did you have issues to install it ?
Did I miss something ,I can't use it after connected to usb port 3 then 4 and installed software as they said![]()
Oh.. I put the battery too before posting![]()
Gonna be mad with that lol
E8400@3.6ghz 1.11v |Asus P5E3 deluxe bios 1001| 2 giga Cellshock DDR3 12800@1696mhz|Samsung Syncmaster 2232BW 22' | Asus 8800 GTS² 512 TOP|Western digital sata 500 SE16 | Blu Ray LG GGW-H20LRB| Creative X-fi platinum|Nexus 600W | case Coolermaster 1000 "Storm"
Xeon E3110@3.6ghz 1.15v|Asus P5K premium "blackpearl" bios 503|2 gigas Cellshock DDR2 8500 |Twintech 9600 GT|nec 1970 GX|Gigabyte 3D aurora case
E8400(Q804A249) valid@ 4.8 ghz 1.56v
Xeon E3110 (Q746A534)valid@ 4.79 ghz 1.59v real bios AIR /superpi 1m@9.968 .. under vista![]()
My Ibanez 540S " Saber "overclocked with Di Marzio and Sperzel
My cousin on drums Hi Brian !![]()
Having trouble with mine too, put the battery in, plugged the wireless reciever into the Wake-On LAN ports near the Audio ports and it says diconnected when the setting screen comes up. Anyone have a clue?![]()
Core 2 Duo E6400 @ 3.2ghz w/ Zalman CNPS9500LED
G. Skill 2x 1GB DDR2-800 ZX
P5W DH Deluxe
Asus X1900XT
Lian Li V1000B II Plus
32gb WD Raptor 10krpm SATA
320gb Seagate 7.2krpm SATA
Kingwin 600MA1
have you installed the cd drivers or website one ?
retired computer enthusiast
CD drivers, they're the same I think since I checked their website and believe I installed those too and no luck
P5W DH Deluxe
Asus X1900XT
Kingwin 600MA1
i installed the cd drivers. mine is working fine.
did you stick it in one of the usb ports closest to the pcie slots?
i installed the drivers off the website.
software always says disconnected
except ONCE... i removed/reinserted battery, and i was able to use the remote until next restart.
really, really bothering me. because i was going to buy a media remote before i found this board. so this sucks.
i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
Installed it closest to the audio connections like it said to, but still no luck. Did you plug in the receiver before installing the drivers or after?Originally Posted by m0da
P5W DH Deluxe
Asus X1900XT
Kingwin 600MA1
I plugged it in before I installed the drivers, but I dont think the order makes a difference...
Did a battery come with it? I didnt see one and went out and bought another battery when I set it up.
Aspire-X Superalien
OCZ GameXStream 850W
Asus P5W DH Deluxe
Intel Core 2 Duo E6600 w/ Zalman CNPS9500
2GB OCZ EL Platinum XTC PC2-6400
EVGA GeForce 8800 GTX Superclocked
SB Audigy 2 ZS Gamer
2 x Seagate Barricuda 7200.10 500GB
Perhaps the battery is close to dead when shipped?
Maybe, it still makes the blue light on the controller light up. One thing that also bothers me is that the battery sort of doesn't click in, you have to just toss it in and cover it up for it to stay in place.
P5W DH Deluxe
Asus X1900XT
Kingwin 600MA1
Well,
I just found out the remote can power up the computer each time. Yet, in Windows, it shows disconnected and does nothing... !
I fixed it, I switched it around to each USB port after I installed the drivers and seems to work in the non-Wake On LAN USB ports so it works, just wont boot on the computer I think. But does launch programs and all sorts of stuff and can go into hibernation.
P5W DH Deluxe
Asus X1900XT
Kingwin 600MA1
so, putting it in the 'top' ports fixed it?
If so... gonna burn asus manual for goodOriginally Posted by AndrewZorn
too lazy to plug the receiver and check it![]()
weird how the ones designed for it dont work
i havent tried it yet myself
its like, i thought that the designated ones would just have wake enabled
and other than that normal usb ports
so for windows to not work with them... weird
also i used the external usb hookup thing for my case usb and those dont work. cant figure it out
can yall tell me what this remote does?
Asus p5n-e sli
E6300 stock heatsink
2 x 1 ddr667 supertalent 5-5-5-13 2.1
X1800xt 256mb
Enermax liberty 620
turns computer on/off, controls winamp/media players, sets up wifi in sleep mode
and ive discovered that by setting up the user profiles or whatever, you can make the 5 buttons whatever you want as far as hotkeys go
so i could in theory play icy tower with my P5W remote
if i could get theto work
What I did:
1) downloaded drivers from Asus website
2) Installed Drivers, rebooted
3) Connected the Wireless Receiever to various mobo USB ports until one worked
4) Worked on the bottom USB port (not near Audio inputs)
5) Disconnected it from the non-Wake On port and connected it to a Wake-On port.. it worked!
P5W DH Deluxe
Asus X1900XT
Kingwin 600MA1
wait, so what port is it finally in?
1 3
2 4
------------BOARD
Cant get it to work, always "disconnected", my board is not being recognized as Asus-board, i think thats the problem. Try this: Rightclick the DH Remote icon in the system tray, select NoiseOff or EZ-WiFi. Then do you get a msg saying it will only work on P5W-DH board? It happens sometimes here, unless i mess with task manager and move receiver to other USB ports.
I think clean install is needed to make it work right away, lets hope someone will find a way around it.
BadAxe2, WC'ed L631B115 Xeon3060 3.4GHz 1.27v summer OC, 2GB BallistiX 4:5,
2x250GB-16 Raid-0 + 400GB-16, 7900GTO 512MB, Acer 22" Wide, Nexus 500W.
noiseoff and easywifi work for me (though, wihtout the remote, i couldnt get out of easywifi, i had to shut off)
still says disconnected
this is really dumb
i was pumped about the remote
1)turns comp on and off not too badOriginally Posted by AndrewZorn
2)media players now thats cool kinda like the AIW i used to own.
3)Set up wifi in sleep? i dont get this last function and how its relavent.
Asus p5n-e sli
X1800xt 256mb
Enermax liberty 620
i doubt id be using 1 and i know i wont use 3
basically it can make a wifi network even in S3
but anyway
like i said you can set up shortcuts to work universally (any program)
and even if it is useless i still paid for it so it sucks that its so hard to get working
Mine works in its required usb 3/4 port. Since i use a BTX case, its the top usb ports for me.. Powers on when off with the remote as well.
did you install drivers from website or CD, and did you do anything else special?
