Results 1 to 16 of 16
Thread: First experiance: GB GA-8I945GMMFY-RH Socket 479Y
    namu daishi henjo kongo
    Jan 2005
    Somewhere in Germany
    Got this socket 479Y mobo yesterday, will be my new working rig and r@h cruncher..
    Manufacturer: GA-8I945GMMFY-RH
    Factor: µATX
    Socket: 479Y (for Yonah and Merom, retention modul S478, here with Zalman 7000B-AlCu)
    CPU-Supprt: Yonah and Merom
    Chips:
    1. Northbridge: Intel® 945GM Express Chipset
    2. Southbridge: Intel® ICH7M-DH (with SATA-Raid - hey, guys from AOpen, look at this... )
    3. T.I IEEE1394a controller
    4. Intel PRO1000PL Gigabit Ethernet controller
    5. Realtek ALC880 audio codec
    RAM: 2 x Slots DDRII PC5400
    internal connectors:
    1. 2 x Serial ATA 3.0Gb/s connectors
    2. 1 x UDMA ATA 100/66/33 connectors
    3. 1 x FDD connector
    4. 2 x IEEE1394a connectors (supports 2 ports)
    5. 2 x USB 2.0/1.1 connector (supports 4 ports)
    6. 1 x SPDIF IN/OUT
    7. 2 x Cooling fan pin headers
    8. 1 x COM port connector
    external connectors:
    1. 4 x USB 2.0/1.1 ports
    2. 1 x RJ45 ports
    3. 6 x Audio ports (4 x Line-out/ 1 x Line-in/ 1 x MIC)
    4. PS/2 Keyboard/ Mouse
    5. 1 x COM port connector
    6. 1 x LPT port
    7. 1 x VGA port
    8. 1 x 1394 port
    slots:
    1. 1 PCI Express x 16 slot
    2. 1 PCI Express x 1 slot
    3. 2 PCI slots
    BIOS-features:
    VCore: no adjustment
    VDimm: no adjustment
    FSB: no adjustment
    EIST: enable/disable, Idle 0,98 V ± 0,02 V, Load 1,18 V ± 0,02 V (measured with MM)
    RAM: timings could be adjusted, divider also (400, 533, 667), with CTRL+F1 add menue
    fan controll: works very good
    VCore-measuring:
    Readout of VCore is wrong with CPU-Z 1.34 and 1.35, 1.33 works, Easytune HW-monitor also, but slighlty to low.
    test rig:
    CPU: T7400ES (Merom, 166 MHz x 13)
    RAM: 2 x 512 MB Syncmax eXtreme PC6400
    Cooler: Zalman 7000B-AlCu
    GFX: NV 6600
    PSU: Seasonic S12 380 W
    HD: WD 74 GB Raptor
    DVD: Toshiba
    power consumption:
    Idle: approx 50 W (with EIST)
    Load (2 x Pi): approx 80 W
    Temperatures measured with HW-monitor:
    BIOS: download@gigabyte - atm 1. Release
    + very low power consumption
    + Merom-support
    + nice working fan control
    + SATA-Raid ( AOpen guys, look at this... )
    + quiet cheap compared to other S479Y-boards (prices at geizhals.at)
    + S478-retention modul
    + BIOS looks sophisticated
    - only 2 SATA and 1 IDE-Port
    - no OCing
    - only 2 RAM-Slots
    Conclusion: cheap and economical mobo for working rig and HTPC
    More to come...
    Questions? Comments?
    BTW: if somebody knows a working pinmod, please post a link, *this one*, but doesn´t work...
    Quote Originally Posted by NEW MODEL ARMY - the attack - 1984
    Now the talking's over, plans are laid and the hour is set
    Glances round the table, eyes all shining, dark and bright
    We meet again at daybreak for the day that will be ours
    We're tomorrow's history. So just check your weapons, say your prayers.
    May 2006
    Herbert's House in Family Guy
    sweeet
    hope i can find merom chip
    EDIT: WOW 80 W
    Nov 2004
    Holland
    Looks like a nice and affordable mainboard
    My Rig:
    Intel Core 2 Duo E6400
    2x512mb Micron PC3200 OEM D9DQW "Fatbody"
    Biostar TForce P965 Deluxe
    MSI/Medion GeForce 6700XL (Cheap )
    Chieftec 360W (in search for someting better)
    WD 160GB S-ATA
    Oct 2004
    IL
    Nice, good mobo ... can be used in HTPCs
    What it is ?
