Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: The Intel Conroe supported price saving 975X-DFI INFINITY 975X/G
    Nov 2004
    Intel Core 2 Duo series will be released in July 2006 to open up the new
    frontier of desktop PC performance.
    This time, as we expected, Intel still follow it’s own style. Intel Core 2 Duo
    series comes with complete different platform compared with the Pentium 4
    series.
    Except new Intel 965 chipset, 975X could also support this new series by
    modify M/B PCB layout. Most of major M/B manufacturers already started to
    change their M/B layout to accommodate this new series of Intel processors.
    In July, users should be able to see Conroe supported 975X M/B
    released to retail market.
    Now let us look at the product package of INFINITY 975X/G
    Product accessories:
    Thick user manual, driver CD, cables, RAID driver floppy, rear panel I/O Shield.
    Motherboard appearance
    After one year of refinement, The INFINITY series, targets on budget
    solution, the material and components used on this series now come with the
    taste one step closer to high-end products in the market.
    The lower left hand corner
    Two PCI-E x16 slots, could be used with ATI CrossFire.
    The lower right hand corner:
    The built-in Power&Reset button.
    The South Bridge is equipped with ICH 7 chipset, and the light green squire
    shape covered on the top of ICH 7 chipset is the unique DFI fan-less ceramic
    chipset cooler.
    The upper part of motherboard:
    Equipped with 6-phase Digital PWM power design provides more stable
    electric current and more stable system performance.
    Rear I/O connectors:
    Following the footstep of ASUS, DFI also starts to adopt eSATA interface on
    rear I/O panel, external SATA storage devices now can be easily used by the
    access of eSATA connector on rear I/O panel.
    Nov 2004
    Introduction of BIOS options:
    Genie BIOS setting page:
    The main setting page for the tuning of system performance.
    CPU voltage control:
    The CPU VID Offset setting range is broad enough from 12.5mV to 787.5mV, equivalent to 0.0125V to 0.7875V.
    And each offset interval is as small as 12.5mV only.
    The CPU clock setting range from 266Mhz to 533Mhz
    The lowest FSB depends on the default CPU clock setting,
    If the CPU is 133 or 200 MHz, then its FSB starts from 133 or 200 MHz.
    DRAM voltage
    The range from 1.9V to 2.65V, with 0.05V of interval.
    DDRII supports from 400, 533, 667 to 800Mhz.
    DRAM timing setting options
    PC Health Status page:
    Shows more components’ voltage than other products.
    Even though under Intel Platform, there are less overclock options and smaller overclock range,
    DFI still provides many overclock options to end users.
    Nov 2004
    Test Environment
    CPU:INTEL Core 2 Duo E6700
    MB: DFI INFINITY 975X/G
    DRAM:Corsair TWIN2X2048-6400C3
    VGA:MSI RX1900XT 512MB
    HD:Seagate 7200.7 80GB
    POWER:AcBel 550W
    Cooler:Tower112
    System configuration
    CPU 300X10=3000Mhz
    DRAM DDRII 900 CL3 3-3-9/13
    VGA Core/Memory 625/1450Mhz
    PCMARK2005
    DDRII 900 CL3 3-3 stable
    3DMARK2005
    X1900XT CrossFire
    Strength:
    1. Supports Conroe processors, and the price is roughly $250 U.S. dollars.
    2. Equipped with 6-phase Digital PWM power design and ceramic chipset cooler.
    3. Equipped with eSATA interface.
    4. Broad range of CPU & DRAM voltage, and broad range of CPU clock setting.
    5. Built-in Power & Reset buttons
    6. The tendency to use better capacitors.
    Weakness:
    1. The DRAM compatibility still needs some improvement.
    2. Boot up LOGO and hardware monitor utility program also need some refinement.
    At the moment, most of 975X M/Bs do not support Conroe processor,
    and the price range is roughly between 220 to 330 U.S. dollars.
    The new release of DFI INFINITY 975X/G comes with relatively lower price
    and competitive performance will certainly stir up some excitement in this
    price sensitive motherboard retail market.
    CPU:INTEL Core 2 Extreme X6800
    MB: MSI P965 Platinum
    DRAM:PATRIOT XBL DDRII 1000 512MBX2
    VGA:MSI RX1900XTX
    POWER:AcBel 550W
    Cooler:Sonic Tower
    400Mhz
    Jun 2006
    Can you test maximum FSB?
    Oct 2005
    Belgium
    Wow dude, nice work
    edit: Oops, there was more to come
    Nov 2003
    Thanks for all the pix and preview into the latest gear, wwm. Very informative.
    ln2nl
    Jun 2004
    The Netherlands
    37x mhz fsb is max... to bad for now
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Jan 2006
    but at least u got crossfire working. thats pretty cool. any special drivers needed? or just regular ones. 37x is kinda weak tho :/ hope bios updates fix it. unless they did that on purpose to shine on the lanparty.
