http://service.futuremark.com/compare?3dm05=2099808
@ 740/1720Mhz (1.65/2.06V)
990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
OMG!ótimos resultados Barrel!!
os 800mhz ainda virão![]()
when you say 1720 do you mean 860 ?
and thats a crazy ass heatsink fan you got on that card.
DFI LANPARTY UT nF4 Ultra-D [6/23 BIOS]
AMD Opteron 148 [CAB2E 0546GPMW] [257x11.0 @ v1.500] & Zalman CNPS7000B-CU
OCZ EL Platinum Rev. 2 2x512[207FSB @ 2-3-3-6 @ v2.80 1T]
DFI Ultra-D [6/23 BIOS]
eVGA 7800GT [470 / 1100]
Western Digital Caviar SE 250GB Serial ATA
Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
which side of the gfx resistor did you solder to which side of the variable resistor? does it even matter?
I will probably be picking up a 7600gt to tide me over to DX10 and I will be volt modding it, unfortunately I am pretty much a volt mod noob.
thanks alot
how does that even fit. nice work
Asus p5n-e sli
E6300 stock heatsink
2 x 1 ddr667 supertalent 5-5-5-13 2.1
X1800xt 256mb
Enermax liberty 620
yep 860x2Originally Posted by cMw
Originally Posted by vapb400
It don't matter
pencil mods ftw
Q6700
MSI P35
8GB OCZ
2xHD 2900 XT
PCP&C 1kw
Always like looking at big hsf's on little video cards ..and nice results too. Excellent.
Regards
Andy
@ 686/1600Mhz (1.48/2.06v)
Full-Load
That is a very clean and professional looking card there. Very nice mods you've done.![]()
it does, if the VR is set at say 75k and you solder to the wrong 2 pins (assuming its 100k for example) you'd get 25k resistance.. = b00m..Originally Posted by Barr3l Rid3r
and you much screw opposite ways for the different pins..
but anyway awesome mod and nice scores
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
Incredible score there!![]()
And great mod with the cooler...
what are the stock volts for a 7600GT??
Best regards![]()
Silverstone RAVEN RV02|
Core i5 2500K@4.4GHz, 1,300V|
Corsair A70|ASUS P67 Sabertooth|Creative X-Fi Titanium Fatal1ty|
Corsair Dominator DDR1600 4x4096MB@DDR3-1600@1.65V|Sapphire HD7970 3GB 1075/1475MHz|
Corsair Force F120 120GB SSD SATA-II, WD Caviar Black 2x1TB SATA-II 32mb, Hitatchi 320GB SATA-II 16mb|Silverstone DA750 750w PSU|
Well, I'm thinking you do know wich legs you are using, cut one of the side ones off, if you are confused.
He was talking about the SMD resistor in the VGA, not the trimmer.
Originally Posted by DTU_XaVier
1.3v
very nice work!!
my 7300gt(p456 pcb) 1.6v/1.86v@700/860
using a Venice 2.8Ghz?
What is the difference between the cards? GS/GT
Just lower clocks and not GDDR3 memory ( though some AIB might be doing a special with GDDR3 I guess ).
Regards
Andy
Originally Posted by zakelwe
OK, so yous is basic the same as a 7600GT right?
Are u using an 2.8GHz Venice for thos benchas?
up cause conroe is comming
didnt someone hit over 10k with a 7600 GT?
A64 3200+ @ 2600Mhz | Asus A8N-SLI Deluxe 1016 | XFX 7800 GT (510 / 1300) w/ ACS5
OCZ 2x512MB Gold Dual Channel DDR432 | Seasonic S12 500W | BenQ FP937S+ | Western Digital 160GB | Thermaltake Tsunami Dream
just a fake at 10k5
the best score with single 7600GT is 9k by a french girl![]()
i want to beat her soon when i have my conroeand may be dry ice
nice cooling!
tou will get a smaller problem if you are going for sli whit this cooling![]()
celeron!!
