Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 117
Thread: P5W DH Deluxe Issues...
    Jun 2005
    Durham University, UK
    Well...first off all, after i exceed a certain FSB (around 330ish, don't know for sure...), when i select restart from the shut down menu, rather than doing it normally, it'll completely shut off, and then power back up in a few secs. The same thing happens when you save changes in the CMOS and restart. Even if i press the reset button, it'll do the same thing. What gives?
    Also, I can't really get above 400 MHz on the FSB without it failing to POST....It also fails to post if vMCH is > 1.55v. I've tried both 0502 and 0602 BIOSes, but there's no difference apart from the fact 0502 doesn't allow me to adjust vCore.
    And now, I can't get into windows at an FSB of 370 MHz wheras 386 x 7 is fully prime stable and 400 x 7 was prime stable until i stopped it after an hour.
    Any suggestions are more than welcome
    It's not the RAM....I've tested it via memtest and it happily does DDR1000 @ 4-4-4-8
    The rig
    CPUs: E6300 ES B0 @ 3220 MHz w/1.35v orthos stable | E6600 B2 @ 3400 MHz w/1.43v --> Sold | Xeon 3050 L2 @ 3304 MHz w/1.45v orthos stable
    MoBo: Asus P5K-E WiFi-AP @ 520 x * orthos stable
    Graphics: 256 MB Connect 3D Radeon X1900XT @ 661/828 (core/mem)
    RAM: 2 x 1 GB Team Xtreem PC2 5300 @ DDR1010 4-4-4-8 / DDR1100 5-5-5-12 w/2.25v orthos stable
    HDDs: 300 GB (16 MB Cache) and 80 GB Maxtor Diamondmax 10 drives
    Optical: NEC ND3500AG DVD +/- RW
    PSU: Antec True Power 2.0 550W
    H2O
    Swiftech MCR220-QP | Laing D5 | AquaXtreme MP-05 Pro LE | DangerDen Maze 4 LP | 2 x 120mm NoiseBlocker SX1 fans
    Lappy
    MSI MS1022 14.1" Widescreen Barebone | Celeron-M 360 1.4 GHz @ 1.86 GHz / Pentium M 715A | GeForce 6200 Go | 80 GB Fujitsu HDD | Sony DVD +/- RW
    Waiting for
    Nehalem
    Admin
    Dec 2003
    Hillsboro, OR
    Try loosening the PCI-E link parameters. I don't remember exactly what they are off the top of my head. (Not at home right now)
    Mar 2004
    Tried 0078?
    Intel FTW!
    Beanna
    Jun 2005
    Quote Originally Posted by NiCKE^
    Tried 0078?
    Got a link?
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    jesus dont tell me the DH is doing that too.
    the -E Premium board had that same issue.
    some one said it was an asus feature, feature my arse its frickin annoying and BAD for your hardware.
    you cant reboot, re cant resart, you cant exit the bios, you can not restart from dos, you cant do anything the system shuts down and then about 3 seconds later restarts like nothing happened.
    you cant tell me asus doesnt know whats going on.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Jun 2005
    Quote Originally Posted by Lestat
    Yep...that's exactly what's hapenning on my MoBo...
    @NiCKE^: I'll give that bios a shot. Thanks for the link
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
    May 2006
    Herbert's House in Family Guy
    http://wiki.p5wdh.de/doku.php?id=downloads:bios
    try all those. cool german site
    also have u experience any vdroop?? cuz my Pentium D 920 at 3.78Ghz is experiencing taht a little bit. I set Vcore to like 1.4715 in BIOS and only getting about 1.44 during idle and 1.43 1.42 during full load dual prime 2004.... and MCH,FSB,ICH were left to auto, also there is no way to increase PCI X voltage?? should i just increase PCI X clock??
    Jun 2005
    00778 didn't help. Should i try 0504?
    I've already tried:
    0401
    0502
    0602
    0078
    And this stupid reboot problem still occurs.
    Can someone take a pic of their P5W DH and post it? I'll compare it to mine to see if any Caps are missing. AFAIK, the problem on the P5WD2 could be solved by adding a cap. Maybe my MoBo is an earlier revision or something
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
    May 2006
    damn, my power switch is broke... getting one this afternoon .