    Asus p5n-e sli
    E6300 stock heatsink
    2 x 1 ddr667 supertalent 5-5-5-13 2.1
    X1800xt 256mb
    Enermax liberty 620
    Nov 2003
    france -- lille
    Quote Originally Posted by Waus-mod
    I have see 400 mhz fsb by coolaler
    Xeon 3060 L631B115 max 4680 superpi SS 10.904
    Asus P5B deluxe + vdrop vcore vddr2 vmch mods
    2x1go crucial ballistix pc8000
    2x1go crucial ballistix pc6400
    8800 gts 320 // x800xl // 9250 pci
    corsair hx 620 // seasonic s12 500
    DOD chilly1 R402a
    watercooling // zalman9700
    Jan 2006
    http://www.xtremesystems.org/forums/...d.php?t=104712
    he got 455.........lots of mixed results here.
    Asus p5n-e sli
    X1800xt 256mb
    Enermax liberty 620
    May 2006
    alexandria, VA
    wow almost 18000 on on '05 with just a little bit of overclock, impressive, like someone said before can you test the max fsb
    Intel Core 2 Duo T5500
    2GB DDR2 667
    120GB 5400 HD
    Intel GMA 950
    XP MCE
    (^Laptop)
    May 2006
    hmm...$190ish you say? I thought I was going to have to wait for a 965 to get a board under $200. Now we need some more test results...that and somewhere to buy it.
    Champion
    Nov 2004
    Hungary
    Micutzu reached 500Mhz FSB with dfi.
    "We are competing, competing to win. And the main motivation is to compete for victory" - Ayrton Senna
    Oct 2005
    Tempting board, but the power connector placement and all the caps next to the socket kinda kill it for me. It looks like it'll be a to insulate around the socket. For the price it looks very good though, not to mention the nice overclocking options.
    Antec P180B
    OCZ GameXstream 600W
    Q6600 G0 w/CNPS9500 LED
    DFI LanParty LT P35-T2R
    Corsair TWIN2X4096-6400C5DHX
    eVga 7800GT CO + VF900
    WD 74 GB Raptor (Leopard 10.5.2)
    A lot of storage...
    Dell 2405FPW
    Logitech G7 in Black
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    As i posted last week, the board is fixed on the 1066 strap so the board will max out unmodded at 370fsb...this is an internal cut off as the board needs to move to the 1333 to clock higher.
    That being said if you have an XE and you use the 13 multi you will have higher scores in the 1066 strap than the 1333 with a lower multi and high fsb.
    DFI have a bios in tesing i hear that has the 1333 strap....this should see the board fly over 370fsb easy.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Nov 2003
    france -- lille
    Quote Originally Posted by over@locker886
    link please
    DOD chilly1 R402a
    Champion
    Nov 2004
    Hungary
    Quote Originally Posted by d@rkn1ko
    link please
    http://www.crazypc.ro/forum/showpost...&postcount=150
  18. #18
    ln2nl
    Jun 2004
    The Netherlands
    Quote Originally Posted by Tony
    like i said to bad for now
    *EDITed by IFMU*
    Forum Policies
  19. #19
    May 2006
    Belgium
    You're right about the price : in Europe also (at least) around €190,- (including VAT), which I find quite expensive for a "mid-range" offering. In my opinion there's little price difference with the "top" motherboards as the Asus P5W DH which sells here for €210 (also incl. VAT). What is €20,- if you've got to pay about €1000 for ram + cpu ?
    Just my 2c hey
    "The light at the end of the tunnel is the headlight of an oncoming train" (Murphy)
    Reviewing for Madshrimps
  20. #20
    Jan 2006
    Fl
    May have to keep an eye on this one,Good price & some room for OCing. I wont shell out anything over 200 bucks for a Mobo
    E6750 G0 POS!
    GA-P35-DS4 Rev. 2.0
    Visiontek HD4870
    Maxtor SATA 160
    OCZ Reaper 2x2 1066
    X-Fi Fatality XG Pro
    Tsunami Dream/Thermaltake TP650
  21. #21
    Nov 2003
    france -- lille
    when I look the cpuz validation I see intel board not dfi
    DOD chilly1 R402a
  22. #22
    Sep 2002
    Sydney, Australia
    so these boards will take a celeron D?
    Rehabilitation for memory addicts
    Intel Core 2 Duo E6300 ES | Gigabyte GA-965P-DS3 | Thermalright XP90C | 2 x 512MB Corsair XMS5400UL | 256MB GeCube x1800xl
  23. #23
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    yep
    Sistem de test:
    Intel 975X BX - rev 304, BIOS 0908, Vmodded
    Kingston KHX4300D2K2 3-3-3-10
    EVGA 7900GT CO Superclocked - Vcore = 1.55V, cu AC Silencer 6
    Tagan U15 580W
    Win XP SP2, Forceware 91.31
    cooler stock Intel (de la un Pentium 630)
  24. #24
    Champion
    Jun 2002
    lab501.ro
    I was using Intel Bad Axe guys, no time to test the DFI.
  25. #25
    Oct 2004
    IL
    looking like a cheap and good mobo
    Sorry for my bad English.
    Rig I:
    | I7-2600K | Intel DZ68DB | Mushkin BlackLine 4Gbx2 1333 | Intel SSD 320 | Seasonic M12 520w
    Rig II:
    | E2160 (stock) @ 3Ghz | IP35-E | Gskill F2-6400CL4D-2GBHK | Gecube HD2600xt + Accelero S1R2| WD 250 AAKS | Hec Silent Pro 385w |
