Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: p5wdh vs d975xbx vs dq6 32M super comparison
    X.I.P
    Mar 2005
    those mobos are stock. no vmod at all
    lets some pictures of mobos
    DQ6
    DQ6 PIC NO2
    DQ6 PIC NO3
    DQ6 PIC NO4
    D975XBX
    D975XBX PIC NO2
    D975XBX PIC NO3
    D975XBX PIC NO4
    P5WDH
    P5WDH PIC NO2
    P5WDH PIC NO3
    1ST, P5WDH... BOOT UP AT FSB434.
    E6600 1.57v
    800 2GBHZ 2.4v
    0088 bios
    MCH 1.6v
    FSB 1.2v
    2nd, DQ6... MAX BOOT UP AT FSB400~409.
    E6600 1.57v
    800 2GBHZ 2.35v
    F2 bios
    MCH 1.2v (NORMAL)
    FSB 1v (NORMAL)
    using giga's software to reach 434, it will not boot from bios with FSB over 405 (in my case, i did 416 boot up once but it is not easy, only 400 is ok)
    *****UPDATE*****
    with V-MCH +0.2v, now i can boot up at FSB 433.... however, once turn off the power it will not boot up again!!
    the result with FSB 433 and 1:1 same as P5WDH 3-4-3.
    32M is MUCH slower!
    still testing 304 mobo
    P5WDG
    pro:
    1. High FSB boot up! no one is going to use soft FSB set everyday!
    2. easy recovery if fail to post, 2nd post will use default setting and previous bios options saved
    3. CF
    con:
    1. High FSB over 350 can't use DDR2 1000+ option. some ram's hidding timing are not currect and result is fail to post
    2. 975 MCH requires higher voltage
    DQ6
    pro:
    1. a lot of bios options and fsb up to 600, vcore, vdimm
    2. MCH for 965 is better than 975, with normal 1.2v i can boot up to 400
    con:
    1. memory divider has same problem with 975, with high FSB can use DDR2 1000+ option... some hideing timing is not currect
    2. too many bios options are NOT working, like say 1.6v+ vcore just won't boot!!!!!!
    3. very bad bad bad bios design! you can't change all setting at once, you need to change one option, save, boot up ,change one option, save, boot up again and repeating until everything is done.... this is soooooo gay
    4. no program available for soft ram timing adjust
    5. not support 7950, CF. nor SLi
    6. back plat is not good if you wanna use TQ120!!!!!!
    7. too many... not worse to buy one....
    Git-R-Done
    May 2006
    Toronto, Canada
    *forum. :p
    Thanks for this man, subscribed for sure, will be nice. Too bad no DFI though.
    If you want, PM me, I'll delete this post (if you want a straight run).
    X.I.P
    Mar 2005
    ops.... muhahhahahaah ok forum
    Xτræmε ÇruñcheΓ
    Jul 2005
    Molvanîa
    i wish this existed yesterday but i just hope it comes out in my (asus's) favor
    i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
    Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
    Apr 2005
    Looking forward to this Denny.
    Jan 2005
    Canada, Québec
    Great! Looking especially for the DQ6................can't wait for results!
    May 2004
    ILLinois
    Just in time before new board.
    INTEL inside
    Oct 2004
    Québec, Canada
    nice !!! subscribed
    retired computer enthusiast
    Dec 2004
    California,USA
    Ditto...subscribed...This would be very interesting to know the outcome...
    "It's not what you are called....It's what you answer to"
    X.I.P
    Mar 2005
    *****updated DQ6, please check 1st post*****
    Xtreme Legend
    Dec 2003
    Northern California
    Judging by the timings, you were running the Asus board 1:1. But the Gigabyte board was at 4:5. Wouldn't it be better to test both with same ratio.
    X.I.P
    Mar 2005
    Quote Originally Posted by sierra_bound
    can't boot
    i am using bootable seting 1st!