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by K.I.T.T.
    This is fairly normal behavior with 975X chipset. My guess is the board needs a few seconds to adjust to a new strap. Same thing will happen with Bad Axe board.
    As far as the FSB problem, that could any one of a number of things. You need to increase MCH voltage if you want to get higher FSB.
    Jun 2005
    Quote Originally Posted by sierra_bound
    So does anyone else have the same issue with this board then or is it just me? Because one of my mates with the same board reports no such problem
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
    Xtreme Legend
    Dec 2003
    Northern California
    My board does it too. It's just something I've learned to live with. I mentioned the temporary shutdown thing in another thread that's since been buried out of sight.
    If you're not overclocking or making a lot of BIOS changes, you will probably never experience this.
    May 2006
    about this pic:
    http://img407.imageshack.us/img407/8273/165pj.jpg
    was i in the edge of burning my Pentium D 920?? lol, is the reading accurate??
    cuz according to x bit lab:
    http://www.xbitlabs.com/articles/cpu...920-930_5.html
    it says that in some benchies the temp topped 70c ....
    May 2006
    You know, I'm getting it too but not all the time. Sometimes, like you said, it shuts off for few secs then powers back on. Other times it performs a normal reboot.
    Jun 2005
    Quote Originally Posted by SturmoV
    same here mate
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
    Mar 2004
    My P4C800-E Deluxe had the same behaviour.
    Intel FTW!
    Beanna
  18. #18
    Xtreme Cruncher
    Jul 2005
    London - UK
    p4gpl-x behaved the same too, it also had the vcore problem
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
  19. #19
    Feb 2006
    This thread makes me concerned b/c I ordered one of these P5W DH from newegg.
    Seems though from the SPI scores that this one outperforms the bad axe...
    so with X6800 retail and P5W DH will CPU multiplier be unlocked???
    this way there is no reason to push the FSB so hard to create problems
    can anyone confirm for sure?
    QX9770@3.66Ghz 24/7 365
    790i STriker II Extreme Rock Solid Stable (finally)
    8GB Corsair XMB 1600Mhz DDR3
    MSI 280GTX OC 650/2300 in SLI
    300GB Velociraptor, 500GB Data
    4X Liteon Blu-ray Burner
    MMORPG
    Vista 64
  20. #20
    Xtreme Cruncher
    Jul 2005
    London - UK
    oh, ps..
    here's the fix
    http://translate.google.com/translat...language_tools
    edit@ in case it don't make sense.. it basically says don't plug mouse or keyboard into port 3 or 4
  21. #21
    Xtreme Mentor
    Jun 2002
    so did this fix work for you?
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
  22. #22
    Jun 2005
    Quote Originally Posted by lawrywild
    oh, ps..
    here's the fix
    Nah mate...my muse and keyboard are PS2...and those USB ports have nothing plugged in. lol...those 2 ports are still covered by a label...havent been bothered to take it off
    The rig
    H2O
    Lappy
    Waiting for
    Nehalem
  23. #23
    Xtreme Legend
    Dec 2003
    Northern California
    oh, ps..
    here's the fix
    Webwilli brought this up a few weeks ago, plus a fix.
    You are more likely to experience the temporary shutdown when you're pushing the system to the limits. And as I mentioned, the Bad Axe does this too.
    All of this has been discussed before here at XS. People need to use the search function.
  24. #24
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    Yes..bad axe do it to. but ONLY happens when i change bootstrap
    The whole world's hip and thats not cool !
    Rip Van Hippy
    Doesn't expecting the unexpected make the unexpected the expected ?
    Light travels faster than sound. This is why some people appear bright until you hear them speak
  25. #25
    Xtreme Cruncher
    Jul 2005
    London - UK
    hmm hope mine doesn't do it..
    did you take the plastic off the nb cooler? I noticed theres some plastic coating on it but was worried if I took it off it'd remove that nice Digital Home logo atm the plastic is spoiling the sexy polish job
