All right guys. I know a lot of you have been having strange issues with this board. Mine is quite finicky, but there seems to be a trick to getting it to work properly. I'm currently testing out a few things, but for me, the largest problem by far involves something called "DQS Receiver Enable Delay" (DQSRED for short) in systool. sadly, this option cannot be changed in the BIOS, but I emailed MSI asking for a few things just a few minutes ago, so we'll see how that goes.
So, for those of you who can boot into windows, I ask you to tell the following:
"DQS Receiver Enable Delay" as reported by systool in the "AMD AM2 Memory Fine Tuning" page
HTT speed
CPU Multi
Memory Ratio
Memory timings & voltage
Which memory you are using
What I have found so far is that as the HTT is raised about 10mhz, the DQSRED also rises about 0.10 to 0.15ns. However, the MSI seems to be setting the DQSRED too high in some cases.. most notably when the HTT is raised. Sometimes, the BIOS will raise the DQSRED a full ns for a 10mhz bump... when that happens, even though I can still boot into windows if the memory ratio is low enough, SuperPI will get an error for anything over 64k
i'm currently working to see if there is a relatively simple formula that you can plug in the mhz and memory divider into to get the ideal DQSRED.. so stay tuned i guess.
i also welcome anyone with questions or tips that they have found from their own board to post here, hopefully we can all figure out this board and get it working the way it should