    Xtreme Legend
    Dec 2003
    Northern California
    Okay, that's what I thought. So the Gigabyte board won't boot at 434 1:1. Nice memory speed on the DQ6. But it's still more than 30 seconds slower in 32M.
    Thanks for doing the comparison test. I'm sure it will help members.
    X.I.P
    Mar 2005
    434 1:1 won't boot
    anything over 400 basically no boot at all
    btw i use AUTO timing for DQ6, if i mannally set in to 4-4-3 or 4-4-4 it just no boot at all
    if p5wdh with 4:5 won't boot...
    every mobo has its weak part......
    Mar 2004
    Did you gain anything on lapping the CPU?
    Intel FTW!
    Beanna
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by guess2098
    434 1:1 won't boot
    I can run P5W DH at 4:5 with memory up to around 480, but that's it. I think it needs voltage mod to run higher at 4:5.
    Thanks again for the info.
    X.I.P
    Mar 2005
    yeah! see high FSB over 1000+ will not boot
    basically is the timing problem, becasue with low FSB such as 333 with DDR2 1066 just no problem at all...
  18. #18
    INTEL inside
    Oct 2004
    Québec, Canada
    If they could allow higher vdimm and most of all, higher fsb from the bios on the bad axe !
    4 bad axe I tested all did 3.95ghz 32m (stock board except short oc debug)
    Is it possible for you to monitor your temp with the bad axe using coretemp during 32m ?
  19. #19
    X.I.P
    Mar 2005
    Quote Originally Posted by Supertim0r
    tomorrow i am going to post the 304.. just too laze today...
    304 can't do over DDR2 1000 to boot... same problem with p5wdh.....
    basically is the timing clock delay vs FSB
    with the hidding timing, it can do 333 or 350 with DDR2 1000+ but if over this... damn the delay is too short and mobo just no post!
    that is why many ppl use 304 1066 and can not use 4:5 over DDR2 1000, but 499 is 32M stable
  20. #20
    X.I.P
    Mar 2005
    just wanna clear up, DQ6 can do 1:1 CL3 with 400 boot up but it can't reach 434 CL3-4-3 stable pass 32M
    some timing need to adjust but there is no program to do so.
    from 400 to 434 soft oc you need to adjust the ram timing for sure
    but in this case I can't do it, that is why i use 4:5 instead of 1:1
  21. #21
    Jul 2005
    ATX
    awesome comparisons, thanks for the results guess!
  22. #22
    Feb 2005
    Italy
    awesome man, finally we can have a clear idea on what we wanna buy!
    Marco
    XtremeHardware.it
    Asrock Italian Official Support Forum, Enermax and Sapphire Support Forum
  23. #23
    Mar 2006
    Hellas
    I'd prefer a comparison at lower speed but same setup than this.Every mobo has different results,even these from the same company/model.This is just my opinion..of course thanks a lot for the results!
  24. #24
    Apr 2006
    NJ
    Cool, Thanks a lot for the comparisons!
    I have a DQ6 waiting for its conroe chip to be fired up!
    Antec P180 SILVER
    Asus P8P67 Deluxe Bios 1602
    Intel Core I7 2600K @ 4.8ghz 1.295V Manual 24/7
    Thermalright Ultra 120 Extreme
    OCZ 700W PSU
    4X2GB Corsair Vengeance DDR3 1600mhz
    Seagate 1TB Samsung 1TB (X3)
    MSI Radeon HD 5850
    WINDOWS 7 PRO X64
  25. #25
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    that DQ6 sounds just as wacky as my P5W DH alot of the same issues you had are the same ones i have
    can NOT manually set SPD timings
    can boot at 400+ FSB with AUTO MCH
    can NOT boot at over 410FSB nothing that i do makes it work. 1:1 or 4:5 or any ratio... nothing works.
    there was some other ones ..but anyways.
    wow sounds like their DS3 board is a real killer compared to the DQ6
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