    Sorry for my bad English.
    Rig I:
    | I7-2600K | Intel DZ68DB | Mushkin BlackLine 4Gbx2 1333 | Intel SSD 320 | Seasonic M12 520w
    Rig II:
    | E2160 (stock) @ 3Ghz | IP35-E | Gskill F2-6400CL4D-2GBHK | Gecube HD2600xt + Accelero S1R2| WD 250 AAKS | Hec Silent Pro 385w |
    Jan 2005
    The Gigabyte has the same mounting system copared to socket 478, means you can use more or less every S478 cpu cooler...
    Jan 2005
    Ok, for shure no OCing, but look at the power consumption:
    CPU: Vonah T2600ES vs Merom T7400ES (both 2,13 GHz)
    MoBo: Gigabyte 945GM
    GFX: NV 6600 passiv
    PSU: Seasonic 380 W
    HD: 74 GB Raptor
    DVD: Toshiba
    Merom@166 x 13
    Idle (mit EIST): 53 W with 0,98 V (measured at board)
    Load (r@h): 84 W with 1,21 V (measured at board) - Tcpu = 42°C acc. Easytune HW-Monitor
    Yonah@166 x 13
    Idle (mit EIST): 54 W with 0,98 V (measured at board)
    Load (r@h): 81 W with 1,27 V (measured at board) - Tcpu = 43°C acc. Easytune HW-Monitor
    To compare:
    Yoanh@AOpen i975Xa with r@h: approx 110 W
    Merom@AOpen i975Xa with r@h: approx 150 W -
    Why is there a difference of 40 W at the AOpen? The only thing I see is the BIOS, or?
    Xtreme Legend
    Mar 2005
    Australia
    no OCing = banned
    Team.AU
    Got tube?
    GIGABYTE Australia
    Oct 2004
    IL
    Quote Originally Posted by stummerwinter
    Cool
    I need new mobo for my 2.8C
    BTW, you tested some S478 cpu on this mobo ?
    Rig I:
    Rig II:
    Oct 2004
    IL
    sorry, DELETE !
    Rig I:
    Rig II:
    Nov 2005
    Germany
    Quote Originally Posted by Andrewv
    Cool
    you can use S478 cpu cooler on it, not s478 cpus
    Oct 2004
    IL
    Quote Originally Posted by Chri$ch
    My bad :\ lol
    Rig I:
    Rig II:
    Apr 2005
    Hey Stummerwinter, this is great info, I was looking around for Merom support, as my Yonah Asus still hasnt got BIOS support; this board is even better;
    + retention module
    + 4GB RAM support (Asus only 2GB for those planning on Vista)
    + Merom !!!
    + Low power
    How much did your Merom cost?
    And do we have any Merom experts that can explain stepping/revisions?
    Jan 2005
    I paid for my ES weeks ago 500 €, but prices dropped alot, you pay now less then 400 €...
    If you need a contact, PM me...
    The problem is, after Conroe is availible nobody is taking care of Merom´s...
    Apr 2005
    Thanks for the further info, I've been offered one at 300US or 240€
    Maybe ES prices dropping because of *all* the interest in Conroe, this is good for me!
    How did you measure your power consumption, using a wall socket meter?
    I have a similar Yonah system, which idles at 77watts, very high compared to your Merom (using seasonic power angel)
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by solaa21
    really i have a need for large qty on regular basis..........say 10-20 at a time.........can you hook me up with your contact.........anyone else for that matter
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jan 2005
    I used this one, from a big german electronic distibuter: Energy Check 3000
    I measured the following:
    @AOpen:
    Yonah@2,90 GHz (AutoVCore): 110 W during r@h
    Merom@2,75 GHz (AutoVCore): 150 W during r@h
    @Gigabyte:
    Yonah@2,13 GHz: 80 W during r@h
    Merom@2,13 GHz: 82 W during r@h
    I don´t understand the difference at the AOpen...
