Guys today i`ve bought the Mobo and now i check the temps 50 degrees is the mobo tempand the cpu which is set to 4Ghz and default voltage is about 65 degrees
I cool the system with home made water cooling and checked how the cpu block is placed and its good placed and the grease(AS5) is ok too.Now default freq and 1.2voltage 43-4 deg in idle mode
