originally Posted by Gun_Strife
    lookls pretty good
    I'm using an MCP655 waterpump, Thermochill PA120 radiator mounted externally with a radbox, and a second Swiftech single 120mm fan radiator mounted inside my case.
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    i say temps are normal here's my E6600 on Badaxe at 3600mhz at 1.371v Swiftech G4 Storm with Thermochill 120.3 and MCP650
    Room temp = 23-25C
    Interesting the temps are a bit off for me by 4C between Intel DCC vs Coretemp
    Intel DCC shows actual bios option values you set for vcore, vdimm, mch, fsb etc not the actual readings. For example 1.4v vcore in Intel DCC = 1.371v vcore reading in bios.
    Load temps dual stressprime
  19. #19
    Nov 2005
    London UK
    Damn these retail chips are hotter than a $2 pistol.
    New! Rev 6 step B2, now with added Prescott!
  20. #20
    INTEL inside
    Oct 2004
    Québec, Canada
    my B1 is hot as hell too
  21. #21
    Mar 2006
    GA
    Quote Originally Posted by eva2000
    Room temp = 23-25C
    Thanks for the confirmation of these temperatures eva2000. I was beginning to worry based upon the reaction to these temps from some of the guys around here. I will try to reach 4 ghz with a multiplier of 15 today just to see what kind of temps this produces. I'm not having any luck raising the FSB to near 400 while lowering the multi to 9 0r 10
    Here's a pic of my setup:
  22. #22
    Nov 2005
    London UK
    Quote Originally Posted by Supertim0r
    Anyone got any phase results on the retails? note to self: Must order a 775 clamshell kit.
    Looks like plan A to stick a 6700 under Vapo LS is looking essential.
  23. #23
    The only ORB-Owning Camel On XS
    Mar 2004
    Ohio
    should have a retail 6800 (egg) under a Storm G5 tonight...
    id assume ill have it under the Chilly1 SS within the week
    and hope to do a D-Ice run not too far behind that
    wonder how the IHS's are on these...dont really want to lap the stepping off but will if i have to
    after enjoying Yonah temps for a while there its sad to see these "Press-HOT-esk" temps return
    JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
    6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe -
    - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master -
    - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU
    - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
  24. #24
    May 2006
    Room temp = 23-25C
    IPB IMAGE
    IPB IMAGE
    How are people getting such high OCs on air when this thing is blazing hot on a water setup like yours?
  25. #25
    Nov 2005
    London UK
    Quote Originally Posted by BWR
    high OCs on air = the better Rev 5 step B1 ES chips
    hot = X6800 retail (Rev 6 step B2) so far.
    It was only a fix for RAID5 afaik, but it seems to have hamstrung these chips quite a bit.
    More data still desired.
